Tost brake bolt shears off
Old September 4th 07, 02:18 AM posted to rec.aviation.soaring
Mike Schumann
Default Tost brake bolt shears off
"never point the plane at anything valuable whilst expecting this brake to
stop it..."??????????
Brakes need to work reliably. If there is more than one incident of this
type, there needs to be a service bulletin or AD issued to fix the problem.
Mike Schumann
On Sep 1, 8:40 am, Jack Glendening wrote:
I am wondering if others have experienced the shearing of a Tost brake
bolt resulting in brake failure - I'm speaking about the bolt which
extends from the hub and is secured to the aircraft frame (not
the bolt which extends for the wire lever attachment). I experienced
such a failure on my latest landing with a month-old Tost unit - I was
puliing more strongly than usual on the brake but not nearly as hard
as I could, and certainly not as hard as I would if it had been an
emergency situation. I was amazed that such could produce a bolt
shear - I would have thought that some other brake part would fail
before such a
relatively thick bolt would, but I am no mechanic. It makes me wonder
about the quality of the parts Tost is using. Is this a known/common
point of failure?
Jack Glendening
Hi Jack - I believe you are talking about a 4.50 tire mechanical
(ie non-hydraulic) Tost brake? The wonder is not that the bolt
sheared, rather that your brake shoes (actually, the one shoe
doing any work) generated enough force to shear the thing.
I don't think this is a common point of failure (though another
post here recounts another incident). For these brake
assemblies modified to servo-actuate, the torque load
is carried through the cast aluminum hub from the cam
to this bolt, and the cast hub has been known to fail...
Make sure that the end of the bolt isn't sloppy where it
attaches to the gear fork, which maybe could provoke
a failure, replace the bolt, and never point the plane at
anything valuable whilst expecting this brake to stop it...
Hope this helps,
Best Regards, Dave "YO" ("Miss August")
Posted via a free Usenet account from http://www.teranews.com
Old September 4th 07, 06:25 PM posted to rec.aviation.soaring
Bruce
Anyone who relies on the ineffectual brake fitted to most older gliders is an
optimist of note.
On the 4.00 X 4 hub common to these aircraft you have a couple of square
centimetres of friction material, with non energising shoes trying to stop
around 300 - 350kg of glider moving at anything up to 100km/h. Most are good for
one retardation only, at best, then they fade severely.
In my experience, with a lot of fettling work one can achieve a brake that is
reliably weak - which is a whole lot better than the alternative. But experience
indicates that one should still discount it ever working effectively in an
emergency.
You would be distressed to see how much damage you can cause at walking speed
with a 15m single seater. Just think what a 26m+ motorised uber bug smasher
could do with all it's inertia. (although they tend to have halfway decent disk
brakes these days)
In any case the man has it right - Don't point your glider at anything you
intend to keep, especially on a downhill. There is no need to provoke Murphy.
snip
Old September 4th 07, 09:38 PM posted to rec.aviation.soaring
Chris Reed[_1_]
My open Cirrus (1968, probably 400kg with me on board) has the 400 x 4
wheel and Tost brake.
The main purpose of the brake is to stop the glider overrunning the
aerotow rope in the Up slack/All out transition.
It also makes a scraping noise if I use it after landing.
I've never yet met a reliable glider wheel brake. I suspect the worst
kind are those which work *almost* all the time (K21 comes to mind)
because then you might get into the habit of pointing the glider at
expensive objects!
is an optimist of note.
stop around 300 - 350kg of glider moving at anything up to 100km/h. Most
are good for one retardation only, at best, then they fade severely.
that is reliably weak - which is a whole lot better than the
alternative. But experience indicates that one should still discount it
ever working effectively in an emergency.
speed with a 15m single seater. Just think what a 26m+ motorised uber
bug smasher could do with all it's inertia. (although they tend to have
halfway decent disk brakes these days)
you intend to keep, especially on a downhill. There is no need to
provoke Murphy.
brake to stop it..."??????????
snip
Old September 4th 07, 09:56 PM posted to rec.aviation.soaring
Bob Backer
I must say that I almost agree. I have had 4 gliders. My Astir CS had
a tost brake that was bad. My ASW17 had a tost brake that was a bad joke
considering the mass of the 17. My ASW22 had a disc brake that worked
pretty well after bleeding but it just did not like to stay bled.
Amazingly, the tost drum brake on my Ventus C works like a champ. I can
put the glider on its nose if I want.
expensive objects!
gliders is an optimist of note.
square centimetres of friction material, with non energising shoes
trying to stop around 300 - 350kg of glider moving at anything up to
100km/h. Most are good for one retardation only, at best, then they
fade severely.
it ever working effectively in an emergency.
walking speed with a 15m single seater. Just think what a 26m+
motorised uber bug smasher could do with all it's inertia. (although
they tend to have halfway decent disk brakes these days)
provoke Murphy.
snip
Old September 8th 07, 11:20 PM posted to rec.aviation.soaring
Eric Greenwell
You should meet a glider with a Cleveland wheel and brake, like those
used on Schleicher gliders from the ASW 20 B/C and later. These are the
same brakes used on thousands of airplanes, and they are effective and
reliable.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old September 5th 07, 04:53 AM posted to rec.aviation.soaring
Mike Schumann
Ineffective brakes is one thing. Brakes where bolts shear off during normal
use is a completely different category.
Mike Schumann
"Bruce" wrote in message
is reliably weak - which is a whole lot better than the alternative. But
experience indicates that one should still discount it ever working
speed with a 15m single seater. Just think what a 26m+ motorised uber bug
Murphy.
snip
Old September 3rd 07, 03:16 PM posted to rec.aviation.soaring
John Sinclair
Jack,
I believe you are describing the *anti-rotation* bolt
and I have seen them shear off when the hub was improperly
installed. This bolt must be mated with its receptical
on the side of the landing gear or the hub will spin
when brakes are applied, resulting in the hub spinning
almost 360 degrees before hitting the landing gear
with sufficient force to shear off the bolt.
This bolt must be mated before installing the axle
when re-installing the wheel. While we're talking about
wheels and tires, if after changing the tire, the axle
doesn't slide easily through the hub, you have probably
*pinched* the tube in between the hub halves.
JJ
of a Tost brake
the bolt which
frame (not
I experienced
Tost unit - I was
not nearly as hard
it had been an
produce a bolt
part would fail
before such a
It makes me wonder
this a known/common
point of failure?
Jack Glendening
mechanical
the bolt
one shoe
thing.
another
it
at
it...
Hope this helps,
Best Regards, Dave 'YO' ('Miss August')
FS Tost E85 Release scooter Soaring 0 March 7th 06 02:31 AM
FS Tost E85 Release scooter Soaring 0 November 22nd 05 01:11 AM
TOST E85 RELEASES [email protected] Soaring 2 March 6th 05 04:21 PM
Cessna 182 Tost 337? [email protected] Soaring 6 May 15th 04 03:24 PM
Tost springs Lord Struthers Soaring 1 October 10th 03 10:49 PM
