Air Compressor Horsepower/Wattage/Amperage
Old June 20th 07, 10:17 PM posted to rec.aviation.homebuilt
RST Engineering
Default Air Compressor Horsepower/Wattage/Amperage
Good Lord, starting current of 64 amps at 115 volts? Most 15 amp breakers
would pop in half a second at 400% overload; how do these little one horse
compressors plug into a 15 amp circuit and start so easily? It is just when
you don't have nearly infinite current available from house mains and you
start fooling with generators that the situation becomes sticky.
Lessee now, lets go to the 100% (one horse) column and we find at 115 volts
a PF of 79, 66% efficiency, and 15.4 line amps. One horse is 750 watts and
at the one horse level this rascal is sucking 1770 watts, or an efficiency
of 42%. But the table shows a 66% efficiency. Hmmm ... cos (79°) = .2 but
that factor of out of phase isn't going to get me into the ballpark, nor is
the sin at .98 going to get me anywhere either.
Hmmmm ...
"Dream as if you'll live forever. Live as if you'll die today."
--James Dean
"GeorgeB" wrote in message
On Tue, 19 Jun 2007 21:09:51 -0700, "RST Engineering"
Load Characteristics at 230 V, 60 Hz , 1 HP
% of Rated Load 25 50 75 100 125 150
S.F.
Power Factor 37 52 64 72 79 83 76
Efficiency 43.4 58.2 64 66 65.8 63.7 65.9
Speed (rpm) 1782 1766 1749 1729 1706 1676 1715
Line Amperes 4.9 5.3 5.9 6.7 7.7 9.1 7.3
ASSUMING 100 psi is 90% load, mayne 6.5A on 230. Restart at 80psi, if
compressor is properly designed, will be no worse than 0 psi start,
ie, it starts briefly unloaded. (It won't draw any more current in
any event, but the starting time would be extended)
Old June 20th 07, 10:43 PM posted to rec.aviation.homebuilt
of 42%. But the table shows a 66% efficiency. Hmmm ... cos (79°) = ..2 but
It's them dadgummed vodoo phased lectrons with them giant p states
that are
casuing you the problems Jim. Just remember that all a tech cares
about is that
missing volt, the guy with the BS. is chasing the extra milliamp, the
MS guy is
putzing with the missing microvolt and the PhD is still trying to
figure out where that
extra electron came from....
Craig C.
Old June 20th 07, 11:06 PM posted to rec.aviation.homebuilt
Those little one-horse compressors that run on a 15-amp
circuit probably aren't really one horsepower as we know it. More
marketing hype. They might be basing the 1-hp thing on starting
current or some similar sleight-of-hand.
Dan
Old June 20th 07, 11:25 PM posted to rec.aviation.homebuilt
cavelamb himself
Ya know, it's funny - ( he said, changing subjects abruptly).
I have a Hobart 135 wire welder set up for 120VAC.
At 120 VAC the placard calls for 20 amps.
It had a dedicated 30 amp breaker for it in my shop.
Sweet machine.
But here in the garage of this house there is only one plug.
And it's on a 15 amp breaker.
Trying to tack some 1/4" steel brackets together was about the most
frustrating welding experience of all times.
Just about the time the puddle going nice - the breaker tripped.
The tacks were very "tacky" - down right sloppy looking in fact.
I real quick gave up and went down to the Tractor Supply and got a
heavy duty (30 amp) twenty foot extension cord and plugged into the
dryer circuit.
The Hobart was back to it's sweet personality again.
At least the welder rating is right...
But my 6 HP shop vac can't blow that breaker even if it wanted to.
Old June 21st 07, 12:36 AM posted to rec.aviation.homebuilt
Blueskies
Maybe try to find some info air conditioners for RVs that run off generators...
FWIW, do you have a compressor you can instrument?
I'm not a motor guy, but the inrush will always be high until the back emf stabilizes things. I would imagine the
limited source from the generator would only slow down the start, and if the motor turns at all it should get up to
synchronous speed. How much it would overheat due to the low voltage brown out is another issue...
