Aerodynamics acording to Myth Busters!
Old November 1st 07, 08:10 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Default Aerodynamics acording to Myth Busters!
"Denny" wrote
Jeez, there goes my excuse for not fixing the broken latch on the
tailgate... I hate it when that happens...
Ahh, don't sweat it too much.
A couple bungee chords will do just fine. g
Jim in NC
Old November 1st 07, 08:46 PM posted to rec.aviation.homebuilt
Lou
I admit, I didn't follow the original thread, but I've driven
a pickup for the past 30 years and I can tell you that each
time I've installed a cap I lost 2mpg.
Lou
Old November 1st 07, 11:08 PM posted to rec.aviation.homebuilt
clare at snyder.on.ca
Lou
And on my 1957 Fargo, putting the gate down gave me an extra couple of
MPH and MPG. Mind you that whole truck had no aerodynamics at all.
Stepside with sidemount.
Posted via a free Usenet account from http://www.teranews.com
Old November 2nd 07, 01:18 AM posted to rec.aviation.homebuilt
Harry K
Jim in NC
I hate modern technology. They never work as well as the old stuff.
Just today I saw the broken end of a bungee on the side of the
highway. That never happened in the days of baling wire.
Harry K
Old November 4th 07, 06:56 PM posted to rec.aviation.homebuilt
J.Kahn
Capt. Geoffrey Thorpe wrote:
"cavelamb himself" wrote in message
link.net...
But those webbed tailgate thingies have GOT to increase drag.
Don't they???
Richard
OK, Following up on on old thread.
I spent the day working in an automotive wind tunnel today, and I thought to
ask the operator if he had tried tailgate up / down in the tunnel.
He said they did a bunch of tests on an F150 and found that a tonnau cover
was best, a cap was nearly as good, tailgate up was better than down (I
forget if there was a difference between down and removed) and the web
things were the worst.
With the tailgate up, when they used smoke, the smoke would go over the roof
and then come down and touch the top of the tailgate.
Geoff
I work on the RJ program and it was once explained to me, in a
discussion of devices to slow airflow in ducts, that a wire mesh
structure has far more drag and will create a much larger and more
permanent (longer lasting effect downstream) drop in velocity than a
single obstruction, even if the single obstruction is much larger. In
our case, a nozzle type restrictor used on the cockpit air duct had a
fraction of the effect on velocity downstream, that the mesh screen at
the outlet had, and was basically useless. So it's easy to see how
those tailgate screens are the worst thing to do for drag.
John
Myth: 1 G barrel rolls are impossible. Jim Logajan Piloting 244 June 22nd 07 04:33 AM
Dispelling the Myth: Hillary Clinton and the Purple Heart Otis Willie Naval Aviation 0 February 21st 06 05:41 AM
dam busters Hamisha3 Military Aviation 48 February 26th 04 11:17 PM
cheap, durable, homebuilt aircrafts- myth or truth? -=:|SAJAN|:=- Home Built 27 January 8th 04 09:05 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 06:15 PM
