Tost brake bolt shears off
Old September 5th 07, 04:53 AM posted to rec.aviation.soaring
Mike Schumann
Default Tost brake bolt shears off
Ineffective brakes is one thing. Brakes where bolts shear off during normal
use is a completely different category.
Mike Schumann
"Bruce" wrote in message
Anyone who relies on the ineffectual brake fitted to most older gliders is
an optimist of note.
On the 4.00 X 4 hub common to these aircraft you have a couple of square
centimetres of friction material, with non energising shoes trying to stop
around 300 - 350kg of glider moving at anything up to 100km/h. Most are
good for one retardation only, at best, then they fade severely.
In my experience, with a lot of fettling work one can achieve a brake that
is reliably weak - which is a whole lot better than the alternative. But
experience indicates that one should still discount it ever working
effectively in an emergency.
You would be distressed to see how much damage you can cause at walking
speed with a 15m single seater. Just think what a 26m+ motorised uber bug
smasher could do with all it's inertia. (although they tend to have
halfway decent disk brakes these days)
In any case the man has it right - Don't point your glider at anything you
intend to keep, especially on a downhill. There is no need to provoke
Murphy.
Mike Schumann wrote:
"never point the plane at anything valuable whilst expecting this brake
to stop it..."??????????
snip
Posted via a free Usenet account from http://www.teranews.com
FS Tost E85 Release scooter Soaring 0 March 7th 06 02:31 AM
FS Tost E85 Release scooter Soaring 0 November 22nd 05 01:11 AM
TOST E85 RELEASES [email protected] Soaring 2 March 6th 05 04:21 PM
Cessna 182 Tost 337? [email protected] Soaring 6 May 15th 04 03:24 PM
Tost springs Lord Struthers Soaring 1 October 10th 03 10:49 PM
