![]() wrote It would be pointless as 100% alcohol would immediately start absorbing water from the air. In another post I said alcohol would absorb about 2-3% by volume. A web search gives numbers in the range of 2-4%. I'm not disagreeing with you. I do wonder what the water content of the pure alky is, the moment it comes out of production, though. -- Jim in NC |
In rec.aviation.owning Morgans wrote:
wrote It would be pointless as 100% alcohol would immediately start absorbing water from the air. In another post I said alcohol would absorb about 2-3% by volume. A web search gives numbers in the range of 2-4%. I'm not disagreeing with you. I do wonder what the water content of the pure alky is, the moment it comes out of production, though. Probably around 5-8%. Back in my college days I did "fermentation and chemistry experiments" and with half-way decent temperature control that's what you get. -- Jim Pennino Remove .spam.sux to reply. |
![]() "Morgans" wrote in message ... "Cubdriver" wrote Well, the alky presumably was shipped in full tanks / barrels / whatever, so we can hope it's undiluted. But, it is _very_ difficult (it takes some expensive chemistry tricks) to get all of the water distilled out of alcohol, in other words, stronger than around 98% alcohol. Is that all the alky producers go for, or do they use the expensive tricks to get the last two percentage points of water out of the alky? -- Jim in NC I don't know whether they do any initial distillation, to get to approximately the 60% (or 120 proof) level, but the rest is apparently now done by filtration through molecular sieves. The process is far less expensive than distillation and achieves about 99% purity. Various sources are offering a variety of grades of pure ethanol, up to 99.9%--although that does get expensive. Here is just one of the many links that I found with Google: http://www.alibaba.com/catalog/11549..._Grade_Bio_Eth anol.html Peter |
"Morgans" wrote: "Cubdriver" wrote Well, the alky presumably was shipped in full tanks / barrels / whatever, so we can hope it's undiluted. But, it is _very_ difficult (it takes some expensive chemistry tricks) to get all of the water distilled out of alcohol, in other words, stronger than around 98% alcohol. Is that all the alky producers go for, or do they use the expensive tricks to get the last two percentage points of water out of the alky? I doubt that they would go for the expensive tricks, since the alcohol will absorb moisture out of the air and from the bottom of the fuel tanks as soon as it contacts either. There is no point in trying for higher purity. |
On Sun, 3 Jun 2007 12:37:37 -0400, "Morgans"
wrote: But, it is _very_ difficult (it takes some expensive chemistry tricks) to get all of the water distilled out of alcohol, in other words, stronger than around 98% alcohol. I think that's correct. When I was a student in England years ago, we used to buy a liquor known as Polish White Spirits, which was 180 proof or 90 percent. The local wisdom (university students) held that anything stronger would promptly dilute itself back to 180 proof from water in the air (this was England, remember, very humid). Google tells me that one can buy 190 proof (95 percent) "Everclear" grain alcochol in British stores today. Blue skies! -- Dan Ford (Proof = the concentration of alcohol at which gunpowder soaked with it will still explode, or rather flash up. It was therefore called "proof", which later became 100 proof. It just happened to be 50 percent alcohol, so 200 proof is 100 percent. (More student wisdom.) (Wiki tells me that 100 proof is actually 49.28 percent alcohol BY WEIGHT. By volume, it's less, so the student wisdom is a bit shaky.) Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 forthcoming from HarperCollins www.flyingtigersbook.com |
On Jun 5, 12:22 pm, Cubdriver usenet AT danford DOT net wrote:
On Sun, 3 Jun 2007 12:37:37 -0400, "Morgans" wrote: But, it is _very_ difficult (it takes some expensive chemistry tricks) to get all of the water distilled out of alcohol, in other words, stronger than around 98% alcohol. I think that's correct. When I was a student in England years ago, we used to buy a liquor known as Polish White Spirits, which was 180 proof or 90 percent. The local wisdom (university students) held that anything stronger would promptly dilute itself back to 180 proof from water in the air (this was England, remember, very humid). Google tells me that one can buy 190 proof (95 percent) "Everclear" grain alcochol in British stores today. Blue skies! -- Dan Ford (Proof = the concentration of alcohol at which gunpowder soaked with it will still explode, or rather flash up. It was therefore called "proof", which later became 100 proof. It just happened to be 50 percent alcohol, so 200 proof is 100 percent. (More student wisdom.) (Wiki tells me that 100 proof is actually 49.28 percent alcohol BY WEIGHT. By volume, it's less, so the student wisdom is a bit shaky.) Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 forthcoming from HarperCollinswww.flyingtigersbook.com The only real difference between the 190 proof Everclear you refer to and the alcohol that is added to auto gas is that the alcohol to be added to auto fuel is "denatured". All this means is that it has been poisioned so that it is unfit for human consumption. This is usually done with natural gasoline and the regulations allow them to vary the amount they add to 3-5%. |
How can "pure gasoline" coming out of a 'supply depot' have the same 87 octane as the same "pure gasoline" mixed with
10% ethanol? Since all auto gasoline is coming from the same distribution pipes, what is the octane in those pipes? Folks have said that the various sellers have their own additive packages, and others have said that the ethanol is added near the point of use, and still others have indicated the ethanol is added to increase the octane rating. If all this is true, then the gas in hte pipes could be some low octane rating which is then boosted with ethanol to 87 octane for the pumps. That infers to me that even if you bought gas straight from the pipe it would not be 87 octane. Not good for STC holders... |
![]() "Blueskies" wrote in message t... How can "pure gasoline" coming out of a 'supply depot' have the same 87 octane as the same "pure gasoline" mixed with 10% ethanol? Since all auto gasoline is coming from the same distribution pipes, what is the octane in those pipes? IIRC, the octane rating is what it is measured at DELIVERY, not in the pipeline. Think (I think): Adjustments in the chemical composition at various points in the delivery system. |
![]() "Blueskies" wrote How can "pure gasoline" coming out of a 'supply depot' have the same 87 octane as the same "pure gasoline" mixed with 10% ethanol? Since all auto gasoline is coming from the same distribution pipes, what is the octane in those pipes? Folks have said that the various sellers have their own additive packages, and others have said that the ethanol is added near the point of use, and still others have indicated the ethanol is added to increase the octane rating. If all this is true, then the gas in hte pipes could be some low octane rating which is then boosted with ethanol to 87 octane for the pumps. That infers to me that even if you bought gas straight from the pipe it would not be 87 octane. Not good for STC holders... Not to worry. The pipeline people send many various grades of gas, all through the same pipeline. They may send 95 octane straight gas for 4 hours, then switch to 82 octane for 2 hours, and so on, with the right storage facilities along the way intercepting it, and putting it into separate tanks. I believe how they know how to switch over, is to first know how long the switch in types to get to them, then the senders put a dye package into the fuel to alert the storage and distribution people that it is time to switch some valves, and send the next fuel into a different tank. When the tanker comes to deliver the fuel to the gas station, they blend the correct amounts of each into the tank, and you get what you ordered. Specialty fuels may not travel the pipeline, but be shipped some distances by tanker truck, or barge. -- Jim in NC |
![]() MSNBC story about bad gas at a walmart in Louisville. The "regular" stuff turned out to be 80% water and some diesel??? http://www.msnbc.msn.com/id/18950569/ |
Gasohol | Blueskies | Piloting | 240 | July 6th 07 12:42 AM |
Gasohol | Blueskies | Owning | 233 | June 30th 07 03:50 AM |
How scary is gasohol? | Charles Talleyrand | Owning | 27 | March 1st 04 11:39 AM |
