Mxsmanic wrote in
: Dudley Henriques writes: We had a Cessna 337 on our line for charter use at one time. It had a sync gauge. Strangely enough, whenever I had occasion to fly this bird I always ended up syncing the props by ear. You could easily feel if one of them was out even by a small amount of RPM. Logically the smallest differences would also be the most annoying, since they would result in such slow variations. And in theory you should be able to eliminate them by adjusting RPM manually. But since the Baron has a prop sync switch it occurred to me that perhaps the RPM levers aren't precise enough to make it easy to sync the props (?). I'm still not clear on whether or not this switch actually moves the prop levers or what. I know, send me $200 and I'll tell you fjukktard Bertie |
Bertie the Bunyip wrote:
I know, send me $200 and I'll tell you fjukktard Bertie Just be sure to spend it on some counselling, ok? |
Same here Dudley..
I have a "few " hours in a 310... I just set them manually, they stayed in sync very well I have 2500 hrs on the boat, no auto sync, although they make them. You engage it once the vessel is moving fwd in gear, then use one throttle (usually the Starboard) and the Port engine tracks the master.. The 1st sign of engine trouble is the engines going out of sync without any aparent reason... Cheers! Dave On Mon, 21 May 2007 22:46:39 -0400, "Dudley Henriques" wrote: "Dave" wrote in message .. . Yes... it can be REALLY irritating.. I have a twin engine boat, same issue... VERY annoying.. to me, and many others.. Some don't seem to mind.. (?) Not only the noise, but the vibrations , when out of sync, can be very annoying as well... Dave We had a Cessna 337 on our line for charter use at one time. It had a sync gauge. Strangely enough, whenever I had occasion to fly this bird I always ended up syncing the props by ear. You could easily feel if one of them was out even by a small amount of RPM. Dudley Henriques |
"Mxsmanic" wrote
I note that the Baron (and presumably other twins) has a prop sync switch that somehow synchronizes the prop speeds on both engines. From recordings I've heard of the interior noise of the aircraft, it does sound as though props that are just slightly out of sync can produce a very irritating intermittent noise as they move in and out of phase. Slightly out isn't as bad as way out IMO. One of our guys likes to fly with that wow-wow-wow-wow going on for hours and it drives me nuts when I'm the passenger. It's all I can do to prevent myself from reaching over and adjusting the props myself. Also, how does the prop sync work? Does it actually move pitch or throttle levers or something? In our aircraft there are pulse generators that monitor engine rpm and feed a computer. The computer directly controls the right engine prop governor. The system only works if the engines are already within 50 rpm of each other. Even then, the system can take up to a minute to sync the props - it's much easier and quicker to do it manually. Ours has never worked all that well and we really don't use it, or need it for that matter. BDS |
On 2007-05-22 05:53:03 -0700, "BDS" said:
Slightly out isn't as bad as way out IMO. One of our guys likes to fly with that wow-wow-wow-wow going on for hours and it drives me nuts when I'm the passenger. It's all I can do to prevent myself from reaching over and adjusting the props myself. Bob Stevens ("There I Was") tells the story of one Bedcheck Charlie during WW II "who could never sync his props." The irritating noise was considered even more obnoxious than the bombs he dropped, particularly since he also never hit anything. -- Waddling Eagle World Famous Flight Instructor |
Mxsmanic wrote in
: I note that the Baron (and presumably other twins) has a prop sync switch that somehow synchronizes the prop speeds on both engines. From recordings I've heard of the interior noise of the aircraft, it does sound as though props that are just slightly out of sync can produce a very irritating intermittent noise as they move in and out of phase. If you want to simulate that accurately, just talk while your's jerking off with your sim Berti e |
On May 22, 9:31 am, Bertie the Bunyip wrote:
Mxsmanic wrote : I note that the Baron (and presumably other twins) has a prop sync switch that somehow synchronizes the prop speeds on both engines. From recordings I've heard of the interior noise of the aircraft, it does sound as though props that are just slightly out of sync can produce a very irritating intermittent noise as they move in and out of phase. If you want to simulate that accurately, just talk while your's jerking off with your sim Berti e Perhaps you could drill a hole in your "English As A Third Language" textbook and hump the snot out of it. Leave it open so you might learn something in that 5 second interval betwixt engage-disengage-ment as you peer out the airport hotel window for a little (OH!) plane spotting. |
EatMe wrote in
ups.com: On May 22, 9:31 am, Bertie the Bunyip wrote: Mxsmanic wrote : I note that the Baron (and presumably other twins) has a prop sync switch that somehow synchronizes the prop speeds on both engines. From recordings I've heard of the interior noise of the aircraft, it does sound as though props that are just slightly out of sync can produce a very irritating intermittent noise as they move in and out of phase. If you want to simulate that accurately, just talk while your's jerking off with your sim Berti e Perhaps you could drill a hole in your "English As A Third Language" textbook and hump the snot out of it. Leave it open so you might learn something in that 5 second interval betwixt engage-disengage-ment as you peer out the airport hotel window for a little (OH!) plane spotting. Oh dear. someone is trying to **** me off. Well, could be fun.. Bertie |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets | Jim Macklin | Piloting | 26 | January 13th 07 12:06 AM |
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets | Jim Macklin | Instrument Flight Rules | 15 | January 13th 07 12:06 AM |
CompaqAero1530 sync question | Stewart Kissel | Soaring | 0 | February 21st 05 03:15 AM |
Prop noise vs. engine noise | Morgans | Piloting | 8 | December 24th 03 03:24 AM |
