Off in the weeds
Old August 25th 07, 01:05 AM posted to rec.aviation.piloting,rec.aviation.student
Matt Whiting
Default Off in the weeds
Dan Luke wrote:
It was the second flight of the day for the conservation organization I do
volunteer flying for. The local Baton Rouge guy bird-dogging illegal Cypress
logging had me set up to take him, a reporter and a cameraman from the Fox TV
station up to video the bad guys at work.
4R is the shortest runway at BTR, but it's closest to the FBO, so I begged for
it and got it.
Was it very hot also? I'm asking due to the fact that it took 3800' of
runway to accelerate to 75 and stop. That is a long way in a Skylane.
It is great that all turned out well and probably better than you
weren't able to rotate enough to lift-off. That may have been even
worse with that guy that close to the controls.
So, how did the flight go once you got off the ground on the next
attempt? :-)
Matt
Old August 25th 07, 02:12 AM posted to rec.aviation.piloting,rec.aviation.student
Dan Luke[_2_]
for it and got it.
South Louisiana in August? Yes, very hot. There was also some runway spent
while I tried to figure out the problem. Did we go past 80 KIAS? Maybe.
I've now had two scary emergencies. What they say about getting past the
denial stage is true.
It is great that all turned out well and probably better than you weren't
able to rotate enough to lift-off. That may have been even worse with that
So, how did the flight go once you got off the ground on the next attempt?
Fine. We found some cypress rustlers and the TV folks got their videos. Lots
of low altitude maneuvering and generally fun flying.
Dan
T-182T at BFM
Old August 25th 07, 04:38 AM posted to rec.aviation.piloting,rec.aviation.student
Matt Whiting
for it and got it.
Nobody tried to shoot you down, eh?
Matt
Old August 25th 07, 09:29 PM posted to rec.aviation.piloting,rec.aviation.student
Dan Luke[_2_]
I admit I did pucker a little bit.
There are some tough ol' Cajun boys down there.
Dan
T-182T at BFM
Old August 27th 07, 12:04 AM posted to rec.aviation.piloting,rec.aviation.student
Matt Whiting
Yes, some of those illicit folks don't take kindly to being spied on!
Matt
