Zero G profile
Old May 8th 07, 11:47 AM posted to rec.aviation.piloting
mike regish
Default Zero G profile
What's the best way to fly a zero G parabola? My kids are hooked on them and
they're actually learning some science from it. I'd like to get a little
more duration without getting too fast.
I usually do a little climb until the speed bleeds off some and then push
over firmly. Should I pull the power over the top as I'm pushing?
mike
Old May 8th 07, 02:58 PM posted to rec.aviation.piloting
Paul Tomblin
Why don't you get up to full speed, pitch up, then push down a bit? That
way you can get negative G's on the way up while you're bleeding off the
speed.
Paul Tomblin http://blog.xcski.com/
I mean, if went 'round saying I was a perl hacker, just because some
moistened bint lobbed a "Perl for Dummies" at me, they'd put me away!
-- Randy the Random
Old May 8th 07, 03:43 PM posted to rec.aviation.piloting
Dale
mike
While your doing the zero G take a glance at the oil pressure
gauge...you may find it has dropped very low. FYI
Old May 8th 07, 09:23 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
That's what I do. Keeps me from accelerating excessively in the dive.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200705/1
Old May 19th 07, 03:28 PM posted to rec.aviation.piloting
Mxsmanic
JGalban via AviationKB.com writes:
Your acceleration is fixed in a parabola. It is always exactly -1.0 G, which
precisely negates the pull of gravity and gives you the zero gravity
objective.
Old May 19th 07, 04:09 PM posted to rec.aviation.piloting
Maxwell
"Mxsmanic" wrote in message
which
objective.
Clueless as usual.
Old May 19th 07, 05:42 PM posted to rec.aviation.piloting
Mxsmanic
Maxwell writes:
Clueless as usual.
A zero-G parabola is a ballistic trajectory; it always involves acceleration
towards the ground (in the direction of gravity) at exactly 1.0 G. That's how
it produces the "zero-G" effect.
This being so, you cannot change the acceleration of the aircraft along the
vertical axis without losing the zero-G effect.
Essentially, if you fire a cannonball next to the aircraft, your aircraft
needs to follow the same path as the cannonball in order to become
"weightless."
Old May 19th 07, 06:29 PM posted to rec.aviation.piloting
Maxwell
acceleration
how
"weightless."
Obviously,,, but it still has "zip" to do with reducing power to avoid
Old May 20th 07, 02:05 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
Maxwell writes:
Clueless as usual.
No, it isn't.
bertie
Old May 19th 07, 09:45 PM posted to rec.aviation.piloting
mike regish
Uhh..hate to burst your bubble again, but -1 g would have you straining at
your seatbelt with a force of 1 g. If you're not wearing one, you would be
exerting 1 g against the roof.
mike
which
objective.
Saturn V Typical Mission Profile 9903826.jpg [email protected] Aviation Photos 0 April 12th 07 02:37 AM
ASW27 wing profile templates basils27 Soaring 0 June 29th 05 12:46 PM
Looking for 3/8 in-24 thread/low profile self locking nuts/ Larry Home Built 3 February 23rd 05 04:56 PM
Looking for 3/8 in-24 thread/low profile self locking nuts/ Larry Home Built 3 February 22nd 05 04:02 PM
Aviation Profile Prints for sale Chris Banyai-Riepl Military Aviation 0 July 7th 04 05:48 AM
