One item the course taught me was a Modified Wingover which allowed a blind
canyon 180* turn within a wingspan. Impossible. vince norris |
after the instructor said it would be within a wingspan, it sure seemed that
way to this old man G. "vincent norris" wrote in message ... One item the course taught me was a Modified Wingover which allowed a blind canyon 180* turn within a wingspan. Impossible. vince norris |
Dick wrote:
after the instructor said it would be within a wingspan, it sure seemed that way to this old man G. I recall, now, an airplane that can change heading by 180 degrees within one wingspan. It is a DC-3 that is mounted on a pedestal at Whitehorse, Yukon, airport. It is on a support that permits it to windcock, and it does, even in a slight breeze. And it needs no more space that one wingspan to do a 180 or even a 360! vince norris |
Turns is a wingspan? We could do a Bill Clinton here, depends on what
you mean by 'wingspan'. Or whose wingspan. Just how tight a non-aerobatic turn can you do in a training airplane like a 152? On Jun 26, 12:21 am, vincent norris wrote: Dick wrote: after the instructor said it would be within a wingspan, it sure seemed that way to this old man G. I recall, now, an airplane that can change heading by 180 degrees within one wingspan. It is a DC-3 that is mounted on a pedestal at Whitehorse, Yukon, airport. It is on a support that permits it to windcock, and it does, even in a slight breeze. And it needs no more space that one wingspan to do a 180 or even a 360! vince norris |
Opps -- asked a question that I could have checked on myself.
looks like a 60 degree bank and 60 MPH would result in a turn diameter a bit under 300 feet (no wind etc) |
the plane was a French CAP 10 acrobatic plane
wrote in message oups.com... Turns is a wingspan? We could do a Bill Clinton here, depends on what you mean by 'wingspan'. Or whose wingspan. Just how tight a non-aerobatic turn can you do in a training airplane like a 152? On Jun 26, 12:21 am, vincent norris wrote: Dick wrote: after the instructor said it would be within a wingspan, it sure seemed that way to this old man G. I recall, now, an airplane that can change heading by 180 degrees within one wingspan. It is a DC-3 that is mounted on a pedestal at Whitehorse, Yukon, airport. It is on a support that permits it to windcock, and it does, even in a slight breeze. And it needs no more space that one wingspan to do a 180 or even a 360! vince norris |
![]() tbaker27705 wrote Just how tight a non-aerobatic turn can you do in a training airplane like a 152? If it were my butt about to run into a cumulogranite, it would matter not, what the rating of the aircraft was. -- Jim in NC |
On 2007-06-24 10:51:51 -0400, "Dick" said:
After taking some rigorous Unusual Attitudes Training, now I can't do a smooth Lazy Eight to save my soul G (or comfort my wife). One item the course taught me was a Modified Wingover which allowed a blind canyon 180* turn within a wingspan. Only way to do this would be a Hammerhead, and a Hammerhead done perfectly as well :-) Unfortunately after I look left over the wing to line up with the entry point and initiate first pitch/bank, I'm then at the 90* point and still too fast..... Advice please. Thanks, Dick Hi Dick; I won't get into the mechanics on Lazy 8's as there are literally hundreds of competent sources available and I'm sure you have already read them. Procedure is only part of the equation when it comes to doing a good Lazy 8. Contrary to what some might think, doing a good Lazy 8 within specific parameters is actually not as easy as it might seem. In fact, as an aerobatic instructor, I'll have even a competent acro pilot demonstrate a good Lazy 8 to me before moving on into the "good stuff" :-) The key to doing good Lazy 8's is control coordination and feel. You are dealing directly with an ever changing dynamic in a Lazy 8. This means that your aircraft's altitude, attitude, airspeed, and heading are all in constant flux as you execute the maneuver. There's a lot more involved than simply being at the right point in space at the right time, altitude, and angle of bank. All these things are changing as far as control response goes as the maneuver progresses. As airspeed decreases, you will need to alter the angle of bank to compensate. Same for increasing airspeed. All the while this is going on, you have to be watching your heading change along the arc of the maneuver. What I do with acro students having trouble with Lazy 8's is to have them concentrate on doing a good wingover first. This way, they can concentrate on the 90 degree reference point, the 45 degree point and the 135 degree point on one side only at a time. When you can consistantly perform good wingovers to one side, then the other, you should then put them together and do Lazy 8's. Basically, you are dealing with pitch and bank and what you have to do with varying control pressures with BOTH these parameters to achieve the desired result. Try practicing a single wingover to one side. Let the airplane tell you what you are doing wrong. In aerobatics, (yes, I know the definition as relates to Lazy 8's :-) the airplane will teach you every time you try to perform a maneuver what you are doing wrong. What YOU have to do is WATCH for the difference between what you wanted the airplane to do and what it actually did do based on the control input you provided. In a Lazy 8, if you are early or late at a reference point, you are either early or late in pitch or roll. Ask yourself what you have to change in control input; then try it again with that change. Don't overtask on reference points. Learn where you lose and regain your visual cues vs your reference points vs your high or low wing and compensate for that. Basically what you are looking for is smooth fluid unhurried continious control pressures throughout a Lazy 8. As I said, contrary to what some might say, a pilot who can perform a good Lazy 8 is a pilot who has taken the time to become proficient in the basics, and in all of flying, there is nothing more desirable in a pilot then being someone who can execute based on a well rounded comprehension of the basics. Dudley Henriques |
On 2007-06-24 19:35:43 -0700, Dudley Henriques said:
What I do with acro students having trouble with Lazy 8's is to have them concentrate on doing a good wingover first. This way, they can concentrate on the 90 degree reference point, the 45 degree point and the 135 degree point on one side only at a time. When you can consistantly perform good wingovers to one side, then the other, you should then put them together and do Lazy 8's. Basically, you are dealing with pitch and bank and what you have to do with varying control pressures with BOTH these parameters to achieve the desired result. Dudley, I am not sure I understand this as a teaching technique for a Lazy Eight. You get examiners who complain that people doing Lazy Eights are actually doing Wingovers instead of Lazy Eights. You see comments like this, for example, in Ken Medley's article on the AOPA web site: "Examiners complain that many applicants actually do wingovers when they think they are doing lazy eights. A wingover is a good, easy aerobatic maneuver, but it isn't a lazy eight. In lazy eights you fly the airplane throughout. In wingovers, you slip the airplane during the turnaround. For lazy eights, fly the airplane throughout the turns - no slipping - and be sure to allow for torque." -- Waddling Eagle World Famous Flight Instructor |
![]() C J Campbell wrote: In wingovers, you slip the airplane during the turnaround. For lazy eights, fly the airplane throughout the turns - no slipping - and be sure to allow for torque." You are saying that a wingover is not coordinated, but it is. |
Somebody Terrified of Compound Curves ---- Or Just Lazy | Larry Smith | Home Built | 8 | October 31st 03 02:40 PM |
"Lazy Dogs" | Mike Yared | Naval Aviation | 1 | August 15th 03 06:00 PM |
