How do you guys deal with turn points with different radii in a "turn
area" task? I've been playing with my 302/303 and there doesn't seem to be a way to set a different radius for each turn point. It would be nice to get an "arrival" message for each turn point automatically. Do you guys have to verify cylinder entry manually in this case (for the 302/303)? Or is there another way to utilize this feature of the flight computer in a task with mixed radii? Thanks, Dave |
If you don't plan to use a PDA with moving map, then the best option
is to use a paper checklist to note your arrival at each turn. You will be navigating to the center of the turn area, so as soon as the distance to go indicates less than the radius, check it off on the list. You must still consider how deep to go and which side of center, etc... So continue displaying distance to this turn, until you decide to go to the next turn. This will help as you approach the back edge of the cylinder as well. But the key is that if the GPS displays a distance LESS than the radius, you are there. Having an audio beep is really redundant in turn area tasks especially since we are talking about fairly large areas. When flying an assigned task, the audio arrival notification makes a bit more sense, as the airspace could be a bit crowded with gliders due to the smaller radius. -Tom |
Dave,
Sometimes, you will not be navigating to the center, but to a far edge of the circle. Maybe your route to that far edge will take you through the center and maybe not. I use a pda running Glide Navigator II, and you can move your turnpoint from the circle center to wherever you need it within the circle. Then, you are navigating to that point rather to the circle center. If the 303 doesn't support Turn Area Tasks, you might consider as others have mentioned and get a pda. Another free software not mentioned is Soaring Pilot http://www.soaringpilot.or g/ made to run on the Palm operating system, but with the purchase of 'StyleTap' software, it will run on the Windows CE platform. Ray Lovinggood Carrboro, North Carolina, USA At 04:18 06 August 2007, 5z wrote: If you don't plan to use a PDA with moving map, then the best option is to use a paper checklist to note your arrival at each turn. You will be navigating to the center of the turn area, so as soon as the distance to go indicates less than the radius, check it off on the list. You must still consider how deep to go and which side of center, etc... So continue displaying distance to this turn, until you decide to go to the next turn. This will help as you approach the back edge of the cylinder as well. But the key is that if the GPS displays a distance LESS than the radius, you are there. Having an audio beep is really redundant in turn area tasks especially since we are talking about fairly large areas. When flying an assigned task, the audio arrival notification makes a bit more sense, as the airspace could be a bit crowded with gliders due to the smaller radius. -Tom |
On Aug 5, 7:44 pm, wrote:
How do you guys deal with turn points with different radii in a "turn area" task? I've been playing with my 302/303 and there doesn't seem to be a way to set a different radius for each turn point. It would be nice to get an "arrival" message for each turn point automatically. Do you guys have to verify cylinder entry manually in this case (for the 302/303)? Or is there another way to utilize this feature of the flight computer in a task with mixed radii? Thanks, Dave What hasn't been discussed yet is how to manage the "distance remaining vs time to finish" equation in a Turn Area Task - which is the really big impact of the the variable areas, really. Since these are all time-limited tasks, it becomes extremely important to be able to "what-if" (both before the flight, based on a guesstimate of the day's conditions) and in real time (as the reality of the day's condition becomes apparent!) the time to complete the task given the available area remaining, so as to finish just over the minimum time, if possible. Unfortunately, this is probably only practicable with a good PDA setup (and any of those mentioned will do it), or an expensive glide computer like the SN10. And even then it can be really interesting, especially on a weak day - there's nothing like trying to figure out time-speed-distance problems in the cockpit when the lift is less than a knot and you are below 2000' agl most of the time! Funny, how straight speed tasks, that only require a simple GPS to complete, are not used in Sports class - instead the emphasis is on time-limited tasks that really require some serious computational hardware and software to be competitive... Anyway - solution? Inexpensive PDA, free software, mouse GPS (or connect to existing 302), battery pack (if needed). Can probably be done for $300 or less. Set it up right and you can move it from glider to glider. Plus you get the benefits of a moving map with landable fields - a huge safety feature and confidence builder, IMO. Good luck, Kirk 66 |
On Aug 6, 1:23 pm, "kirk.stant" wrote:
Funny, how straight speed tasks, that only require a simple GPS to complete, are not used in Sports class - instead the emphasis is on time-limited tasks that really require some serious computational hardware and software to be competitive... Of course the "bring what you own" US sports class prevents good competition on straight speed tasks. Perhaps if a sailplane had been chosen for the world class, instead of a streamlined brick, we could have good head to head races for cheap :-) Todd Smith 3S |
toad wrote:
Perhaps if a sailplane had been chosen for the world class, instead of a streamlined brick, we could have good head to head races for cheap And this has prevented you from competing in world class? Jack |
On Aug 6, 3:07 pm, J a c k wrote:
toad wrote: Perhaps if a sailplane had been chosen for the world class, instead of a streamlined brick, we could have good head to head races for cheap And this has prevented you from competing in world class? Jack Yes, If a glider that had met my required specs when I was looking to buy a glider had been selected as the world class glider, I would probably have bought one. And my specs were not to extravagant, I ended up buying a Grob 102. Todd Smith 3S |
Warning, extreme topic creep!
