By the way, the "damage" was the result of a design fault in the nose gear
extension mechanism, not a result of excessive speed on climbout. The damage was caused by fast retraction of the nose gear on take-off (because of the weak cylinder against building airspeed); the solution to that one was to fit a restrictor in the hydraulic 'up' line. Any other problems were linked to, but not the cause of, the damage. The NAA logs are quite detaioled on this. Duncan |
Exceeding M1.0 in either the Sabre or the Dog was no big deal. You
just pointed them straight down from 40+ and didn't fight it if it wanted to roll around .95(flap rigging, usually). Question: didn't Edwards get boomed when Welch went supersonic? Walt BJ |
"Corey C. Jordan" wrote:
On 23 Sep 2003 07:47:41 -0700, (Walt BJ) wrote: Exceeding M1.0 in either the Sabre or the Dog was no big deal. You just pointed them straight down from 40+ and didn't fight it if it wanted to roll around .95(flap rigging, usually). Question: didn't Edwards get boomed when Welch went supersonic? Walt BJ It certainly did! Prior to heading back to North American to debrief with the engineers, Welch telephoned a friend that he had briefed the day before about what to be listening for. Excitedly, his friend related that they had been nearly blown out of bed by a terribly loud ba-boom. The time was noted and it corresponded to George's dive. Major General Joseph Swing heard the boom and reported it to Stu Symington. Hundreds of others heard it too. Many wives ran outside looking for the tell-tale plume of smoke indicating a crash, but there wasn't any smoke to see. Ask any of the NAA guys (or the Bell crew as well) who were there at the time. Welch's boom was quite loud, far more so than Yeagers would be (which makes sense when you consider that Welch was diving towards the base, whereas Yeager was in level flight at higher altitude). Correct me if I'm wrong, but didn't the XP-86 still have the 4,000 lb. thrust J35C-3 at that time? Quite a ways down on thrust from the 5,200 lb. J47-13 of the F-86A, and the top speed of the XP-86 in the only reference I have handy is given as 618 mph @ 14,000 ft. and 575 mph @ 35,000 ft. (M0.875), versus the 677 (presumably lower down) of the F-86A. The XP-86 is credited in the same source with first exceeding Mach 1 on 26 April 1948, but it's implied (not explicitly stated) that it did so on a 3,920 lb. thrust J35-A-5, and that the J47 was first installed in the F-86A. This seems more than a bit odd, to install an untried engine in the production a/c without flying it in the prototype first. I've read pilot's accounts that say that some F-86As would 'hang up' and not quite make it through the mach if you didn't do the roll in right, which suggests that the XP-86 with its lower thrust might well have trouble. Of course, if exceeding mach was mainly a question of drag rather than excess thrust, then it shouldn't have been a major problem. I've just always wondered. Guy |
On 23 Sep 2003 05:53:00 GMT, (DunxC) wrote:
By the way, the "damage" was the result of a design fault in the nose gear extension mechanism, not a result of excessive speed on climbout. The damage was caused by fast retraction of the nose gear on take-off (because of the weak cylinder against building airspeed); the solution to that one was to fit a restrictor in the hydraulic 'up' line. Any other problems were linked to, but not the cause of, the damage. The NAA logs are quite detaioled on this. Duncan According to Roy Ferrin, the actuator was replaced with one having a larger diameter piston, and the door linkage was adjusted to close a tad sooner. I can't see how a flow restrictor in the line will compensate for a lack of force resulting from inadequate pressure area. If you want more push for a given hydraulic pressure, you need a larger cylinder. My regards, Widewing (C.C. Jordan) http://www.worldwar2aviation.com http://www.netaces.org http://www.hitechcreations.com |
(Corey C. Jordan) wrote:
On 23 Sep 2003 05:53:00 GMT, (DunxC) wrote: By the way, the "damage" was the result of a design fault in the nose gear extension mechanism, not a result of excessive speed on climbout. The damage was caused by fast retraction of the nose gear on take-off (because of the weak cylinder against building airspeed); the solution to that one was to fit a restrictor in the hydraulic 'up' line. Any other problems were linked to, but not the cause of, the damage. The NAA logs are quite detaioled on this. Duncan According to Roy Ferrin, the actuator was replaced with one having a larger diameter piston, and the door linkage was adjusted to close a tad sooner. I can't see how a flow restrictor in the line will compensate for a lack of force resulting from inadequate pressure area. If you want more push for a given hydraulic pressure, you need a larger cylinder. My regards, Widewing (C.C. Jordan) They likely had to cause the NG to retract fast originally because as mentioned the cyl was weak and they needed to get the gear up before the airspeed had built up too far. That's what I gather from the writeup above. Problem likely was that, although the restrictor would reduce the speed of the retraction, it seems reasonable that it would combat the purpose of the fast retraction. Seems reasonable to fit a more powerful jack as they did. -- -Gord. |
what is good sound proofing for interior?!?! | Rick | Home Built | 12 | May 13th 04 02:29 AM |
Pulse jet active sound attentuation | Jay | Home Built | 32 | March 19th 04 05:57 AM |
Simpy One of Many Stories of a Time Not So Long Ago | Badwater Bill | Home Built | 40 | March 16th 04 06:35 PM |
