Why?
mike "Mxsmanic" wrote in message ... If it is equal to 1.0 G (which would be quite a feat), |
mike regish writes:
Why? It's hard to maintain a downward acceleration of 1 G in any aircraft, especially a small, non-aerobatic aircraft. |
Mxsmanic wrote in
: mike regish writes: Why? It's hard to maintain a downward acceleration of 1 G in any aircraft, especially a small, non-aerobatic aircraft. How would you know, fjukkwit, you don't fly. Bertie |
Didn't say anything about maintaining it. It is easy to attain zero g in an
airplane. And if you start out with a steep climb, you can sustain zero g for several seconds easily. I know because I do it all the time. My kids love watching their soda bottles floating up in front of them. mike "Mxsmanic" wrote in message ... mike regish writes: Why? It's hard to maintain a downward acceleration of 1 G in any aircraft, especially a small, non-aerobatic aircraft. |
On Jun 14, 9:39 pm, "mike regish" wrote:
Didn't say anything about maintaining it. It is easy to attain zero g in an airplane. And if you start out with a steep climb, you can sustain zero g for several seconds easily. I know because I do it all the time. My kids love watching their soda bottles floating up in front of them. I used to move an item from one side of the cockpit to the other and back and forward just to impress the pax.. Then on the ground I'd drop the item just to show pax the speed we were descending at at the time ... |
Dave Doe wrote:
To put it another way, if you closed your eyes, you wouldn't know you've done a roll (given you go for the 'non-standard' 1G roll), other than the initial sensation of beginning the turn, and then the sensation of the turn stopping. Not sure exactly where you are with this, but as what you are saying pertains to barrel rolls begun from level flight or from a position with the nose below the horizon, don't forget that the entire gist of the misunderstanding that has been running rampant on this thread about barrel rolls and doing them at 1 positive g can be centered and completely focused on the fact that it's the ENTRY and the EXIT of the roll, and how these two factors interplay into the roll itself that is causing all the confusion. The one factor that can't be taken out of the barrel roll scenario is that no matter how you cut it, if PITCH is a factor in a barrel roll, there will be an indication on a g meter above 1 g as that pitch change is being made. In a normal barrel roll you have pitch change as the nose transverses the roll in it's helical path. If a barrel roll requires the nose of the aircraft to be above the horizon during the entry and then again brought back to the horizon during the recovery (as it does) you will absolutely be showing more than 1 positive g on the g meter during the roll, and if it's a retaining double needle g meter, after the roll when you bring the airplane home........period! This is a fact of life. As soon as the aircraft's nose shows a positive nose rate in PITCH as it's raised during the roll entry and then again during the recovery as it's raised again to level flight, that g meter will leave 1 and show more than 1 positive g. Now here is the part that is causing all the confusion. ONCE the nose has been raised above the horizon (and that over 1 g has been registered on the g meter) as you feed in aileron you can PLAY WITH THE BACK PRESSURE being applied and EASE OFF the positive g to a LOWER LEVEL if desired over the top of the roll, but that level can't be unloaded below 1 g or the arc of the roll will be destroyed. It's the COMBINATION of roll and pitch that is producing the roll arc and those TWO pressures MUST be maintained to produce the roll. So the bottom line is simply that to do a barrel roll where the nose must be both above and below the horizon line starting from level flight you need over 1 g during the entry and exit, but you can reduce the g to 1 through the top of the roll if desired. Dudley Henriques |
I don't know how anyone can make it more clear than that. If you don't
believe this, you have never done barrel rolls and should do so, with appropriate plane and instructor, before saying any more. Dudley Henriques wrote: Not sure exactly where you are with this, but as what you are saying pertains to barrel rolls begun from level flight or from a position with the nose below the horizon, don't forget that the entire gist of the misunderstanding that has been running rampant on this thread about barrel rolls and doing them at 1 positive g can be centered and completely focused on the fact that it's the ENTRY and the EXIT of the roll, and how these two factors interplay into the roll itself that is causing all the confusion. The one factor that can't be taken out of the barrel roll scenario is that no matter how you cut it, if PITCH is a factor in a barrel roll, there will be an indication on a g meter above 1 g as that pitch change is being made. In a normal barrel roll you have pitch change as the nose transverses the roll in it's helical path. If a barrel roll requires the nose of the aircraft to be above the horizon during the entry and then again brought back to the horizon during the recovery (as it does) you will absolutely be showing more than 1 positive g on the g meter during the roll, and if it's a retaining double needle g meter, after the roll when you bring the airplane home........period! This is a fact of life. As soon as the aircraft's nose shows a positive nose rate in PITCH as it's raised during the roll entry and then again during the recovery as it's raised again to level flight, that g meter will leave 1 and show more than 1 positive g. Now here is the part that is causing all the confusion. ONCE the nose has been raised above the horizon (and that over 1 g has been registered on the g meter) as you feed in aileron you can PLAY WITH THE BACK PRESSURE being applied and EASE OFF the positive g to a LOWER LEVEL if desired over the top of the roll, but that level can't be unloaded below 1 g or the arc of the roll will be destroyed. It's the COMBINATION of roll and pitch that is producing the roll arc and those TWO pressures MUST be maintained to produce the roll. So the bottom line is simply that to do a barrel roll where the nose must be both above and below the horizon line starting from level flight you need over 1 g during the entry and exit, but you can reduce the g to 1 through the top of the roll if desired. Dudley Henriques |
Dispelling the Myth: Hillary Clinton and the Purple Heart | Otis Willie | Naval Aviation | 0 | February 21st 06 05:41 AM |
Impossible to ditch in a field (almost) | mindenpilot | Piloting | 29 | December 11th 04 11:45 PM |
bush: impossible to be AWOL (do vets give a sh!t) | B2431 | Military Aviation | 7 | September 8th 04 04:20 PM |
cheap, durable, homebuilt aircrafts- myth or truth? | -=:|SAJAN|:=- | Home Built | 27 | January 8th 04 09:05 AM |
The myth that won't die. | Roger Long | Piloting | 7 | December 19th 03 06:15 PM |
