Learning to spray paint
Old August 22nd 07, 03:19 AM posted to rec.aviation.homebuilt
Ernest Christley
Default Learning to spray paint
Stealth Pilot wrote:
I used a $6 airbrush from Northern Tool to spray a lot of the tube on my
project. It clogged up beyond repair about halfway through the
fuselage. It was actually beneficial that it was so small, because I
couldn't have gotten a touchup gun into all that small spaces between
tubes. I ended up doing a large section with a 3" roller. That worked
really well for everything except the tight corners. If I had to do it
over again, I'd roll as much as I could and hit the corners with the
modeler's airbrush.
you tried to get by with just one???? :-) :-)
buy a dozen of them :-)
expect them to gum up and replace them.
I must throw out the 5 gummed up ones I still have in the workshop.
Stealth Pilot
You live and learn. It was my first time, and I didn't know any better.
By the time I knew, it was late on a Saturday and the frame was
already sandblasted.
Old August 22nd 07, 01:09 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Wed, 22 Aug 2007 02:19:29 +0000, Ernest Christley
modeler's airbrush.
Stealth Pilot
I hope you meant to write bead blasted.
Old August 22nd 07, 03:54 AM posted to rec.aviation.homebuilt
George Warner
Can you tell me the model of the HF HVLP cheapy that you're talking about?
There are many on their site.
Thanks
"Ernest Christley" wrote in message
Morgans wrote:
"cavelamb himself" wrote
I second the HVLP approach.
Mine is a $90 Harbor Freight cheapie that I've used for the last 8
years.
It makes very little overspray, and works fine.
I should add that there is not enough tea in China to make me spray a
fuselage with an airbrush, when I could fill the quart HVLP gun one time,
or perhaps two, and do it all. The waste factor difference would be very
small, indeed.
I second the cheapy HF HVLP sprayer. The suck at spraying regular paint,
but the watery aircraft paints are a perfect match for it. It puts down
PolyTone in a perfect layer.
project. It clogged up beyond repair about halfway through the fuselage.
It was actually beneficial that it was so small, because I couldn't have
gotten a touchup gun into all that small spaces between tubes. I ended up
doing a large section with a 3" roller. That worked really well for
everything except the tight corners. If I had to do it over again, I'd
roll as much as I could and hit the corners with the modeler's airbrush.
"Life is not a journey to the grave with the intention of arriving safely
in
a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, with chocolate in one hand and wine
in
the other, loudly proclaiming 'WOO HOO What a Ride!'"
--Unknown
Old August 22nd 07, 08:49 AM posted to rec.aviation.homebuilt
Morgans[_2_]
"George Warner" wrote in message
Thanks
Wow, the prices for these have really come down.
http://www.harborfreight.com/cpi/cta...emnumber=93305
This one (above) is good, because it will work at any angle. I have not used
the exact model, though. Plenty good for primer, and probably good enough for
finish. The gun body material is unknown, but it has all of the controls for
the best spray control. I think it is my first choice.
http://www.harborfreight.com/cpi/cta...emnumber=43430
This is similar to the one I have used, but you have to be able to rotate your
work, because it can not spray upside down.
http://www.harborfreight.com/cpi/cta...temnumber=7901
This one is the most costly, and reads like it should be the best.
http://www.harborfreight.com/cpi/cta...temnumber=7902
This one has all the needed controls, and is smaller, but will not work
upside -down. The smaller size could be a good thing for getting into smaller
places. It reads as though it should spray a smaller pattern. (lower air
consumption)
http://www.harborfreight.com/cpi/cta...emnumber=92541
High cost, but the name is one of the most trusted in spray equipment.
http://www.harborfreight.com/cpi/cta...emnumber=46719
Another interesting choice in a smaller unit.
You are right. Lots of choices.
I think I would go with the first choice. Some of the other units do not have
as many controls, and that is one of the biggest keys to get the pattern you
need. I do like the spray lines instead of cup on the gun, so you can spray in
any orientation.
I don't need a new unit, but I am tempted to get this one. I don't have one
with the fluid line, instead of cup. I did find I could spray in many different
positions by putting a few elbows and couplings together, so the gun could go
upside down, and keep the cup level. It is kinda' a work-around, but it works
reasonably well for me. g
Jim in NC
http://www.harborfreight.com/cpi/cta...emnumber=90977
Could be a good choice.
Anti-fog window spray? Peter R. Owning 9 October 17th 06 04:19 AM
End Of Spray Season [email protected] Rotorcraft 0 September 24th 05 02:44 AM
FA: New WALCOM Spray Guns FYIS.org Home Built 0 August 11th 05 08:36 PM
The NEW liquid spray Pledge - Pledge® Multi-Surface Clean & Dust Spray No Spam Owning 6 February 15th 05 05:50 PM
Interior Spray Paint Ben Smith Owning 11 June 14th 04 08:33 PM
