Head orientation in turns--how is it taught for aviation?
Old June 11th 07, 01:40 AM posted to soc.culture.turkish,rec.aviation.piloting,alt.usenet.kooks,alt.fan.karl-malden.nose,soc.culture.british
Default Head orientation in turns--how is it taught for aviation?
There was a thread a while ago about how not only could one stay with
the force into the seat, but actually maintain 1 G straight into the
seat through a roll. If one is flying coordinated, keeping normal to
the airplane makes sense. Those how fly aerobatics have a different
set of criteria. For what it's worth, watching the in cockpit cameras
of some moderatedly skilled pilots, like the Blue Angels, shows them
"upright" with respect to the airplane except when G forces sling
their heads around, but they do fly coordinated most of the time.
But what do they know?
On Jun 10, 8:35 pm, Bertie the Bunyip wrote:
Mxsmanic wrote :
writes:
If the turn is coordinated, there is no "sideways" force to perceive
as that is the definition of a cooridinated turn.
False. The aircraft is being accelerated to one side.
Nope, wrong again, moron.
Bertie
Old June 11th 07, 12:24 PM posted to soc.culture.turkish,rec.aviation.piloting,alt.usenet.kooks,alt.fan.karl-malden.nose,soc.culture.british
Actually, with respect to maintaining one g into the seat and doing a
kind of roll, you can, or at least Newton says so, but I'm not sure
the airplane exists that has the control authority to do it. If you
search the groups you'll be able to find the analysis, but the short
form is this. The airplane has got to accelelerate downward at 1 G,
then pull a G in a coordinated bank. It'll roll, but it won't be
pretty, and the pilot will feel 1 G into the seat.
The diameter of the roll is something like 80 feet! Almost a snap
roll.
Think of it this way, and you'll be able to see how it works. If you
roll into a level bank, you'll feel increasing Gs. If, on the other
hand, you push over, you'll feel decreasing Gs. Somewhere between the
two, a coordinated bank and a push over, you'll be able to feel 1 G.
Give it a try a few times when you're flying aerobatics, and I'll bet
you can get to 45 or even 60 degrees of bank in a decending term with
your G meter locked at one before you run out of control authority.
On Jun 10, 8:52 pm, Bertie the Bunyip wrote:
wrote roups.com:
You can't.
set of criteria.
Nope, I fly aerobatics.
Quite well, too.
The criteria is the same, only the level of undrstanding changes.
Exactly. But fjukkwit won't buy it..
Bertie
Mxsmanic wrote
writes:
perceive as that is the definition of a cooridinated turn.
Bertie- Hide quoted text -
- Show quoted text -
Old June 11th 07, 03:41 AM posted to soc.culture.turkish,rec.aviation.piloting,alt.usenet.kooks,alt.fan.karl-malden.nose,soc.culture.british
Maxwell
That is either untrue, or real misleading. The Blues fly with a different
purpose, keep the aircraft on trajectory. When they are flying a knife edge,
they are hardly coordinated, as with many other maneuvers.
A 1g barrel roll can be done, but the required trajectory of the aircraft is
not going to be one that is necessarily eye pleasing for ground
demonstration purposes.
Old June 11th 07, 04:08 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
"Maxwell" wrote in
different purpose, keep the aircraft on trajectory. When they are
flying a knife edge, they are hardly coordinated, as with many other
maneuvers.
aircraft is not going to be one that is necessarily eye pleasing for
ground demonstration purposes.
Nope. the only thing you can do at 1 G is straight and level flight.
You can keep positive G around a barrel roll, but not 1 G
Bertie
Old June 11th 07, 06:23 AM posted to soc.culture.turkish,rec.aviation.piloting,alt.usenet.kooks,alt.fan.karl-malden.nose,soc.culture.british
Mxsmanic
Maxwell writes:
Any maneuver that involves a change in altitude will involve forces exceeding
1 G at some point.
Old June 12th 07, 12:43 AM posted to rec.aviation.piloting
Mxsmanic wrote in
Maxwell writes:
exceeding 1 G at some point.
Nope, wrong again fjukktard.
Bertie
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
CAP Orientation Pilot? Robert M. Gary Piloting 7 August 3rd 05 02:22 AM
ADV: AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium General Aviation 0 December 30th 03 11:37 AM
ADV: GREAT AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium Aviation Marketplace 0 December 30th 03 11:36 AM
sounds of aviation navigation equipment as head on a scanner radio Dan Jacobson Instrument Flight Rules 5 December 4th 03 07:27 PM
