Gasohol
Old June 10th 07, 06:15 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Roger (K8RI)
Default Gasohol
On Sat, 9 Jun 2007 17:29:04 -0700, "Matt Barrow"
"Bob Noel" wrote in message
"Blueskies" wrote:
If this special clean gas w/o alcohol is brought to the airport and kept
there, doesn't it pretty much miss the point of
the autogas STC? The whole idea was to be able to use normal autogas in
these
old low compression engines.
I thought one objective was to avoid using the 100LL in engines that were
prune
to lead fouling.
Wouldn't prunes give them gas?
Although gas might be a byproduct, prunes are primarily an agent for
cleaning out all the old crap which should leave the engine nice and
clean on the inside.
Old June 11th 07, 03:37 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Matt Barrow[_4_]
Default Gasohol
"Roger (K8RI)" wrote in message
kept
these
were
prune
to lead fouling.
Yes, but would the gas be Mogas or 100LL?
Old June 12th 07, 07:43 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Roger (K8RI)
Default Gasohol
On Mon, 11 Jun 2007 07:37:45 -0700, "Matt Barrow"
kept
these
were
prune
to lead fouling.
Prunes are "nature's dynamite and will clean out old or new pipes
regardless of what you've been running though them. They add a bit of
color to the diet.
How scary is gasohol? Charles Talleyrand Owning 27 March 1st 04 11:39 AM