"RST Engineering" wrote in message ...
Good Lord, starting current of 64 amps at 115 volts? Most 15 amp breakers would pop in half a second at 400%
overload; how do these little one horse compressors plug into a 15 amp circuit and start so easily? It is just when
you don't have nearly infinite current available from house mains and you start fooling with generators that the
Lessee now, lets go to the 100% (one horse) column and we find at 115 volts a PF of 79, 66% efficiency, and 15.4 line
amps. One horse is 750 watts and at the one horse level this rascal is sucking 1770 watts, or an efficiency of 42%.
But the table shows a 66% efficiency. Hmmm ... cos (79°) = .2 but that factor of out of phase isn't going to get me
into the ballpark, nor is the sin at .98 going to get me anywhere either.
Hmmmm ...
--James Dean
"GeorgeB" wrote in message ...
S.F.
Old June 21st 07, 03:46 PM posted to rec.aviation.homebuilt
GeorgeB
On Wed, 20 Jun 2007 14:17:58 -0700, "RST Engineering"
If you go to Baldor's website and look at this motor (and the 3600RPM
is different), you'll note that this 1HP will acutally supply 2HP and
not stall ...
that's 1770 VA, not watts ... watts will be that times PF (already the
cos of phase angle applied) gives 1400 watts ... which my pea brain
shows as a hair under 54% ... not the 66% they show.
I work with 3 phase motors, and have found the calculations to be
better ... wonder where the extra power is?
0.79 is cos(38 degrees)
Hmmmm ...
I agree that the data doesn't fit itself ... but it was a copy/paste,
not hand entered, so I didn't check carefully.
If you got a store bought 1HP compressor, I'd bet ti would have a more
accurately defined 0.5HP unit ... see following ... at 100% the
numbers check out ... 3.9A*230V*0.69*0.607=375W ...
Product Nameplate Data :
Rated Output .5 HP Hertz 60 NEMA Nom. Eff. 57
Volts 115/230 Phase 1 Power Factor 71
Full Load Amps 7.4/3.7 NEMA Design Code N Service
Factor 1.25
Speed 3450 LR KVA Code K Rating - Duty 40C AMB-CONT
(Typical performance - Not guaranteed values)
General Characterstics at 230 V, 60 Hz, 0.5 HP
Full Load Torque 0.75 LB-FT Starting Current 18.5
Amps
Start Configuration DOL No-Load Current 2.95 Amps
Break Down Torque 2 LB-FT Line-line Resistance @ 25° C
4.72 Ohms
Pull-Up Torque 1.6 LB-FT Temperature Rise, C @ FL (in deg) 78
Locked-Roter Torque 3 LB-FT Temp. Rise @ S.F. Load (in
deg) 92
Load Characteristics at 230 V, 60 Hz , 0.5 HP
S.F.
Power Factor 39 49 61 69 74 78 74
Efficiency 38.3 49.7 57.4 60.7 60.9 59.8 60.9
Speed (rpm) 3530 3490 3450 3420 3380 3340 3380
Line Amperes 3 3.2 3.5 3.9 4.4 4.95 4.4
Old June 21st 07, 04:07 PM posted to rec.aviation.homebuilt
GeorgeB
I think you slipped a column ...
100% 13.4A (115V), 0.66 eff, 0.72 PF ... 732 watts
Hmmmm ...
Air Compressor Horsepower/Wattage/Amperage RST Engineering Owning 32 June 30th 07 12:47 AM
more horsepower T-Bone Piloting 11 March 20th 06 10:56 PM
Lycoming Horsepower Calculation? Mark Doble Home Built 1 June 20th 05 10:46 PM
Thermals and Horsepower Ken Kochanski (KK) Soaring 14 January 9th 05 05:50 PM
Horsepower Andre Home Built 3 July 18th 03 10:50 AM
