dream time
Old July 8th 07, 07:59 PM posted to rec.aviation.soaring
Markus Graeber
Default dream time
I'd add the new 18m Jonkers JS-1 Revelation to that list. It'll come
as a jet sustainer and conventional self launcher as well, it would
definitely be on my short list. The Antares now comes in a dedicated
18m version as well, but only with a conventional Solo sustainer
engine as option. If I understand it correctly the 304S Shark comes
with a jet self launch option (not jet sustainer) and a conventional
Solo based sustainer option.
Markus
Old July 8th 07, 09:15 PM posted to rec.aviation.soaring
Tim Mara
Default dream time
304S also has the typical power plants for self launch if anyone wants
them....same as S-H, AS or DG.....
Jet is far more interesting, likely more reliable than any of the other
options.....and has plenty of power for self launching but needs a boost to
get initial movement.(short auto tow)...will not be certified therefore as a
self launcher
tim
"Eric Greenwell" wrote in message
news:Yiaki.6226$t05.3592@trndny09...
bagmaker wrote:
OK all, its cold (with an F), wet and dreary here in Oz, and time to
fire up the dreams machine.
What ship, down to 3 options-
ASH26E
304S with Jet sustainer
Antares 20E
Which is your choice and why?
What kind of flying do you hope to do?
If it's safaris, that might favor the ASH26E, because the 304S sustainer
needs a tow and the Antares needs electricity and has much more limited
motoring range.
If most of your flying is where and when a tow is readily available, that
would favor the lighter, simpler, cheaper sustainer.
If it's mostly from an airport with access to electricity and long powered
retrieves aren't important, that would favor the Antares.
Contest flying? The classes you can fly in will be determined by the
glider you choose; e.g., no 18 M if you get the Antares.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old July 8th 07, 10:46 PM posted to rec.aviation.soaring
Bill Daniels
Default dream time
"Tim Mara" wrote in message
to get initial movement.(short auto tow)...will not be certified therefore
as a self launcher
tim
A return to bungee launch?
Old July 9th 07, 04:11 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
wow! Hit a sweet spot here!
Ok, I dont know why the Ventus isnt on the list, its a dream list and not a dream ship (reaching for flame suit)
Cost is an issue with the Antares, but hey ,we are dreaming.
Safari style touring is the aim, I cant imagine too much trouble in finding a AC socket every couple of days would be a struggle on any safari, even if it means U Hiring a genset on the field. 20m is restrictive for competition, having to compete with open class, although if it handles as well as told, should be good. How is it in light conditions with the "permanent" higher wing loading?
I would admit the JS1 Revelation to be near the hit list, although it looks a tad tight cockpit wise and both it and the company remain unproven.
Both the JS1 and the shark 304 would be a great thing jet assisted, I cant wait for that!
What other options do we come up with for assisting the assist for self launch?
Electric wheel motor?
Clockspring wheel? (maybe it can be wound up!!!)
thanks in advance
bagger
Yes Mal, you can fly it
Old July 9th 07, 07:13 AM
Senior Member
The reason the Ventus, ASG variants and similar craft are not on a dream list (of mine) is the engine.
2 strokes should be restricted to lawn mowers, simple as that.
The simplicity, weight and size of a turbine is the main drawcard, noise and low-speed (self-launch) power are the downers.
The Antares will improve both in pricing and electrical complexity/longevity if the company is supported - sales would indicate it will be- and we can all see that self-launch will be the way to fly eventually.
still dreaming..............
bagger
Old July 9th 07, 05:33 AM posted to rec.aviation.soaring
Default dream time
On Jul 8, 3:14 am, bagmaker
ASH26E
Antares 20E
bagger
bagmaker
i need some turbine time so its the 304S for me
Old July 9th 07, 06:36 AM posted to rec.aviation.soaring
bumper
Default dream time
"bagmaker" wrote in message
ASH26E
Antares 20E
bagger
bagmaker
Second Eric Greenwell's response and add:
Of the 3 ships you list, I'd pick either the 20E or ASH26E depending on the
mission.
I was very impressed with the engineering and thought that went into the
Antares when I saw Dave's ship at the SSA convention. I've owned an ASH26E
for almost 5 years and am delighted with it. The Wankel power plant is
turbine smooth and has been 100% reliable, no breakdowns, failure to start,
or overheating. I made the decision to buy the 26E after discussing build
quality with Larry Mansberger and others who maintain and work on gliders.
bumper
bumper ZZ (reverse all after @)
"Dare to be different . . . circle in sink."
Quiet Vent and MKII Yaw String
A Dream franck jeamourra Piloting 0 March 27th 04 07:43 PM
A dream franck jeamourra Simulators 0 March 25th 04 12:26 PM
a dream franck jeamourra Owning 0 March 25th 04 06:26 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
Dream Time -- Little help here? Richard Kaplan Owning 27 July 9th 03 03:37 AM
