ELT Message From FAA
Old September 7th 07, 02:24 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Gig 601XL Builder
Default ELT Message From FAA
Denny wrote:
The regs do not require replacement of the ELT 121.5 units... Save
your money, install new batteries at the annual, and keep on
trucking...
denny
Yet. The NTSB is telling the FAA they should change the regs.
Old September 8th 07, 10:28 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Ron Natalie
trucking...
denny
The NTSB wants a lot of things. Few of them get implemented.
Old September 7th 07, 02:37 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
cjcampbell
trucking...
Why bother with new batteries if the thing won't work and is no longer
required? Just yank it out.
Personally, I am looking forward to a system that actually works.
Whether this one is it or not, time will tell.
Old September 7th 07, 02:59 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Peter R.
The 121.5 MHz ELT will still broadcast the emergency tone on that frequency
after the cutoff date and there will still be overflying aircraft monitoring
121.5, no? Granted that odds of being located by ELT after an off-airport
landing just lowered in this case, but removing the unit altogether reduces
those odds to zero.
Peter
OT Message rule???? Tri-Pacer Piloting 9 February 16th 07 04:43 AM
Christmas Greetings and Message tony roberts Piloting 1 December 25th 05 05:02 AM
Test message nauga Home Built 0 January 27th 04 11:24 PM
New guy with message for All UFO_Investigator - Jim D. Military Aviation 0 August 7th 03 06:53 AM
no message. trial only Ronald E Baker Soaring 0 July 28th 03 02:03 AM
