Myth: 1 G barrel rolls are impossible.
  #11
Old June 16th 07, 04:30 PM posted to rec.aviation.piloting,rec.aviation.student
Jose
Default Myth: 1 G barrel rolls are impossible.
Well, MX, consider the case of a ballistic track that starts off with
an initial vertical velocity that is less than escape velocity.
Up, then down, until it hits what someone so nicely described as 'the
hard edge of the sky". Is your assertion that is orbital?
Suppose that, as the rock was passing through the soft part of the sky
(we neglect air friction because this is powered freefall flight), the
earth shrunk to the size of a walnut. The flight path would stay the
same, and orbit the walnut.
Escape velocity is the velocity required to escape the earth's
gravitational field (go up and not come down at all). What we call
"orbital velocity" is the velocity required to remain in a circular
orbit around the earth, at an altitude of about four thousand miles
above the earth's center. At the apogee of a sufficiently elliptical
orbit, the actual velocity can be arbitrarily small.
Jose
You can choose whom to befriend, but you cannot choose whom to love.
Dispelling the Myth: Hillary Clinton and the Purple Heart Otis Willie Naval Aviation 0 February 21st 06 05:41 AM
Impossible to ditch in a field (almost) mindenpilot Piloting 29 December 11th 04 11:45 PM
bush: impossible to be AWOL (do vets give a sh!t) B2431 Military Aviation 7 September 8th 04 04:20 PM
cheap, durable, homebuilt aircrafts- myth or truth? -=:|SAJAN|:=- Home Built 27 January 8th 04 09:05 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 06:15 PM
