![]() So if I am inexperienced, untrained glider pilot jumping out of my glider a= t 10,000 feet should I freefall for 30 secs down to around 3-5000 feet and = then pull the ripcord when I am spinning like a top and travelling at 120 m= ph, or should I just allow a few seconds to clear the wreckage and then pul= l the cord, and hopefully prepare myself for a long and cold, but safe desc= ent. (How long?) =20 I anticipate the later option. But I can anticipate having to freefall if I= was above, say 18000 feet because the hypoxia and cold might be worse than= the spinning. =20 If I attempt to open my parachute when I am spinning round and round at 120= mph, is it liable to open properly or is there a good chance of it all tan= gling up? =20 Rory =20 =20 Yeah, those are some questions a non-jumper might asks. It takes about 6= 0 seconds to freefall for about 10,000 feet. And I don't want to go to may= be 55 sec. or maybe a 1 min. 05 sec. argument, but a good number is 60 sec= onds. In the US or Europe, flights above 18,000 ft are not really that unu= sual. In many cases pilots will go to 30,000 ft levels or even higher. So,= if you have to bail out at that altitude would you pull the ripcord right= away? I would not. I would freefall for at least 60 seconds or a time tha= t is is necessary to deploy my parachute at or below 15,000 ft. In a case = of non jumpers that initial acceleration is horrifying, but after you acce= lerate to about 120 MPH the sensation of speed goes away. The only thing r= emaining is that everybody who exits an aircraft without a training, will = be spinning in the freefall. Guaranteed. That is why I did recommend to ta= ke a __________________________________________________ _______________ Try Live.com - your fast, personalised homepage with all the things you car= e about in one place. http://www.live.com/?mkt=3Den-gb = |
Even if you rely on the lanyard, you'll still be spinning like a top. As
soon as you exit the glider, you will be unstable, spinning and tumbling around. There is a very good chance the lanyard will wrap around you, perhaps tying you to the glider. I question whether a first-timer in freefall would have the environmental acuity to recognize their altitude, especially since he'll be spinning and tumbling wildly. Do an AFF or just take the risk. "Rory O'Conor" wrote in message ... So if I am inexperienced, untrained glider pilot jumping out of my glider a= t 10,000 feet should I freefall for 30 secs down to around 3-5000 feet and = then pull the ripcord when I am spinning like a top and travelling at 120 m= ph, or should I just allow a few seconds to clear the wreckage and then pul= l the cord, and hopefully prepare myself for a long and cold, but safe desc= ent. (How long?) =20 I anticipate the later option. But I can anticipate having to freefall if I= was above, say 18000 feet because the hypoxia and cold might be worse than= the spinning. =20 If I attempt to open my parachute when I am spinning round and round at 120= mph, is it liable to open properly or is there a good chance of it all tan= gling up? =20 Rory =20 =20 Yeah, those are some questions a non-jumper might asks. It takes about 6= 0 seconds to freefall for about 10,000 feet. And I don't want to go to may= be 55 sec. or maybe a 1 min. 05 sec. argument, but a good number is 60 sec= onds. In the US or Europe, flights above 18,000 ft are not really that unu= sual. In many cases pilots will go to 30,000 ft levels or even higher. So,= if you have to bail out at that altitude would you pull the ripcord right= away? I would not. I would freefall for at least 60 seconds or a time tha= t is is necessary to deploy my parachute at or below 15,000 ft. In a case = of non jumpers that initial acceleration is horrifying, but after you acce= lerate to about 120 MPH the sensation of speed goes away. The only thing r= emaining is that everybody who exits an aircraft without a training, will = be spinning in the freefall. Guaranteed. That is why I did recommend to ta= ke a __________________________________________________ _______________ Try Live.com - your fast, personalised homepage with all the things you car= e about in one place. http://www.live.com/?mkt=3Den-gb = |
With a 20ft lanyard, you won't have much time to spin before the chute is
pulled. With a manual chute (which I use to have on my back), I would pull immediately after egressing the glider at any altitude I usually fly at (which is up to 18'000 ft). Especially when the mountains below me have their tops somewhere between 10'000ft and 14'000ft. Hitting a mountain slope with 5 m/s while dangling unconsciently below a parachute may not be the optimum solution. However, hitting it at 200 kph with my eyes wide open seems to me even worse. I take emergency parachutes as a tool to survive, not necessarily as a solution to just walk away. "Jim Vincent" wrote in message . .. Even if you rely on the lanyard, you'll still be spinning like a top. As soon as you exit the glider, you will be unstable, spinning and tumbling around. There is a very good chance the lanyard will wrap around you, perhaps tying you to the glider. I question whether a first-timer in freefall would have the environmental acuity to recognize their altitude, especially since he'll be spinning and tumbling wildly. Do an AFF or just take the risk. "Rory O'Conor" wrote in message ... So if I am inexperienced, untrained glider pilot jumping out of my glider a= t 10,000 feet should I freefall for 30 secs down to around 3-5000 feet and = then pull the ripcord when I am spinning like a top and travelling at 120 m= ph, or should I just allow a few seconds to clear the wreckage and then pul= l the cord, and hopefully prepare myself for a long and cold, but safe desc= ent. (How long?) =20 I anticipate the later option. But I can anticipate having to freefall if I= was above, say 18000 feet because the hypoxia and cold might be worse than= the spinning. =20 If I attempt to open my parachute when I am spinning round and round at 120= mph, is it liable to open properly or is there a good chance of it all tan= gling up? =20 Rory =20 =20 Yeah, those are some questions a non-jumper might asks. It takes about 6= 0 seconds to freefall for about 10,000 feet. And I don't want to go to may= be 55 sec. or maybe a 1 min. 05 sec. argument, but a good number is 60 sec= onds. In the US or Europe, flights above 18,000 ft are not really that unu= sual. In many cases pilots will go to 30,000 ft levels or even higher. So,= if you have to bail out at that altitude would you pull the ripcord right= away? I would not. I would freefall for at least 60 seconds or a time tha= t is is necessary to deploy my parachute at or below 15,000 ft. In a case = of non jumpers that initial acceleration is horrifying, but after you acce= lerate to about 120 MPH the sensation of speed goes away. The only thing r= emaining is that everybody who exits an aircraft without a training, will = be spinning in the freefall. Guaranteed. That is why I did recommend to ta= ke a __________________________________________________ _______________ Try Live.com - your fast, personalised homepage with all the things you car= e about in one place. http://www.live.com/?mkt=3Den-gb = |
FS: Parachute | Ed Byars | Soaring | 0 | March 28th 06 11:09 PM |
Looking for a 28' Parachute | MC | Soaring | 8 | January 16th 05 12:09 AM |
F.S. Parachute | Tom Stowers | Products | 1 | October 1st 04 12:36 AM |
F.S. Parachute | Tom Stowers | Aviation Marketplace | 0 | October 1st 04 12:36 AM |
Parachute anyone? | [email protected] | Home Built | 18 | January 21st 04 07:39 AM |
