Standards for H.P. corr. factors ??
Old July 5th 07, 03:47 AM posted to rec.aviation.homebuilt
Rich S.[_1_]
Default Standards for H.P. corr. factors ??
"Morgans" wrote in message
Time for someone to trot out the GM stress test for new engines.
It makes the FAA tests look like a walk in the park.
Anyone got a copy of that handy?
No, but I remember one test for the Chevy 350 V-8. They were trying to run
the test in the greater Los Angeles area and couldn't pass. It turned out
the intake air was more polluted than the specs for the exhaust emissions.
They had to move the laboratory out to some dry lake east of L.A. to run the
test. It passed. The exhaust was more pollution-free than the air in L.A.
Urban legend? I dunno, but I flew over L.A. in the 60's and had less than a
mile visibility on a clear day.
Rich S.
Old July 7th 07, 02:29 PM posted to rec.aviation.homebuilt
Barnyard BOb
Morgans wrote:
"Charles Vincent" wrote
I will bet that many of the un-certified engines being marketed out there
couldn't finish the endurance test without swallowing an exhaust valve.
Morgans, no need.
You're outclassed no matter what you wave at the crowd. :-)
I am sooooo glad that I have no dogs in this hunt.....
YET!
- Barnyard BOb -
Old July 7th 07, 05:19 PM posted to rec.aviation.homebuilt
Morgans[_2_]
"Barnyard BOb" wrote
Morgans, no need.
YET!
I know, I know. Keep flying those ancient tractor engines, and be quiet!
g
I had not sighted you around, for a while, so I thought it would be safe to
throw out the conversion engine testing bit.
Next time, give me a 3 day warning before you pop in, so I know whether to
post stuff like that, or to wait until you are gone! ;-)
Jim in NC
Old July 7th 07, 09:04 PM posted to rec.aviation.homebuilt
Peter Dohm
there
Jim in NC
IIRC, the one who used to post that article was Corky Scott and it has been
quite some time since I have observed any posts from him. OTOH, I have
never been sure which manufacturer's stress test that may have been. A
frequent contributor to another NG, who was retired from one of the other
automobile companies, occasionally wrote in the same style as the article
that I recall; but that style may very well be generic to the industry.
However, I am glad that you brought the subject back up; because there are a
couple of points which I neglected to make in an earlier post in a branch of
this thread.
1) The certification test for aircraft engines really does apear to be
directly related to the actual use and performance of aircraft engines, as
installed, using real propellers and an acceptable simulation of real
aircraft cooling systems--with all of the efficiencies and inefficiencies
which all of that might imply.
2) The automotive engine stress tests could very well be exactly what the
name implies--Stress Tests. In other words, they may well be very carefully
designed tests to predict certian common warranty problems on new engine
models--as used in automobiles where they commonly operate between idle and
20% power, with occasional bursts of full power and occasional demands for
maximum power from cold engines. Based on that possibility, it would be
very usefull to know the engine coolant outlet *and* inlet temperatures and
flow rate as well as the oil outlet *and* inlet temperatures and flow rate
during the sustained high power run. (Remember that they have chillers on
line which probably have far more capability than the engines under test.)
There are a few other things I would like to know, specifically for any
engine which I might consider for conversion, such as any additional steady
speeds which might have been tested; but those temperatures and flow rates
would tell whether the engine showed any promise when using any plausible
cooling system in an aircraft.
There are still several automotive engines that I believe have a lot of
promise, and I would really enjoy such a project. However, it would save a
lot of effort if a few more data points happened to be published.
Peter
Old July 8th 07, 12:31 AM posted to rec.aviation.homebuilt
Morgans[_2_]
carefully
and
I remember it more as a worst case abuse test. LOTS of WOT running, some of
it for longer periods of time than certifications tests.
and
steady
Good point about flow rates and temperature.
From the guys that have used Ford and Chevy V-6's, they have not had a
problem with cooling if the system is well designed to create a good
positive air pressure. Shoot, instead of real radiators, most use two GM
air conditioner condenser radiators. It seems like cooling must not be too
hard, with those two little radiators.
The only problem stated is that they can not sit for too long, without
overheating.
I always wondered why they don't put little fans on the radiators, as is
standard for auto applications. I know, a little more weight, but if it got
me though long taxi situations at fly-ins, and big airports, that would be
weight I would be willing to carry.
Jim in NC
Old July 8th 07, 01:36 AM posted to rec.aviation.homebuilt
Peter Dohm
carefully
and
for
of
The test does include long periods of WOT, in addition to a lot more types
of extremely severe service. My point about the idle to 20% power is that
most of the engines sold will be used in automobiles with mostly very
lightly loaded operation, interspersed with bursts of acceleration onto
highways and occasional panic acceleration with cold engines. As I
understand it, the real purpose of the tests is to accelerate the possible
failures of a few critical parts, such as vibration dampers and head
gaskets, in an effort to predict and control the long term costs associated
with warranties--and especially extended warranties and service contracts
which can frequently by 7 years and 100,000 miles.
and
rate
on
test.)
steady
rates
plausible
too
overheating.
It's good to hear that the cooling works reasonably well at normal power
levels--at least for the V6 engines. There are basically two cooling
problems to overcome at idle: First, there is the usual problem of
downdraft cooling in which the air must be pushed downward even though
convection wants to move it the other way--and a lot of air cooled engines
have the same problem when the installation is entirely designed around high
speed and low drag and the cooling inlets are simply too small to get the
job done at idle. The second problem is peculiar to liquid cooled engines
in which most of the coolant in the radiators is positioned lower than most
of the coolant in the engine--the water pump needs to turn fast enough to
move the coolant in a direction opposite from its natural convection. The
result is that a lot of V6 and V8 engine installations with offest reduction
drives (usually belt or chain) probably suffer from a "double wammy" in
terms of cooling difficulty at idle. OTOH, some of the inverted
installations, such as Steve Wittman's conversion for the Tailwind, which
had updraft cooling and the radiator mounted above the inverted crankcase,
should be immune from those problems--although I neglected to ask Steve
Wittman that question and have not had an opportunity to ask anyone else
with real world experience.
(He was in attedance and had the V8 Tailwind on display at SnF a number of
years ago.)
got
I don't know the real reason, but fans would definitely restrict the airflow
at speed. That could be a greater penalty than the modest weight.
Peter
Old July 5th 07, 04:25 AM posted to rec.aviation.homebuilt
Dave S
there couldn't finish the endurance test without swallowing an exhaust
valve.
Charles
Mine could. Simply because it doesn't have valves.
On a side note that IS interesting about the certification requirements
and the endurance required.
I wonder how many "certified engines" are requiring rebuild at the
completion of a full regime used during the certification process.
Dave
Mazda rotary goin in a velocity SE
Human factors RECKLESSNESS private Aerobatics 60 May 10th 05 05:52 AM
Human factors RECKLESSNESS private Piloting 68 May 10th 05 05:52 AM
Human factors RECKLESSNESS private Soaring 72 May 10th 05 05:52 AM
Strike Fighter Squadron OPTEMPO factors [email protected] Naval Aviation 4 March 3rd 05 12:14 PM
JAR 22 STANDARDS Gordon Schubert Soaring 2 April 7th 04 05:31 PM
