On Sat, 2 Jun 2007 22:16:03 -0400, "Morgans"
wrote: How sure are we that the gasohol in service station tanks contain no water? I would never bet on it. Is it possible that all tanks containing gasohol contain at least some water dissolved? Extremely likely, from past experience (pumping gas decades ago) Is it a certainty that the alcohol added to gasoline contains no dissolved water? No. Definitely NOT a certainty. I don't know the answer to any of these questions. Does anyone know, for CERTAIN, any of these questions? My guess is that all service station tanks, (unless they have never had straight gas, and that they are BRAND NEW) have had an opportunity to get some water in their tanks. If that is the case, and you put gasohol in them, the gasohol samples will contain some dissolved water, and the seltzer test will work. If that is the case, doing a scientific test with clean gas and adding water free alcohol will prove nothing. Except you can NEVER say NEVER, and ALWAYS avoid ALWAYS. It is POSSIBLE you may GET totally dry gasohol. The probability that it will remain dry is slim.(alcohol is hygroscopic - it attracts and binds water) -- Posted via a free Usenet account from http://www.teranews.com |
"Morgans" writes:
How sure are we that the gasohol in service station tanks contain no water? I can assure you they will. When a pipeline delivers a tender [batch] of gasoline into storage tankage; they let it sit for a while, then drain the bottom of the tank ("water-draw") until they get gas... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
("David Lesher" wrote)
I can assure you they will. When a pipeline delivers a tender [batch] of gasoline into storage tankage; they let it sit for a while, then drain the bottom of the tank ("water-draw") until they get gas... At the Brewery (in the 80's) during beer changes, there were these sight glasses in the lines - at the valves. We'd flush out the line with water, watch the sight glass ...when we saw bubbles or a definite color change, we'd wait a few seconds then throw the valve. The water in the line was pumped out onto the floor, and/or "dumped" with a few spins of the bowl (a.k.a. the filler). Montblack |
Gasohol | Blueskies | Piloting | 240 | July 6th 07 12:42 AM |
Gasohol | Blueskies | Owning | 233 | June 30th 07 03:50 AM |
How scary is gasohol? | Charles Talleyrand | Owning | 27 | March 1st 04 11:39 AM |
