![]() "Jim Burns" wrote in message ... "Kyle Boatright" What is your threshold for landing (or departing) downwind? Runway length. Jim Controllability doesn't enter into equation? It does for me. With a 10 knot headwind, I have lots of rudder authority at 10 or 20 knots of groundspeed on roll-out. With a 10 knot tailwind, there is no rudder authority at 10 knots of groundspeed. There is always the consideration of an engine failure. On takeoff or landing, I'd prefer to be pointed into the wind if the prop stops, rather than having to land downwind or attempt a low altitude turn into the wind... KB |
Kyle Boatright wrote:
"Jim Burns" wrote in message ... "Kyle Boatright" What is your threshold for landing (or departing) downwind? Runway length. Jim Controllability doesn't enter into equation? It does for me. With a 10 knot headwind, I have lots of rudder authority at 10 or 20 knots of groundspeed on roll-out. With a 10 knot tailwind, there is no rudder authority at 10 knots of groundspeed. There is always the consideration of an engine failure. On takeoff or landing, I'd prefer to be pointed into the wind if the prop stops, rather than having to land downwind or attempt a low altitude turn into the wind... It would depend on what aircraft type you fly. With Cessna's and Piper's, there is no need for rudder authority below 30 knots or even higher. I've never flown an airplane with a free castering nose wheel, but I suspect rudder authority is more important there, however, it still seems like the brakes would work fine for directional control at 10 knots. Matt |
On Sep 23, 5:06 pm, Matt Whiting wrote:
It would depend on what aircraft type you fly. With Cessna's and Piper's, there is no need for rudder authority below 30 knots or even higher. I've never flown an airplane with a free castering nose wheel, but I suspect rudder authority is more important there, however, it still seems like the brakes would work fine for directional control at 10 knots. Matt I've done downwind takeoffs and have scared myself a few times. Even five or ten knots leaves you with less control, and I might wish I had that control. Taking off in a gusting tailwind might drop you in the weeds off the end of the runway, too. Dan |
Depends heavily on the aircraft. I know for a fact that a lightly
loaded DC-10 will not be able to land and stop at McCarran with a 10+knot tailwind. Been onboard when it was tried and remember going off the airport boundries at less than 30 AGL You get a new perspective on things when you see TV antennas go by above you and chimmneys just below you! Lockheed L-10A is virtually impossible to land safely with any tailwind. It has so much tail surface that it either slams the tail down or tries to put it on the nose. deHaviland Super Chipmunk with a Krier tail gets super squirrelly with any kind of tailwind. Of course the tail will come off the ground at about 15 knots forward speed |
Matt Whiting wrote: What is your threshold for landing (or departing) downwind? Runway length. Jim Controllability doesn't enter into equation? It does for me. With a 10 knot headwind, I have lots of rudder authority at 10 or 20 knots of groundspeed on roll-out. With a 10 knot tailwind, there is no rudder authority at 10 knots of groundspeed. There is always the consideration of an engine failure. On takeoff or landing, I'd prefer to be pointed into the wind if the prop stops, rather than having to land downwind or attempt a low altitude turn into the wind... It would depend on what aircraft type you fly. With Cessna's and Piper's, there is no need for rudder authority below 30 knots or even higher. I've never flown an airplane with a free castering nose wheel, but I suspect rudder authority is more important there, however, it still seems like the brakes would work fine for directional control at 10 knots. My home airport (KLAM) is a one-way airport. All landings are on rw 27, all departures are on rw 9 regardless of wind conditions. This is due to rapidly rising terrain to the west, as well as the presence of nearby restricted airspace and a townsite immediately to the west. Thus, I have *lots* of experience in landing and taking off with a tailwind. The most important thing I've learned is this: AIRSPEED AIRSPEED AIRSPEED! Ignore how fast you *think* you're going. Ignore how fast the outside world looks like it's going by. Pay attention to the airspeed. Other posters are correct in that you need to turn base further out when landing with a tailwind. How much farther out? Depends on the tailwind. ![]() I wish there were an easy rule of thumb (like "turn base when the approach end is 45 deg behind your wing), but there isn't. In years of doing this, my own personal minimums (or perhaps "maximums" in this case) are 15 kt direct tailwind. This is at an airport that sits at 7300' MSL and has a 5300' runway, and I fly a PA32-300. If it's warm out ( 70 deg F), and the density altitude starts to creep up, that maximum will go down. I haven't found controlability to be much of an issue with tailwind t/o's or landings, but then I fly a wide gear Cherokee 6. It can be with a taildragger. The shallower climb angle is also most certainly something to consider, especially if there are obstructions at the departure end of the runway. Fortunately, at my home airport, the east end of the runway ends in a serious downward cliff. My recommendation: pay attention to the AIRSPEED! (and practice a few tailwind landings and/or takeoffs - they're really not as terrifying as they're made out to be). -- Dane |
"Kyle Boatright" wrote in message
There is always the consideration of an engine failure. On takeoff or landing, I'd prefer to be pointed into the wind if the prop stops, rather than having to land downwind or attempt a low altitude turn into the wind... I'd rather be pointed into the wind, too, but if the failure happens away from the field, I think I'd be a lot less concerned with landing into the wind than I would in actually making the field. -- John T http://sage1solutions.com/blogs/TknoFlyer http://sage1solutions.com/products NEW! FlyteBalance v2.0 (W&B); FlyteLog v2.0 (Logbook) ____________________ |
"John T" wrote in
m: "Kyle Boatright" wrote in message There is always the consideration of an engine failure. On takeoff or landing, I'd prefer to be pointed into the wind if the prop stops, rather than having to land downwind or attempt a low altitude turn into the wind... I'd rather be pointed into the wind, too, but if the failure happens away from the field, I think I'd be a lot less concerned with landing into the wind than I would in actually making the field. True, but downwind off field landings can be nasty. If it all goes horribly wrong on you you'll be travelling a lot faster with a lot less control than you would have with an into wind landing in an inferior field. Also, your glide path control will be much more difficult with a tailwind for two reasons. One, the angle will be much more shallow giving you progress judgement difficulties and of course your glide angle will deteriorate as the wind gradient gives you less tailwind as you descend. But as well as this you won't be used to making a glide approach this way and your chancs for success will be reduced because of this. Having said all that, if you've only got one place to land and downwind is the only way you can do it, well.. Bertie |
On Sat, 22 Sep 2007 23:01:54 -0400, "Kyle Boatright"
wrote: And what is the correct radio phraseology to say: "Fellas, it is time to reverse the pattern - you're taking off and landing downwind.." ? I don't know if it's correct, but I can tell you the reply I got when I tried it: "Pilot's discretion." (To make matters worse, it was right traffic on 33, left traffic on 15.) Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 new from HarperCollins www.FlyingTigersBook.com |
Why not to land downwind | [email protected] | Piloting | 23 | September 6th 06 03:01 PM |
Arizona Downwind Dash | Mike the Strike | Soaring | 4 | April 26th 05 03:53 AM |
Prop to High RPM on downwind | Mitty | Piloting | 70 | November 29th 04 05:13 PM |
Night landings vs. day landings | Gerald Sylvester | Piloting | 15 | February 12th 04 06:38 AM |
Question: "Overhead Entry to Downwind?" | Harry Shin | Piloting | 122 | January 20th 04 02:39 PM |
