Dan wrote:
On May 20, 6:34 am, john smith wrote: Dan wrote: What are the proper control inputs to correct the situation? Yoke full aft, full right aileron, left rudder as necessary to maintain directional control, flaps up. OK, so you're saying that based on the situation, I should trust the ATIS, not the fact that the plane is drifting right? Should the ailerons _always_ be into the wind regardless of actual aircraft drift? As a previous poster wrote, ATIS is only a guide. Keep in mind that the wind is only measured at one place on the airport. Ailerons should always be properly deflected when taxiing, taking off or landing. What direction to apply them and how much will depend on the direction the aircraft is moving and the direction the wind is striking the aircraft from. Taxiing with a tailwind is different than taxiing with a headwind or crosswind. Your instructor should have covered that with you in your primary training. If they didn't find a new instructor. The best recommendation is to get some taildragger training with an experienced taildragger instructor. THAT will really teach you about proper control position and use in an aircraft. How much rudder in one direction or the other can a tricycle gear light plane take without groundlooping? You only apply as much rudder as necessary to maintain control in the direction you want to go. |
Dan wrote:
On May 20, 6:34 am, john smith wrote: Dan wrote: What are the proper control inputs to correct the situation? Yoke full aft, full right aileron, left rudder as necessary to maintain directional control, flaps up. OK, so you're saying that based on the situation, I should trust the ATIS, not the fact that the plane is drifting right? Should the ailerons _always_ be into the wind regardless of actual aircraft drift? No, you should know from which side the wind is coming before you ever touch down. This is very easily detected while on final. And if you slip to accommodate the crosswind (which is the correct way in this airplane and almost all others), then you know exactly what is up before you ever touch down and you also know if the crosswind component is within the control authority of the airplane. How much rudder in one direction or the other can a tricycle gear light plane take without groundlooping? Quite a bit, but if you start to ground loop, then back off! One thing my primary instructor stress was that you ALWAYS apply whatever control input is required to get the performance you desire. You don't fly to some preplanned target. He was not a fly by the numbers pilot and, while I appreciate the need for that in many high performance airplanes, his basic philosophy is sound. The conditions are what they are, not what you planned for or what you wish they were. Fly the conditions, not some preconceived notion of what they should be. I am working on a checkout in this C182 after about 400 hours in Pipers. Compared to what I am used to, the Cessna ground handling (especially after touchdown) seems very squirrley. I've had the same experience with the couple hours I have in 152s and 172s as well. My Skylane wasn't squirrelly at all. Typically, it is the pilot that is squirrelly. :-) Matt |
![]() "Dan" wrote in message oups.com... On May 20, 6:34 am, john smith wrote: Dan wrote: I am working on a checkout in this C182 after about 400 hours in Pipers. Compared to what I am used to, the Cessna ground handling (especially after touchdown) seems very squirrley. I've had the same experience with the couple hours I have in 152s and 172s as well. Pipers will always feel much more "sure footed" compared to Cessnas, it's all in the landing gear. Walk up to both aircraft when they are untied and try rocking the wings. Big difference. The narrow stance and spring steel landing gear is a completely different ballgame. The Piper will feel more agile on a nice paved runway, but it's hard to beat the ride of a Cessna when the surface starts getting rough. Just boils down to personal preference and where you fly most I guess. |
On May 19, 11:26 pm, Dan wrote:
I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. You approach at a normal airspeed, full flaps, coming over the numbers at 65 kts. The mains touchdown, followed by the nosegear. Slight right aileron is being maintained into the wind. Everything is aligned properly and on the centerline at touchdown. After touchdown the plane starts to drift to the right side of the runway. You try to correct by pointing the nose back to the centerline with left rudder. The nose seems to be pointed left, but the plane is still drifting right. It feels like any more left rudder could result in bad skidding and/or a ground loop. What are the proper control inputs to correct the situation? Left aileron would be in the _opposite_ direction of the indicated crosswind. Increasing