Cirrus Lands via Parachute in Nantucket
Old August 19th 07, 04:21 PM posted to rec.aviation.piloting
Larry Dighera
Default Cirrus Lands via Parachute in Nantucket
On Sun, 19 Aug 2007 09:17:52 -0500, "Viperdoc"
wrote in
Does anyone know the N number
http://www.ack.net/Crash081707.html
The plane is registered to Jackson Thomas of 6 Prospect St.,
Nantucket, but Baker would not confirm whether he was the pilot.
http://registry.faa.gov/aircraftinqu...umbertxt=869CD
FAA Registry
N-Number Inquiry Results
N869CD is Assigned
Aircraft Description
Serial Number 1421
Type Registration Individual
Manufacturer Name CIRRUS DESIGN CORP
Certificate Issue Date 10/12/2004
Model SR20 Status Valid
Type Aircraft Fixed Wing Single-Engine
Type Engine Reciprocating
Pending Number Change None Dealer No
Date Change Authorized None Mode S Code 52770174
MFR Year 2004 Fractional Owner NO
Registered Owner
Name JACKSON THOMAS
Street 6 PROSPECT ST
City NANTUCKET State MASSACHUSETTS Zip Code 02554-2704
County NANTUCKET
Country UNITED STATES
Airworthiness
Engine Manufacturer CONT MOTOR Classification Standard
Engine Model IO-360 SER Category Normal
A/W Date 02/18/2004
Old August 19th 07, 05:43 PM posted to rec.aviation.piloting
Ron Natalie
Judah wrote:
Owen Rogers wrote in
Looks like another save for BRS and Cirrus.
Apparently a Cirrus was attempting to land ACK VFR last night when they
ran into weather (fog and low visibility after sunset on the island are
common in the summer). They pulled the Ballistic Recovery System
parachute about 5 miles northeast of ACK.
Wouldn't it have been easier to just turn around?
Fog setting in is often an area phenomenon. It's not
like flying into a puffy cumulous on a summer day.
Old August 19th 07, 06:08 PM posted to rec.aviation.piloting
Matt Whiting
True, but it hardly ever covers an area as large as the range of a Cirrus.
Matt
Old August 19th 07, 08:32 PM posted to rec.aviation.piloting
Ron Natalie
The Cirrus range isn't going to help much with a non-instrument trained
pilot blundering around in the muck. The issue is the conditions
changed faster than the Cirrus can fly.
Old August 21st 07, 12:40 AM posted to rec.aviation.piloting
Matt Whiting
Cirrus.
If the pilot executes a timely 180 and can fly straight and level on
instruments, as they should be able to according to the requirements to
earn their certificate, then there is no reason that fog or IMC should
require chute deployment.
Matt
Old August 19th 07, 08:23 PM posted to rec.aviation.piloting
Vaughn Simon
m...
And it can happen fast...damn fast...when temperature and dew point merge
for any reason.
I will never forget the time it happened to me. It took less than five
minutes to happen, a sudden ground fog that seemed to obscure the entire area.
I was a solo student...in a glider.
Had there been a whole plane parachute there is little doubt that I would
have considered using it. As it was, I received some help to find a hole in the
stuff and all turned out well.
Vaughn
Old August 19th 07, 09:20 PM posted to rec.aviation.piloting
Viperdoc[_4_]
The flight listed in Flightaware.com was IFR.
Old August 19th 07, 10:18 PM posted to rec.aviation.piloting
Marty Shapiro
"Viperdoc" wrote in
And is was on August 10th going from Nantucket to White Plains.
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Old August 20th 07, 01:48 AM posted to rec.aviation.piloting
Matt Barrow[_4_]
"Vaughn Simon" wrote in message
m...
merge for any reason.
five minutes to happen, a sudden ground fog that seemed to obscure the
entire area. I was a solo student...in a glider.
A previous post indicates that the airport (reportedly) went IFR half an
hour earlier.
Old August 20th 07, 01:50 AM posted to rec.aviation.piloting
Judah
Ron Natalie wrote in news:46c87147$0$23480
Does fog simply appear around a plane out of nowhere, and the pilot would not
have seen it coming before he flew into it?
I have never experienced that phenomenon...
Customs at KACK (Nantucket)? [email protected] Piloting 4 July 9th 06 05:42 PM
Martha's Vineyard or Nantucket Paul Owning 9 February 20th 06 10:39 PM
N1 lands in BED: Bush Piloting 50 February 17th 06 08:16 AM
Ack and Back-Plane Headed To Nantucket Missing: Bushleague Piloting 5 December 5th 05 01:22 PM
Nantucket airport John S Piloting 7 November 4th 04 07:32 PM
