Bill Daniels wrote:
Just idle fun speculation, of course. Clearly, a conventional rudder like the Genesis wouldn't work with a 31 meter span. But, it would take only a tiny amount of drag at the wing tip acting through a 15 meter moment arm to produce huge yaw moments. I've run this calculation a few times and the net drag of tip drag rudders would acutally be less than a conventional rudder. A trailing edge elevator would work fine regardless of the span. The Genesis "T" tail is actually a hinderance. Now a portion of the wing is not working at the optimum flap setting. I think that the drag would be significant. The Genesis optimization problem is quite different, as is a conventional Standard Class glider optimization compared to a 15 Meter class glider. Note how different the wing designs tend to be for Standard vs 15 Meter gliders (generally lower aspect ratio/larger area for the Standard class). As for the control moments to control engine thrust and "P" factors, yes, that is a challenge. A few prople have suggested lowering the thrust line so it passes through the CG and aerodynamic center. The rear propeler could fold back somewhat like a Carat and be pulled into a tube in the rear fuselage. Not sure how the landing gear would work with a low thrust line. Perhaps using a jet would make the problem much easier; at least, the thrust could be closer to the center line. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
youtube gliding videos | Mal[_3_] | Soaring | 3 | March 17th 07 04:55 AM |
The Holy Shroud | Acrux | Piloting | 3 | September 29th 06 02:16 AM |
Holy $#$ - eBay Copter | Jimbob | Home Built | 37 | September 13th 05 10:58 PM |
