B-52 Re-engining?
Old September 28th 03, 01:49 AM
BUFDRVR
No auto-rudder on the 757 when I retired from AA in 1993.
I have no reason to doubt you, just wondering what the hell Boeings putting out
in their literature. Does anyone with RB-211s have an auto rudder system?
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old September 28th 03, 02:07 AM
Tarver Engineering
"BUFDRVR" wrote in message
putting out
The 757 has an automatic YAW damper, as does the F-4, but the flight control
changes you are describing are a 777 feature. You really need an integrated
flight control computer to justify taking that much authority away from the
operator. A FBW B-52 is cool with me, but it sounds a tad pricey.
Old September 28th 03, 03:01 AM
Gene Storey
putting out in their literature. Does anyone with RB-211s have an auto
rudder system?
I'm pretty sure the KC-135R has an auto-rudder, and it's a FBC (fly-by-cable).
Although I've only been a passenger in one out of Altus, and that was in 89 :-)
Old September 28th 03, 03:12 AM
Tarver Engineering
"Gene Storey" wrote in message
rudder system?
control
integrated
(fly-by-cable).
That would be expected, but in newer airliners, the operator is not really
supposed to even operate the rudder. That idea is of course only filtering
down to pilots after the
A-300 event at Rockaway. In the 135 the automatic YAW damper was much less
agressive than for the 757.
89 :-)
The 757 is also fly by cable.
Old September 28th 03, 04:40 AM
John R Weiss
"Tarver Engineering" wrote...
Hmmm... Not what Boeing and the FAA say when an engine quits...
Old September 28th 03, 07:00 AM
Chad Irby
really supposed to even operate the rudder. That idea is of course
only filtering down to pilots after the A-300 event at Rockaway.
Quite a few of them found out about it from the Discovery Channel
(really!).
I think they need better mailing lists.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old September 28th 03, 08:50 PM
Darrell
B-58 Hustler History: http://members.cox.net/dschmidt1/
"Tarver Engineering" wrote in message
really
filtering
Not so. The rudder is used to coordinate flight in modern airliners as in
any airplane. It just doesn't take nearly as much with a properly
functioning yaw damper. The pilot flying keeps his feet on the rudder
pedals when hand-flying the aircraft. Rudder is used to deliberately
un-coordinate the aircraft when taking off and landing with a crosswind. I
know some airliners are landed in a crab with a crosswind but most call for
wing low into the wind with opposite rudder for alignment. Even autoland
uses opposite rudder to convert from a crab to a slip, usually at 150' AGL.
The only change after the A-300 event is a re-evaluation of what is meant by
being at or below max maneuvering speed. The old idea that being at or
below that speed allows full control deflection with no restrictions is what
is being questioned.