back pressure would make the nosewheel even less effective. --Dan My immediate thought was to schedule some more cross wind instruction with a good instructor! We are not talking about much wind at all. ATIS wind is not much of a crosswind - 20deg @ 10kts? I'd be inclined to use less aileron and more rudder if its drifting right into the wind. I sure as hell wouldn't drop the nosewheel to the runway and try to force nosewheel steering with the directional control in question! And for sure I wouldn't try to correct it with any brakes. Keep in mind, if its light enough to drift, its still light enough on the wheels they'll lock up and skid real easy with any brakes. I'd be putting in lots of rudder, easing full aft elevator to keep weight off the nose gear, and whatever aileron needed to keep wings level. If that doesn't work, I'd be giving serious consideration to making an immediate go around to take a 2nd look at what is happening. Makes more sense than going off into the weeds while obviously being behind the aircraft? Soaring Buzzard Infamous Worldwide Pilot/Instructor |
You approach at a normal airspeed, full flaps, coming over the numbers at 65 kts. The mains touchdown, followed by the nosegear. Slight right aileron is being maintained into the wind. Everything is aligned properly and on the centerline at touchdown. Dan, a couple other things to consider... Is there just you and an instructor in the plane? How big are you and the instructor? Full fuel, two up front, at 65 kts, your over the numbers speed is too fast. Try slowing to 55 - 60 kts over the numbers. Full stall stall speed is going to be below 45 kts at the lighter weight. Your are drifting because you are still too light on the wheels. Does the stall horn go off as the wheels touch the ground? Do you float down the runway between roundout and touchdown? You should be maintaining pitch attitude as the aircraft settles by steadily increasing backpressure on the yoke. Even as the wheels touch, you continue to steadily pull backpressure and hold it full aft until your in your parking spot and the engine is shut down. |
This simply illustrates why you can't trust ATIS to give you anything more
than a general sense of the conditions you might encounter. Winds change. ATIS stations sometimes see different wind conditions than the touchdown point, due to obstacles and wind direction. With an ATIS reading of a 20 degree off-centerline, and 10 knots of wind, I would fly a normal approach and make the corrections necessary to keep the airplane pointed straight down the runway with no drift during the flare and landing. I would not pre-suppose anything. On the other hand, if ATIS was indicating a 90 degree crosswind at 10 knots, and the smoke from chimneys, or waves on a nearby lake, or the windsock confirmed that information, I would *assume* that I had a noticeable crosswind to deal with, and would be mentally prepared for it... BUT, I'd still wait until final approach to crank in gross corrections to correct drift, and would apply whatever corrections were necessary in the flare to keep the airplane aligned and kill any drift. Bottom line.. ATIS gives you an indication of what the winds were at one point on the airfield at a given time. The conditions at your touchdown spot may be different. KB "Dan" wrote in message ps.com... I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. You approach at a normal airspeed, full flaps, coming over the numbers at 65 kts. The mains touchdown, followed by the nosegear. Slight right aileron is being maintained into the wind. Everything is aligned properly and on the centerline at touchdown. After touchdown the plane starts to drift to the right side of the runway. You try to correct by pointing the nose back to the centerline with left rudder. The nose seems to be pointed left, but the plane is still drifting right. It feels like any more left rudder could result in bad skidding and/or a ground loop. What are the proper control inputs to correct the situation? Left aileron would be in the _opposite_ direction of the indicated crosswind. Increasing back pressure would make the nosewheel even less effective. --Dan |
