Larry Dighera wrote:
On Tue, 21 Aug 2007 04:44:14 -0700, Jay Honeck wrote in . com: On Aug 21, 5:33 am, Larry Dighera wrote: Here in the Northeast, the FSDO will not approve an Air Gizmo at all, and the avionics shop I talked to won't install it as a result. Apparently Air Gizmo's products are not intended for installation in certified aircraft: http://www.airgizmos.com/paneldock.asp All products on this site are intended for use on experimental aircraft. Installation in a production aircraft may require an FAA field approval. Copyright © 2005-2007, AirGizmos, LLC. All Rights Reserved. Insurance company boilerplate. Lawyers dictating life, yet again. [...] For the FAA to be doing anything but embracing this innovative device shows precisely how stupid a government agency can be. Perhaps. But how do you know that the Air Gizmo is safe for installation in your aircraft? Have you personally (or anyone else) thoroughly tested it, and can you state with certainly, for example, that it will not emit voluminous poisonous smoke in the event of an electrical fire, or any of many other possible objectionable hazards or deficiencies? That's why the FAA has STCs. http://en.wikipedia.org/wiki/Type_certificate Supplemental Type Certificate A Supplemental Type Certificate (STC) is a document issued by the Federal Aviation Administration approving a product (aircraft, engine, or propeller) modification. The STC defines the product design change, states how the modification affects the existing type design, and lists serial number effectivity. It also identifies the certification basis listing specific regulatory compliance for the design change. Information contained in the certification basis is helpful for those applicants proposing subsequent product modifications and evaluating certification basis compatibility with other STC modifications. Would you be comfortable knowing, that the interior materials used in your aircraft will emit cyanide gas in the event of a fire? Or would you naively rely on ALL upholstery manufacturers to use safe materials that don't do that without submitting them to FAA for certification? Perhaps the government isn't as stupid as you think. Perhaps there have been issues in the past that warranted the implementation of STC policy? Given the manufacturer's admonition: http://www.airgizmos.com/faq.asp Q: Can the Panel Dock be installed in a certified aircraft? A: The Panel Dock can be installed in a certified aircraft, but you will need an FAA field approval. It would seem that FAA field approval* is required. I'm not an A&P, nor FAA inspector, so I'm not qualified to provide a definitive answer to this issue, so I'll defer to the professionals. (But I can see where those manufacturers who do go through the expense of STC approval might feel that they are being discriminated against if the FAA were to permit unapproved parts to be manufactured for installation in certified aircraft.) * https://www.faa.gov/aircraft/air_cer...d_approv_proc/ Field Approval Process The field approval process is used for one serial numbered aircraft in accordance with FAA Order 8300.10, Vol. 2, Chapter 1. Steps of the field approval process a The applicant proposes to repair or alter one serial numbered aircraft. The applicant must determine that the change is a major alteration or repair per 14 CFR 1.1** and 14 CFR part 43, Appendix A; The change is annotated on a FAA Form 337, Major Repair and Alteration; The applicant submits FAA Form 337 annotating the change with the data package to the Flight Standards District Office; The Flight Standards District Office may meet to assess the scope, complexity of change in light of 14 CFR 1.1 definitions and 14 CFR part 43, Appendix A. The Flight Standards District Office determines that either: The data is adequate and no field approval is required. The Aviation Safety Inspector can sign Block 3 of FAA Form 337 to approve the repair or alteration, or Additional data from the applicant is needed if the original data package is found to be inadequate, or The data needs Aircraft Certification Office review in light of its complexity or adequacy, or The alteration is of a type listed in FAA Orders 8300.10 which exceed the basic scope of a Field Approval and must be processed as an STC. If the Aircraft Certification Office reviews the data, they may: Determine that the data package is acceptable as is and can be approved as a Field Approval; Support the field approval with engineering review, advocate additional data or testing, assist with the flight test and Airplane Flight Manual supplements; Recommend that the project should be an Aircraft Certification Office managed Supplemental Type Certification project, and should proceed with the Supplemental Type Certification process. The Inspector approves the repair or alteration by signing block 3 of Form 337. Owners, operators, and persons who repair or alter aircraft, FAA Flight Standards Inspectors, FAA Aircraft Certification Office Engineers, and DERs need to know when a field approval is made. ** http://www.access.gpo.gov/nara/cfr/w...14cfr1_06.html Major alteration means an alteration not listed in the aircraft, aircraft engine, or propeller specifications-- (1) That might appreciably affect weight, balance, structural strength, performance, powerplant operation, flight characteristics, or other qualities affecting airworthiness; or (2) That is not done according to accepted practices or cannot be done by elementary operations. Major repair means a repair: (1) That, if improperly done, might appreciably affect weight, balance, structural strength, performance, powerplant operation, flight characteristics, or other qualities affecting airworthiness; or (2) That is not done according to accepted practices or cannot be done by elementary operations. But that's no surprise. Neither is your shortsighted cynicism. :-) Ray, c'mon back to the Midwest, where common sense prevails. "where the men are all good at looking, the women smell strong, and the children are above average brats." Any of a dozen shops will install it for ya, properly, with an A&P sign-off and logbook entry. And your insurance company will have an opportunity to deny your claim, and you can be assured of an FAA investigation at your next ramp check, not to mention your opportunity to stay in an aviation-themed motel. :-) What about the ABS "Royalite" used on the production panel , or the polyurethane seat cushion foam used in the production airplane? Those both burn and emit toxic gasses, probably more so than the thermoplastic used for the Air gizmo. I'd bet the air gizmo plastic is very similar to the plastic used on the faceplates of a lot of the TSO'd radios. Same is true for the plastic cradle that comes with the 496 for use with the yoke mount. I see nothing in my insurance contract that would allow them to deny a claim because I have a panel dock in my airplane. As long as the installation is properly logged I should be fine with the FAA and the insurance company, especially after it gets past the first annual with it installed. |
Mounting 396 | Paul kgyy | Piloting | 40 | August 24th 07 08:47 AM |
Mounting Cambridge 10 in ASW-19 | jcarlyle | Soaring | 0 | February 27th 06 01:48 PM |
ELT Mounting for an ASW20-C | Papa3 | Soaring | 11 | January 26th 06 06:37 AM |
Mounting my GPS | Charles Talleyrand | Owning | 8 | November 19th 03 11:51 AM |
Mounting my GPS | Charles Talleyrand | Piloting | 8 | November 19th 03 11:51 AM |
