Proping Question
Old May 17th 07, 03:26 AM posted to rec.aviation.piloting
Dana M. Hague
Default Proping Question
On Tue, 15 May 2007 17:47:01 -0400, "Morgans"
Why no hand propping a nose dragger for you?
I've done it a few times but found it very awkward, as the prop on,
say, a C-150 or 172 is much lower than the prop on a taildragger like
my T-Craft.
On the T-Craft turning it backwards was the standard way of clearing
it if it was flooded... but there was no impulse coupling nor vacuum
pump.
-Dana
If replying by email, please make the obvious changes.
Congress shall make no law....What part of NO didn't you understand?
Old May 17th 07, 03:25 PM posted to rec.aviation.piloting
On May 16, 8:26 pm, Dana M. Hague
my T-Craft.
pump.
I haven't yet seen a Continental or Lycoming lightplane engine
without an impulse coupling on at least one mag. That impulse
mechanism is necessary for starting because it snaps the mag over fast
so it'll generate a spark, but it also retards the spark to at or near
top dead center so that the engine doesn't kick back. The usual firing
position on an A-65 is 30 degrees before top dead center. The other,
non-impulse mag won't fire at hand-propping speeds, but will sometimes
fire immediately after the engine catches and will stop it or kick it
backwards or make it hammer frightfully until the RPM comes up to
idle. Some pilots will set the mag switch to the impulse mag only
while hand-propping, going to Both after the engine is running. Much
safer. I have two impulse mags on mine and it behaves itself.
I hand-prop using one hand only. As I pull down I fold
myself so that my weight is carried back a little. The trick, as has
been mentioned, is to get pretty close to begin with. And make sure of
your footing. Anything slippery like snow or ice or wet grass, or
gravel on the pavement, can let you slide into the prop.
I don't prime my A-65 unless the temp is down around
freezing. It floods way too easily. Mags on, throttle at idle, and it
will catch on the sixth to eighth blade.
Dan
Old May 17th 07, 11:17 PM posted to rec.aviation.piloting
They're out there. In addition to the impuse system, there was a starting
system called "shower of sparks" that used a gadget called a vibrator to
provide the low rpm spark. Unlike the impulse system, the vibrator required
electrical power from the battery to make a spark.
I've usually seen these on older models.
Yup, you're right. Bendix made that system to provide a hot
spark for starting. The mag switch had extra terminals to provide an
AC signal from a buzzbox to the mag, but that mag had a second set of
points that gave the later spark for starting. Unison has a similar
setup now, but solid-state instead of an electromechanical buzzer to
create the signal for the primary winding.
Dan
Old May 18th 07, 12:33 AM posted to rec.aviation.piloting
Morgans[_2_]
starting
required
Both of those spark vibrators just make a constant sparking, just waiting
for the right combination of fuel, air and compression, don't they?
If that is the case, it would seem like that would be like a very advanced
spark, and could easily make a backfire to spin the engine backwards. Is
this what you have observed?
If that is not how they work, then...
Never Mind ! ! ! g
Jim in NC
Old May 16th 07, 10:52 AM posted to rec.aviation.piloting,rec.aviation.student
Cubdriver
On 15 May 2007 09:19:59 -0700, "Robert M. Gary"
So I would pull the prop through with an
open palm hand such that if the prop did start I would be ok (some of
the old guys actually start the plane this way)
That's what I was taught to do, and what I do if I'm propping from the
front (rarely). As it happens, I was 68 at the time, but my instructor
was 21. Blue skies! -- Dan Ford
Old May 16th 07, 11:00 PM posted to rec.aviation.piloting,rec.aviation.student
Robert M. Gary
I still do the full kick when I'm actually starting the engine. Even
when I was flying the float plane and propping from the back, I'd give
a kick. Of course, if you prime the 65 cont hp engines correctly they
take almost no effort to start. I can't imagine trying to start my
Mooney that way!!
-Robert
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
