I wonder what the ETA would be like with the Genesis
fuselage. Maybe a bit like this... http://tinyurl.com/yuqb7v |
Funny! Well done.
Paul Remde "Colin Field" wrote in message ... I wonder what the ETA would be like with the Genesis fuselage. Maybe a bit like this... http://tinyurl.com/yuqb7v |
At 17:42 06 July 2007, Bumper wrote:
'Bill Daniels' wrote in message (really important stuff snipped) The Genesis 'T' tail is actually a hindrance. Bill Daniels I bet not nearly the 'hindrance' as would occur if you attempt to fly the Genesis without that horizontal stab. bumper I don't agree that the Genesis elevator on the tail is a hindrance. Like everything else in engineering it is a trade off. Putting the all-flying elevator on a 'T' tail keeps it out of ground effect so the control feel is the same during landing as during flight. The moment arm of the Genesis elevator allowed the designers to move the cockpit forward so the pilots head is in front of the wing leading edge giving much better visibility than would occur if the pilot has to sit on the cg. The chord at the wing root on the Genesis is quite large but the trailing edge is just as robust as the rest of the glider so handling the 140 Lb. wing isn't a problem. With a large elevator at the trailing edge there could be an assembly/disassembly issue. Would it be separately removable or fixed to the wing? The elevator on the Genesis weighs less than 10 Lbs. and is short enough that you can stick it under your arm or carry it off with one hand. The Genesis has a cockpit large enough for a 6'10' 255 Lb. pilot to move around in. I think just the size of it is as great a 'hindrance' to performance as any other trade off. |
6'10'? 255lbs? What are the load limits for this
glider? At 05:12 11 July 2007, Steve Davis wrote: At 17:42 06 July 2007, Bumper wrote: 'Bill Daniels' wrote in message (really important stuff snipped) The Genesis 'T' tail is actually a hindrance. Bill Daniels I bet not nearly the 'hindrance' as would occur if you attempt to fly the Genesis without that horizontal stab. bumper I don't agree that the Genesis elevator on the tail is a hindrance. Like everything else in engineering it is a trade off. Putting the all-flying elevator on a 'T' tail keeps it out of ground effect so the control feel is the same during landing as during flight. The moment arm of the Genesis elevator allowed the designers to move the cockpit forward so the pilots head is in front of the wing leading edge giving much better visibility than would occur if the pilot has to sit on the cg. The chord at the wing root on the Genesis is quite large but the trailing edge is just as robust as the rest of the glider so handling the 140 Lb. wing isn't a problem. With a large elevator at the trailing edge there could be an assembly/disassembly issue. Would it be separately removable or fixed to the wing? The elevator on the Genesis weighs less than 10 Lbs. and is short enough that you can stick it under your arm or carry it off with one hand. The Genesis has a cockpit large enough for a 6'10' 255 Lb. pilot to move around in. I think just the size of it is as great a 'hindrance' to performance as any other trade off. |
Nyal Williams wrote:
6'10'? 255lbs? What are the load limits for this glider? The Sailplane Directory gives 298 kg (!) and shows no provision for water ballast, so presumably that's all pilot. This seems a bit unlikely; can it be right? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
At 06:06 11 July 2007, Nyal Williams wrote:
6'10'? 255lbs? What are the load limits for this glider? Genesis Flight Manual, Section 2.9 The Genesis 2 glider is a single seat aircraft. Unless lead trim weights are used the cockpit load is limited to the following range: 154 lbs. to 242 lbs. (70 kg to 110 kg) While also staying within the other parameters, Max. TO weight without water ballast: 807 lbs., Max. weight of all non-lifting parts: 531 lbs., you could get up to 255 - 260. Still, the Genesis 2 wing, assuming a 310 lb. load (260 pilot and 50 gear), was tested to 19g. before breaking. There was discussion that perhaps the test fixture failed, concentrating the force and causing the wing to snap. I can imagine that, given the unique shape of the Genesis wing and the fact that most glider wings will fail at 10 to 12g, rolling or twisting forces could have occurred causing the spar to break at 'only' 19g. Perhaps that explains why the Genesis 2 in the video had no damage to the wing. |
The Genesis 2 can hold 26 gal. of water in each wing.
Max. TO weight with water ballast is 1157 lbs. (525kg) At 14:06 11 July 2007, Martin Gregorie wrote: Nyal Williams wrote: 6'10'? 255lbs? What are the load limits for this glider? The Sailplane Directory gives 298 kg (!) and shows no provision for water ballast, so presumably that's all pilot. This seems a bit unlikely; can it be right? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
youtube gliding videos | Mal[_3_] | Soaring | 3 | March 17th 07 04:55 AM |
The Holy Shroud | Acrux | Piloting | 3 | September 29th 06 02:16 AM |
Holy $#$ - eBay Copter | Jimbob | Home Built | 37 | September 13th 05 10:58 PM |
