Coordinated turns without rudder, and autopilots
Old May 29th 07, 03:29 PM posted to rec.aviation.piloting
Paul kgyy
Default Coordinated turns without rudder, and autopilots
So in theory I should be able to turn myself with ailerons only in the same
way, without the need to use the rudder to stay coordinated. What's the
secret? Each time I try to turn at the same rate that the AP manages, I have
As Maxwell observes, this may just be a simulator limitation. In
actuality, a small amount of rudder should be applied when initiating
and recovering from a turn, but once in a constant bank turn, the
aircraft will normally be in coordinated flight without rudder
application.
Old May 29th 07, 07:38 PM posted to rec.aviation.piloting
Mxsmanic
Paul kgyy writes:
application.
But the autopilot has no control over the rudder, and yet the turn is
coordinated. What is it doing to make this possible?
Old May 29th 07, 09:02 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
Paul kgyy writes:
application.
Your mental condition, apparently.
Bertie
Old May 29th 07, 11:28 PM posted to rec.aviation.piloting
Maxwell
"Mxsmanic" wrote in message
Paul kgyy writes:
application.
Nothing, the turns are not perfectly coordinated, they don't have to be.
Old May 30th 07, 06:08 AM posted to rec.aviation.piloting
Mxsmanic
Maxwell writes:
The ball hardly moves. It moves a lot more if I attempt to roll into a turn
myself without using the rudder. Why?
Old May 30th 07, 06:20 AM posted to rec.aviation.piloting
Maxwell
Maxwell writes:
turn
HELLO!!! YOU'RE FLYING A DESK YOU MORON!!!!
Old May 30th 07, 01:11 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Maxwell writes:
be.
There's no ball, there's no ruddrr. there's no airplane, fjukkwit.
it's a computer..
Bertie
Old May 29th 07, 09:00 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Paul kgyy writes:
As others have posted, most lightplane autopilots don't adjust the
rudder for adverse yaw when turning, so you do get a few seconds of
slightly uncoordinated flight. However at normal cruise speeds this
creates no hazard or discomfort.
same way, without the need to use the rudder to stay coordinated.
What's the secret? Each time I try to turn at the same rate that the
AP manages, I have to use the rudder to stay coordinated.
If flying close to stall, the autopilot should be turned off even for
straight and level flight. If the airplane is on the verge of
stalling and starts to turn because of engine p-factor or any other
reason, the autopilot will attempt to correct with aileron. This may
actually induce stall on one wing, producing sudden wing drop and a
potential spin.
I have an aversion to stalls and I usually stay well away from them.
You're an idiot. You can't stall a computer, fjukkwit.
you can't fly a computer!
Asshole.
Bertie
Old May 29th 07, 09:50 PM posted to rec.aviation.piloting
Erik
Oh, I don't know about that, I bet he could.
Old May 29th 07, 09:49 PM posted to rec.aviation.piloting
Erik
That's your simulator.
Moron.
Either go out and do it, or stfu
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 06:40 PM
DGs and Autopilots Andrew Gideon Products 11 April 14th 05 06:04 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 08:46 PM