When I started learning to race in the Arizona Soaring Association's year-long contest series, we still carried cameras, used start gates and finish lines, but were starting to use handeld GPSs to navigate. Tasks were mainly assigned speed tasks, with occasional MATs or PST when the weather was iffy, and speeds were handicapped. The trick was that we separated the gliders into performance groups, and tasked accordingly: A class was full-up racers, and could compete wet if desired. B class was current or just over the hill racers (say, std Cirrus and G-102 on up) but had to be dry. Also new guys with fancy toys but little racing experience. They were tasked on about 75% of the A class task. C class was for 1-26, Blaniks, G-109s, Pioneers, etc; anything that wanted to race but didn't quite have the speed to fly the longer tasks. Again, their task was a percentage of the A class. We had weekends with bigger grids than some regionals I've been to! Personal opinion: with small numbers of less experienced racers, the simpler the task the better. In fact, leeching is a good thing when you are trying to learn! I think area tasks can be too demanding for a newby, if you really try to fly them right. They should only be used as a last resort, for a specific reason: Iffy weather, too many competitors in the same piece of sky, etc. The good old speed task lets the pilot concentrate on going fast, or watching other pilots go fast and trying to copy what they are doi But I'm apparently a minority view (and used to that!). Kirk 66 |
Dave,
I fly with a 302 (love it) but I do have a PDA with GNll software & WP software (I just can't make up my mind), if you make the investment you will never regret it and wonder why you didn't do it before. The navigational and pilot comfort advantages of having the moving map software is huge, with all the navigation goodies mentioned by others and more. I have no direct connection but if you're unsure how to go about picking up the proper PDA system I suggest you contact Paul Remedy at Cumulus Soaring, he is very helpful and professional. RC - 21 On Aug 5, 9:26 pm, Marc Ramsey wrote: wrote: How do you guys deal with turn points with different radii in a "turn area" task? I've been playing with my 302/303 and there doesn't seem to be a way to set a different radius for each turn point. It would be nice to get an "arrival" message for each turn point automatically. Do you guys have to verify cylinder entry manually in this case (for the 302/303)? Or is there another way to utilize this feature of the flight computer in a task with mixed radii? The 303 doesn't support turn area tasks. Not only do you have the issue of differing cylinder radii, but you also have to determine how far to go into the cylinder before you turn, which is difficult to do without proper support from your flight computer or a PDA. My suggestion is that you get an iPAQ 38xx from Ebay or Craigslist, they typically go for around $100. You'll need a cable that will connect the iPAQ to the 302 along with a mount, available from Craggy Aero or Cumulus Soaring Supplies. Grab some free glide software like GPS_LOG or XCSoar (or splurge and get WinPilot, SeeYou Mobile, etc.), and you'll be good to go... Marc |
TSA's mistaken move in easing security delays for frequent fliers | Matt Barrow | Piloting | 15 | November 13th 05 09:42 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Remains of fliers returned to U.S. | Otis Willie | Naval Aviation | 0 | August 19th 04 11:32 PM |
Any fliers? | Garamondextended | Military Aviation | 200 | June 8th 04 08:45 PM |
For Fliers Only | ArtKramr | Military Aviation | 37 | December 4th 03 09:33 PM |
