Greg Esres wrote in news:1191892903.908004.61860
@k79g2000hse.googlegroups.com: No, and with full flaps it pull an greater aoa for the same authority(down force). It stalls. And the nose can drop real hard. As the stab moves into ground effect the aoa increases also. Sorry, I was thinking of a horizontal stabilizer/elevator combo. Still, the lift coefficient of the horizontal tail most likely doesn't get near Clmax. I regularly make full stall landings with the Seneca using 40 degree flaps.The tail doesn't stall. If the nose drops, it's a physical strength issue. But the seneca nose gears take a pounding because of the way they are flown. It leads to failures. The British did a very elaborate analysis of the nose gear on the Seneca and didn't think that was a factor. Why would they have done that? Well, I guess since there's no British airplanes to pic at... But haven't they got enough on their plate trying to figure out why 146's and RB211s are poisoning their pax? Bertie |
Well I have tail stalled it, twice, 18 years ago when learning. CG at
the forward limit(not close, _at_), full flaps, wing in ground effect, stabilitor moving into it's own ground effect, and don't use nose up trim. Thinking about your other post with the claim that some overspray created such problems, I should also point out the aircraft had the known icing package. Looking at the boot on the stabilator it surely must be the culprit as it is far worse than overspray or a wavy edge. As far as I know there is no change in a sabilator that is going to be booted or not. Was it the wing that stalled? Back then I was taught it was the tail. I was also warned if carrying ice to be _very_ wary of a tail stall (no flaps). As for the cardinal, pilots at the time told me the slots came out because some people were managing to stall the stabilator. It must have a very forward center of gravity, but to me that is the way it should be to make loading easier. I have stalled the wing in the flare and that was different. I am sure I could try to do it again but I will pass on that. Yes I trained doing all manner of stalls, well not all, not single engine stalls. I suspect newer Senecas go out the door with the cg farther aft as they have gotten very heavy compared to the III's. Thinking back to the times I did it, I still believe it was the tail that gave out. Even though it goes against popular thinking. But nobody would believe me if I claimed to see a flying saucer either. It's just my personal expierience, nothing quoted from books. And like anybodies I could be wrong, but I lived it so that is what I thought. But your right, it doesn't make sense, they wouldn't certify the airplane it there was any chance of the tail ever stalling under any possible condition. I didn't know that about certification requirements. Thanks for your thoughtful replies and setting me straight. John Greg Esres wrote: No, and with full flaps it pull an greater aoa for the same authority(down force). It stalls. And the nose can drop real hard. As the stab moves into ground effect the aoa increases also. Sorry, I was thinking of a horizontal stabilizer/elevator combo. Still, the lift coefficient of the horizontal tail most likely doesn't get near Clmax. I regularly make full stall landings with the Seneca using 40 degree flaps.The tail doesn't stall. If the nose drops, it's a physical strength issue. But the seneca nose gears take a pounding because of the way they are flown. It leads to failures. The British did a very elaborate analysis of the nose gear on the Seneca and didn't think that was a factor. The gear is designed to withstand vertical loads. It's front to back loads that are a problem. |
The Visitor wrote
Was it the wing that stalled? Back then I was taught it was the tail. I was also warned if carrying ice to be _very_ wary of a tail stall (no flaps). As for the cardinal, pilots at the time told me the slots came out because some people were managing to stall the stabilator. It must have a very forward center of gravity, but to me that is the way it should be to make loading easier. Yes, I'm aware of the icing issue. When I first posted, I was mentally referencing a NASA tail plane report that I had been reading. They did extensive tests and showed that an a/c is most vulnerable at the MAXIMUM speed for a given flap setting. Each flap setting increases the negative AOA for a particular airspeed, due to the downwash of the wing into the horizontal stabilizer. However, as the a/c slows, the AOA of the horizontal stabilizer becomes less negative, because the tail rotates down; the increased downward lift is provided by the elevator deflection, rather than increasing the AOA. I didn't stop to think how the report would differ if they were discussing stabilators. One possibility for the effect you noticed is that as the main wing stalls, there may be a decreased downwash over the horizontal stabilizer, which would produce a downward pitching motion. |
![]() Greg Esres wrote: One possibility for the effect you noticed is that as the main wing stalls, Just that will nose it down. But it was different than the wing stalling in ground effect. there may be a decreased downwash over the horizontal stabilizer, which would produce a downward pitching motion. I can't see it in a downwash while flaring. It's pretty close to the ground. Reduced airflow I could buy but in that situation it would still be firm and responsive to input. Ah well.... |
Question for Bob Gardner - Multiengine bank angle | kevmor | Piloting | 5 | May 14th 07 08:40 PM |
Multiengine Rating | [email protected] | Piloting | 79 | January 25th 07 06:58 PM |
Multi Engine & Time Building? Multiengine.net | NW_PILOT | Piloting | 15 | October 15th 05 12:05 AM |
IFR rating? | Bob Martin | Piloting | 58 | May 7th 04 04:29 PM |
rotorcraft commercial rating or better rating advice | Rick Cook | Rotorcraft | 0 | October 13th 03 04:49 PM |
