Going for my Multiengine rating
Old October 6th 07, 08:28 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
The Visitor[_2_]
Default Going for my Multiengine rating
By way of an addition....
if somebody is in the back it is very easy to rotate for a nice flare
without getting close to a tail stall. Even with full flaps. Tlhere is
probably only one knot difference in stall speed between two notches and
three(full). Fuel and row one passengers only, the cg is very near it's
forward limit. A local flying school that also rents out it's Seneca has
some weight strapped down in the back area, I think 75 pounds. I think
they had three collapses over the last 15 years and none were due to
mis-rigging. And it is checked every 50 hours and also they hold an stc
for putting a window in so it can be inspected through the nose baggage
area each flight.
The Visitor wrote:
No, and with full flaps it pull an greater aoa for the same
authority(down force). It stalls. And the nose can drop real hard. As
the stab moves into ground effect the aoa increases also. The Cessna
Cardinal had this problem, which later got addressed with slots in the
stabilator.
Greg Esres wrote:
The Visitor wrote:
To flare nice with full flaps invites a tail stall.
Not likely. You will lose elevator authority, but the AOA gets
smaller as the tail moves down.
why there is the abundance of nose gear collapses in the type.
Actually, there is an AD out on the Seneca nose gear. The collapses
are generally due to misrigging of the airplane. Friend of mine has a
nosewheel collapse after a full stall, nose high landing.
Generally? I'm sorry about your friend and a misrigged gear on anything
is a hazard. And the pa34 nose gear (like any) can be mis-rigged.But the
seneca nose gears take a pounding because of the way they are flown. It
leads to failures.
John
Old October 9th 07, 02:21 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Greg Esres[_2_]
Sorry, I was thinking of a horizontal stabilizer/elevator combo.
Still, the lift coefficient of the horizontal tail most likely doesn't
get near Clmax. I regularly make full stall landings with the Seneca
using 40 degree flaps.The tail doesn't stall. If the nose drops, it's
a physical strength issue.
But the seneca nose gears take a pounding because of the way they
are flown. It
leads to failures.
The British did a very elaborate analysis of the nose gear on the
Seneca and didn't think that was a factor. The gear is designed to
withstand vertical loads. It's front to back loads that are a
problem.
Going for my Multiengine rating Kobra Piloting 34 October 10th 07 02:23 PM
Going for my Multiengine rating Kobra Owning 29 October 10th 07 02:23 PM
Going for my Multiengine rating Kobra Products 3 September 23rd 07 03:56 AM
Multiengine Rating [email protected] Piloting 79 January 25th 07 06:58 PM
rotorcraft commercial rating or better rating advice Rick Cook Rotorcraft 0 October 13th 03 04:49 PM
