FWIW, Moller Again ?
Old July 9th 07, 10:34 PM posted to rec.aviation.piloting
Darkwing
Default FWIW, Moller Again ?
"Big John" wrote in message
What if he comes to a 50 foot tree? Can't go over and in grond effect
runs into it (
Big John
Air brakes! (or is it error brakes?)
DW
Old July 6th 07, 06:25 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
In rec.aviation.piloting Al G wrote:
GROUND-EFFECT VEHICLE PRODUCTION LAUNCHED
Moller International has completed tooling for its M200G volantor, a small,
"Jetson-like" two-passenger vehicle designed to take-off and land
vertically. The M200G is saucer-shaped, about the size of a small
automobile, and is intended for operation continuously about 10 feet above
ground level. "It's the ultimate off-road vehicle, able to travel over any
surface," claimed Dr. Paul Moller, CEO. He further claimed the M200G could
speed up to 50 mph over a variety of terrain because the electronics keep
the craft stabilized at no more than 10 feet altitude, where extra lift is
obtained from operating near the ground. For more information, visit
www.Moller.com.
I'll bet it's a real thrill going over hills, especially on the downhill
side.
Jim Pennino
Remove .spam.sux to reply.
Old July 6th 07, 07:27 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
www.Moller.com.
side.
Jim Pennino
That's called flying in "hill effect", or maybe its "slope
soaring"... :-)
Old July 6th 07, 08:15 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
In rec.aviation.piloting Gig 601XL Builder wrDOTgiaconaATsuddenlink.net wrote:
small, "Jetson-like" two-passenger vehicle designed to take-off and
land vertically. The M200G is saucer-shaped, about the size of a
small automobile, and is intended for operation continuously about
10 feet above ground level. "It's the ultimate off-road vehicle,
able to travel over any surface," claimed Dr. Paul Moller, CEO. He
further claimed the M200G could speed up to 50 mph over a variety of
terrain because the electronics keep the craft stabilized at no more
than 10 feet altitude, where extra lift is obtained from operating
www.Moller.com.
downhill side.
I'll bet nobody knows.
WHat ****es me off is that EAA is hyping it for him.
It's not hard to figure out; not even the Marine Corp has balls big
enough to try running a hovercraft over a hill bigger than a small
sand dune.
Jim Pennino
Old July 6th 07, 10:23 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Stuart & Kathryn Fields
Gig 601XL Builder: The 2005 EAA video from Oshkosh had just a quick short
flick of a Rotorcraft. Of all they had to choose from they selected the
AirScooter. The AirScooter has no autorotation capability and has the
perfect opportunity for a Lawn Dart Conversion when an engine out occurs at
the max recommended ceiling of 50'. I'm not sure where the "Powers that
Be" are trying to take EAA. It sure seems like it is in a direction away
from amateur built aircraft.
Stuart & Kathryn Fields, Publishers
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
(760) 408-9747 publication cell
(760) 608-1299 technical cell
www.experimentalhelo.com
www.vkss.com
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
www.Moller.com.
downhill side.
Old July 11th 07, 03:23 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Dave Hyde
Gig 601XL Builder wrote...
I cancelled my membership and tech counselor status when they endorsed Jim
Campbell's so-called 'resource guide'. Let's just say I'm not unhappy.
Dave 'back in the game' Hyde
Old July 6th 07, 08:11 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Bill Daniels
Way back, I got a chance to play with some prototype "ATV - like" consumer
ground effect machines. They looked like a cross between a Vespa motor
scooter and an ice rink resurfacing machine. We unloaded them in a big,
empty parking lot and fired them up.
The first thing you learn about ground effect machines is that they stir up
a LOT of dust - even where you didn't expect there would be any dust.
The second thing is that they will almost uncontrollably slide downhill. In
this case, until they got to the storm drain gratings in the corner of the
parking lot where they grounded themselves - there's no ground effect above
a grating. We then faced the problem of an 800 pound machine with no wheels
firmly stuck on a storm drain grate. Fortunately, the truck that delivered
them had a wrecker crane - possibly due to the developers previous
experiences with storm drain grates.
We decided that dry land was possibly not their native environment so we
tried them over water since water is 'mostly' level.
The first thing you learn about ground effect machines over water is that
they kick up a LOT of spray - enough to thoroughly soak the driver. You
need goggles to keep the spray out of your eyes but spray covered goggles
are hard to see through.
The second thing you eventually discover is that when the engine quits over
water the thing sinks FAST. Fortunately, the developer had a water recovery
skiff with a crane and plenty of drying out stuff - possibly due to previous
experiences with over water engine failures.
Maybe this is why you don't see a lot of consumer ground effect ATV's.
Bill Daniels
small,
above
any
could
is
www.Moller.com.
side.
Jim Pennino
Old July 6th 07, 08:47 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Ernest Christley
Bill Daniels
Bill, that was hilarious. Thank you.
I can see I-40 now during rush hour. On of the Aircars runs over a
drainage grate and goes crashing to the ground. Then there is a 300
aircar pile-up, because short of tossing an anchor over the side, I see
nothing on the thing to make an emergency stop with.
More Moller crap Anthony W Home Built 0 April 18th 05 06:25 AM
Move Over Moller Larry Dighera Piloting 16 March 9th 05 01:39 PM
Soviet Ekranoplan redux, FWIW Ogden Johnson III Naval Aviation 0 March 23rd 04 08:44 PM
Moller Skycar T-Boy Piloting 17 March 1st 04 04:23 PM
Moller gets competition! Rob Turk Home Built 18 December 11th 03 09:09 PM
