GNS430W: Parallel offset course feature
Old September 8th 07, 10:32 AM posted to rec.aviation.ifr
B[_2_]
Default GNS430W: Parallel offset course feature
Peter Clark wrote:
On Fri, 07 Sep 2007 08:11:19 -0700, B wrote:
Peter R. wrote:
On 9/7/2007 7:58:56 AM, Roy Smith wrote:
It's mostly used by people flying SAR missions. You keep increasing the
offset and end up flying a box pattern.
Ah, OK. I had read about trans-Atlantic flights using an offset and assumed
it was available in these WAAS boxes given their extreme accuracy and the
increased chances of mid-airs on climb-outs and descents.
It would be nice to use it on Victor airways, had they only offered
offests in 1/10 mile increments.
It would be nice to have victor airways in the box....
All the necessary components of Victor airways are in the box. What you
want, I presume, is an airway database. I guess you have to go to a
G-1000 to get that.;-)
Old September 8th 07, 02:24 PM posted to rec.aviation.ifr
Stan Prevost
It can be used to set a one or two mile offset from an unfamiliar airport
you are flying to, so it comes up on your left side where you can see it
rather than up under your nose where you might miss it. I used it that way
a couple of times on a Northstar M3, but didn't find it worth the trouble,
and I have never used it on my 430W. I can't think of any IFR use for the
feature.
Stan
"Peter R." wrote in message
Just picked up my aircraft with the GNS430W upgrade and was reading the
manual to see what new features are now included. In there I discovered
feature that allows the pilot to purposely fly a parallel offset course
anywhere from 1 to 99 miles. The only tedious characteristic of this
feature
(IMO) is that the pilot must set this option every time a flight plan is
activated, rather than having the option "stick" across flights. Thus,
over
time it seems to me a pilot may eventually opt to not set it.
Anyone use this feature? I am curious about its popularity.
Peter
Old September 8th 07, 02:42 PM posted to rec.aviation.ifr
Roy Smith
"Stan Prevost" wrote:
I can't think of any IFR use for the feature.
Use it for flying perfect racetrack holds. Set up the inbound leg on both
your #1 and #2 GPS, but set the #2 GPS to offset the course by a mile or
so. On the inbound leg, track the #1 GPS. On the outbound leg, track the
#2 GPS with reverse sensing.
Yeah, I know, I'm being silly.
grover cares, then Faris publicly designates a mere parallel apart from Jeremy's riot R. Hamid Piloting 0 August 13th 07 01:19 AM
Jeppesen database subscription for Garmin GNS530W / GNS430W WAAS GPS jbskies Owning 7 February 4th 07 09:21 AM
Jeppesen database subscription for Garmin GNS530W / GNS430W WAAS GPS jbskies Instrument Flight Rules 1 January 29th 07 07:58 PM
Parallel Track function in GPS? Roy Smith Instrument Flight Rules 25 April 30th 04 12:57 AM
Engine Mount Tilt and Offset Barrie Gittens Home Built 7 April 21st 04 01:22 AM
