Head orientation in turns--how is it taught for aviation?
Old June 11th 07, 11:54 PM posted to rec.aviation.student,rec.aviation.piloting
Snowbird
Default Head orientation in turns--how is it taught for aviation?
"Mxsmanic" wrote ...
In a coordinated turn, motorcycles move in two dimensions. They lean into
turns to keep the acceleration vector aligned with the center of gravity
and
the plane of the rear wheel.
Yep, you're right, they're identical.
Pretty much, in this context.
Disagree.
First, motorcycles don't necessarily move in two dimensions in a turn. They
are, however, bound to follow the road surface. Which may be flat.. or then
not.
Second, you might also want to ponder what the motorcycle driver vs. the
pilot is looking at.
Maybe the bike rider wants to look at the intended track of his bike on the
road, in order to spot any bumps. Or maybe he just wants to optimize his
turn to the available width of the road and looks at it more broadly. In
either case it would seem to make sense that the rider's sight perception
improves, if he tilts his eyes more parallel to the road.
The pilot, on the other hand, does not look at any road ahead. He's
interested in the nose vs. horizon sight picture as well as the instruments.
That's a different case and it's not self-evident that tilting the head
parallel to the horizon would improve the pilot's turn performance. On the
contrary, especially if the pilot uses the VSI and altimeter to maintain
altitude, it's probably easier to read them with the eyes level relative to
the instrument panel.
Third, it just might be possible that the pilot's stereoscopic vision can
better help him maintain altitude in the turn by visual cues, if he keeps
his head still. When the airplane banks, part of his stereoscopic ability
is transferred to the vertical direction, which may improve his sensing of
climb/descent changes. Whereas the bike driver has no need to be able to
sense movement in the vertical plane, as he is bound to the road surface
anyway.
Fourth, a bike rider leans forward, while a pilot leans back in his seat.
Can have impact on how the head turns in a turn.
I'm not aware of scientific proof of the above, but neither of the reverse.
So until the opposite is credibly shown, I'll contend that a motorcycle is
different from an airplane.
Old June 12th 07, 06:41 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Snowbird writes:
Neither do aircraft.
The driver of any vehicle needs to look where the vehicle is going.
No, that results in target fixation, and accidents.
Motorcycle riders look where they want to go, just like pilots.
This is a VFR pilot?
his head still.
Stereoscopic vision ceases to be a factor beyond around 10 metres, so it is
never important in the air--which is why full-motion simulators use
collimation to make everything seem infinitely far away, without bothering to
simulate 3D.
I was taught not to lean in any direction that isn't aligned with the bike.
Different in many ways, but very much the same in turns.
Old June 12th 07, 03:58 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
news
Snowbird writes:
turn.
the pilot is looking at.
on the road, in order to spot any bumps.
In either case it would seem to make sense that the rider's sight
perception improves, if he tilts his eyes more parallel to the road.
instruments. That's a different case and it's not self-evident that
tilting the head parallel to the horizon would improve the pilot's
turn performance. On the contrary, especially if the pilot uses the
VSI and altimeter to maintain altitude, it's probably easier to read
them with the eyes level relative to the instrument panel.
can better help him maintain altitude in the turn by visual cues, if
he keeps his head still.
it is never important in the air--which is why full-motion simulators
use collimation to make everything seem infinitely far away, without
bothering to simulate 3D.
seat. Can have impact on how the head turns in a turn.
bike.
That's because your instructor was stuck with an idiot
We frequently use little zen things like that to keep the student from
doing something stupid. Mostly out of desperation when al else fails.
Bertie
Old June 12th 07, 03:59 PM posted to rec.aviation.piloting
Mxsmanic wrote in
news
Snowbird writes:
turn.
bike.
reverse. So until the opposite is credibly shown, I'll contend that a
motorcycle is different from an airplane.
You're an idiot.
Talking to another idiot.
Bertie
Old June 12th 07, 10:23 PM posted to rec.aviation.student,rec.aviation.piloting
Snowbird
"Mxsmanic" wrote ....
Snowbird writes:
That was never the issue. An aircraft can control its altitude in a turn,
but a motorcycle must follow any ups and downs in the road.
But the motorcycle rider does not need to, and indeed can not, have control
in the vertical dimension. Consequently he has no need to look at visual
cues affecting the vertical dimension. The pilot, on the contrary, has.
Failure to notice bumps, potholes, or sand on the intended track causes
accidents.
Ever seen a motorcyclist turning onto a compass course?
instruments.
to
This is not about simulator games.
his head still.
is
to
simulate 3D.
The nose of the airplane is hardly 10 metres away.
bike.
So what?
reverse.
is
You're entitled to your opinion, even if it sucks. Both need about the same
bank angle, but the similarity ends there.
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
CAP Orientation Pilot? Robert M. Gary Piloting 7 August 3rd 05 02:22 AM
ADV: AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium General Aviation 0 December 30th 03 11:37 AM
ADV: GREAT AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium Aviation Marketplace 0 December 30th 03 11:36 AM
sounds of aviation navigation equipment as head on a scanner radio Dan Jacobson Instrument Flight Rules 5 December 4th 03 07:27 PM
