Coordinated turns without rudder, and autopilots
Old May 29th 07, 10:53 PM posted to rec.aviation.piloting
Viperdoc[_3_]
Default Coordinated turns without rudder, and autopilots
The same is pretty much true for the F-16, at least from my less than 100
hours experience. It's usually feet on the floor, and the flight control
system works the various control surfaces..
Old May 29th 07, 11:17 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
"Denny" wrote in message
On the other hand however, in a T38, you can fly a complete aerobatic
sequence including point rolls with both feet planted firmly on the floor
of
the rudder tunnels.
Dudley Henriques- Hide quoted text -
- Show quoted text -
I've always wanted to fly a 38 but never had the opportunity...
My Super Viking was one of those few GA machines with adequate tail
volume that you could fly instrument approaches with your feet on the
floor... Conversely, you could fly the plane nicely without ailerons
just using that powerful rudder...
One of the little tricks I do when 'unbrain washing' the pilots I have
helped over the years, is to say to them that: "you have just snapped
the cables to the ailerons and the elevator... now fly me back to the
airport without touching the yoke!"... Some have been totally
helpless... A few have almost instantly figured it out.. And most need
only be shown how for a few seconds... The majority have been amazed
after they successfully herded the plane a dozen miles back to the
airport and it is gratifying to see the light bulb in their head
suddenly light up as they begin to understand how the controls
actually work...
denny
I agree with this technique completely and have used it myself when teaching
all through my career.
Dudley Henriques
Old May 29th 07, 03:35 AM posted to rec.aviation.piloting
Mxsmanic
Dan writes:
So where is this perfect airplane? I don't know about you, but I need
the rudder pedals to fly the aircraft.
But autopilots apparently do not, and that's what puzzles me.
Old May 29th 07, 07:14 PM posted to rec.aviation.piloting
Erik
Mxsmanic wrote:
Dan writes:
Autopilots in simulators do not. Actual (that's opposite of virtual)
light aircraft need a rudder. If you turn the yoke, the plane will
bank, turn and eventually become coordinated, but for a while in
the interim, you'll be flying uncoordinated.
Some of these differences are why I disregard anything you may say,
correct or not, because you don't understand the basics of actual
flight regardless of how much of a master h4xor you are in the
simulator.
Old May 29th 07, 07:33 PM posted to rec.aviation.piloting
Mxsmanic
Erik writes:
Autopilots on light aircraft do not, and I'd like to know why.
Old May 29th 07, 07:15 PM posted to rec.aviation.piloting
Erik
Mxsmanic wrote:
Dan writes:
Where the hell is Bertie.
Sorry about the troll thing, you were totally right.
Old May 29th 07, 09:32 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Erik wrote in news:135ore2nv2ugk87
@corp.supernews.com:
Mxsmanic wrote:
Dan writes:
need
I'm always right. You're forgiven. Your pennance is to bring me some
beer.
Bertie
Old May 29th 07, 08:51 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Dan writes:
Everything puzzles you fjukkwit, primarily because of your autistic
attitude.
Bertie
Old May 29th 07, 11:43 AM posted to rec.aviation.piloting
Ron Natalie
Get in most any aircraft. Take it to a normal cruise airspeed.
Put your feet flat on the floor and roll her into a standard rate
turn. I can almost guarantee the ball will be centered. It
would be a highly inefficient and impractical design if it
doesn't fly coordinated without rudder impact in that
regime.
Old May 29th 07, 07:34 PM posted to rec.aviation.piloting
Mxsmanic
Ron Natalie writes:
regime.
Then why would you ever need the rudder in a turn?
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 06:40 PM
DGs and Autopilots Andrew Gideon Products 11 April 14th 05 06:04 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 08:46 PM
