B-52 Re-engining?
Old September 28th 03, 10:59 PM
B2431
What came out of the A-300 acident was both large
transport manufacturers saying pilots should not use the rudder under normal
operations.
So one doesn't use rudder when doing a manual turn as one does on every other
aircraft made? If AFCS isn't engaged one has to use rudder to control slip in a
turn. Ever heard of the expression "step on the ball?"
Dan, U. S. Air Force, retired
  #72
Old September 28th 03, 11:10 PM
Gene Storey
"Tarver Engineering" wrote
The pilot flying keeps his feet on the rudder
pedals when hand-flying the aircraft.
An unsafe practice, for modern airliners.
Do you have a source for this? Seems far fetched, but I don't fly airlines,
  #73
Old September 28th 03, 11:21 PM
Tarver Engineering
"B2431" wrote in message
normal
operations.
other
aircraft made?
The YAW damper moves the rudder for the airplane, no human workload is
involved.
The only way to disable the automatic YAW damper is to pull the circuit
breaker.
Ever heard of a fugoid? This is an F-4 related question, so don't blow it.
  #74
Old September 28th 03, 11:28 PM
Tarver Engineering
"Gene Storey" wrote in message
airlines,
In 1972 FAA instituted an automation of airliners requirment. Enterpolating
the number of passengers killed in that hand flying age to the number of
revenue flights today, hand flying predicts killing aproximately 5,000
passengers a year. Instead, man in the loop automated systems have turned
in two years of zero killed; for US common carriers since 1997.
Consider, you are more in hazard of dying of natural causes during an
Airliner ride, than you are to die in a crash. The statistics are such
today that a two man cockpit has become a statistical life saver, as a small
number of Captains expire each year enroute.
  #75
Old September 29th 03, 12:10 AM
B2431
breaker.
What does a tendency to manually over control in pitch have tp do with yaw?
Dan, U. S. Air Forve, retired
  #76
Old September 29th 03, 12:22 AM
Tarver Engineering
breaker.
it.
yaw?
Nope, go look it up.
  #77
Old September 29th 03, 01:43 AM
Jim Knoyle
"Tarver Engineering" wrote in message
airlines,
Enterpolating
small
And the logical conclusion from that would be,
since the befofementioned pitot system tendency to
become clogged with mudbees is such that the elevator
load feel system is an absolute guarantee for being locked into
a condition wheras the pitch attitude is somewhat determined by
the ratio of the lift vectors as seen from the perspective of the
outflow valves. And that is a very serious condition, indeed.
JK
  #78
Old September 29th 03, 02:14 AM
Gene Storey
airlines,
So the answer is no, you don't have any source?
  #79
Old September 29th 03, 02:18 AM
Tarver Engineering
airlines,
Enterpolating
turned
small
If you want a URL, do a google search.
  #80
Old September 29th 03, 02:33 AM
Gene Storey
I did. It said effective rudder use is required for a cross-wind take-off, and to
not use the tiller over about 30 knots accelerating to keep the aircraft centered.
Another page talks about slip techniques.