![]() "Dan" wrote in message ps.com... I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. You approach at a normal airspeed, full flaps, coming over the numbers at 65 kts. The mains touchdown, followed by the nosegear. Slight right aileron is being maintained into the wind. Everything is aligned properly and on the centerline at touchdown. After touchdown the plane starts to drift to the right side of the runway. You try to correct by pointing the nose back to the centerline with left rudder. The nose seems to be pointed left, but the plane is still drifting right. It feels like any more left rudder could result in bad skidding and/or a ground loop. What are the proper control inputs to correct the situation? Left aileron would be in the _opposite_ direction of the indicated crosswind. Increasing back pressure would make the nosewheel even less effective. --Dan "Kyle Boatright" wrote in message . .. This simply illustrates why you can't trust ATIS to give you anything more than a general sense of the conditions you might encounter. Winds change. ATIS stations sometimes see different wind conditions than the touchdown point, due to obstacles and wind direction. With an ATIS reading of a 20 degree off-centerline, and 10 knots of wind, I would fly a normal approach and make the corrections necessary to keep the airplane pointed straight down the runway with no drift during the flare and landing. I would not pre-suppose anything. On the other hand, if ATIS was indicating a 90 degree crosswind at 10 knots, and the smoke from chimneys, or waves on a nearby lake, or the windsock confirmed that information, I would *assume* that I had a noticeable crosswind to deal with, and would be mentally prepared for it... BUT, I'd still wait until final approach to crank in gross corrections to correct drift, and would apply whatever corrections were necessary in the flare to keep the airplane aligned and kill any drift. Bottom line.. ATIS gives you an indication of what the winds were at one point on the airfield at a given time. The conditions at your touchdown spot may be different. KB I agree with the other good responses in this thread and would only add that the ATIS is a periodic and not real time report that could IMHE be 1 or more hours old. I always want to confirm the ATIS by seeing the windsock and monitoring crab and drift on downwind, base and especially on final. Happy landings, |
On Sun, 20 May 2007 20:20:10 GMT, "Private"
wrote: I agree with the other good responses in this thread and would only add that the ATIS is a periodic and not real time report that could IMHE be 1 or more hours old. I always want to confirm the ATIS by seeing the windsock and monitoring crab and drift on downwind, base and especially on final. Along with all the good stuff that's been mentioned... If it's a towered field, simply say "Wind Check?" into the mic while turning final and the tower person will usually give you an instant reading like "330 @ 9, gusting 14". A double click of the mic button will confirm reception, no readback or callsign necessary. You don't need a callsign or any other info when asking, simply "Wind Check?", they'll know what it means. Both the ask and response are very quick and don't waste much radio time. Most of the non-towered fields I use have either an AWOS or ASOS (maybe Belfort? G), that updates every minute, but the same caveats apply about the location of the instrument taking the reading vs. the runway. |
In rec.aviation.student B A R R Y wrote:
Most of the non-towered fields I use have either an AWOS or ASOS (maybe Belfort? G), that updates every minute, but the same caveats apply about the location of the instrument taking the reading vs. the runway. Besides that, the wind can *change* between the time the reading is taken and the time you flare. I went up for some crosswind practice the other day, and the winds were really squirrelly -- changing constantly, and very different at altitude and on the ground. Every few minutes, somebody would key the mike to get a wind check from the local reporting station on the CTAF. Each time, the winds were noticeably different, both in direction and strength. It was kind of funny, and, while I paid attention, I didn't count on the information still being correct while I was landing. Each landing was different from the one before, and I had to pay attention to the winds each moment, and react to what they were doing there, not what they were reported to be. Which made it a lot of fun, of course. .... Alan -- Alan Gerber PP-ASEL gerber AT panix DOT com |
Alan Gerber wrote:
In rec.aviation.student B A R R Y wrote: Most of the non-towered fields I use have either an AWOS or ASOS (maybe Belfort? G), that updates every minute, but the same caveats apply about the location of the instrument taking the reading vs. the runway. Besides that, the wind can *change* between the time the reading is taken and the time you flare. Absolutely! Each landing was different from the one before That's the thing about landings. G |
directional gyro inlet filter | dlevy | Owning | 2 | October 9th 06 03:00 PM |
Is every touchdown a stall? | Mxsmanic | Piloting | 84 | October 4th 06 05:16 PM |
Directional Traffic System | Rich | Products | 3 | October 10th 05 10:04 AM |
Shipping damage to directional gyro? | Marv | Home Built | 2 | April 20th 05 01:34 PM |
FA:Directional Gyro 4000C-1 Autopilot Mitchell | Joel Stolarski | Aviation Marketplace | 0 | July 18th 04 06:43 AM |
