ATC failure in Memphis
Old September 26th 07, 07:05 PM posted to rec.aviation.piloting,rec.travel.air
Default ATC failure in Memphis
In rec.aviation.piloting Mxsmanic wrote:
Denny writes:
ATC failed due to commercial phone lines going down, so we need to
replace ATC ????
No, the argument would be along the lines of ATC being fragile and dangerous,
either because it needs more people/money, or because it is outdated and needs
to be replaced with Something New (depending on which ax you are grinding).
I can see us spending 10 billion dollars for a whole new ATC structure
- that still depends on Ma Bell's 1912 phone lines...
Ma Bell built telephone lines to be very robust indeed; its successors are not
so conscientious, unfortunately. In fact, Ma Bell went well beyond that (cf.
AUTOVON).
AUTOVON used ordinary phone lines usually, but not always, dedicated to
the military.
The lines used were, for the most part, routed around major cities to
avoid system destruction in a major attack.
Other than that, there wasn't much special about it.
Jim Pennino
Remove .spam.sux to reply.
Old September 27th 07, 04:33 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
Denny writes:
replace ATC ????
dangerous, either because it needs more people/money, or because it is
outdated and needs to be replaced with Something New (depending on
You have no idea hwatsoever of which you speak.
Fjukwit
Bertie
Old September 26th 07, 05:22 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
Craig Welch writes:
Huh? Failures such as this happen ...
Sure, but you can spin failures many ways.
Old September 26th 07, 05:36 PM posted to rec.aviation.piloting,rec.travel.air
Viperdoc
Anthony, look at yourself as an example.
Old September 27th 07, 04:34 AM posted to rec.aviation.piloting
Mxsmanic wrote in
Craig Welch writes:
As we all can see. (not including you fjukkwit)
Bertie
Old September 28th 07, 12:44 PM posted to rec.aviation.piloting,rec.travel.air
JA_MORAN
what about backup systems
a Microwave point to point could work, how about different feeds from
different circuits? or a SAtellite dish...
Mxsmanic wrote:
See
http://us.cnn.com/2007/US/09/25/memp...afu/index.html
Was it truly an accident? It sure happens at a convenient time for those who
want to fuel the argument that there's something wrong with ATC. However, the
incident could be used for both pro and con arguments, depending on how it is
spun, i.e., one could argue that "ATC lacks the resources it needs," or that
"ATC needs to be replaced by something new."
Old September 28th 07, 01:00 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
JA_MORAN writes:
Back-up systems can only work if they exist.
Old September 28th 07, 01:16 PM posted to rec.aviation.piloting
Mxsmanic wrote in
JA_MORAN writes:
TGhey do, idiot.
I've been in a complete ATC system failure (not in the US, BTW) and guess
what, everone landed, no problem
You're an idiot.
Bertie
Old September 28th 07, 01:20 PM posted to rec.aviation.piloting,rec.travel.air
FredGarvinMaleProstitute
Mxsmanic wrote:
JA_MORAN writes:
I explained the backup issue in a previous response. The FAA
"Had" microwave backup until the unqualified idiots decided
they did not need it and went single threaded with outside
contractors(Telco).
Current FAA Management is clueless about technical issues
and redundancy because they have filled their ranks with
bean counters and minorities who are unqualified to meet
diversity edicts handed down by feminist man hater goon
squads in D.C.
Your "Vagina" management at work. Emotional and illogical
and vindictive. Hillary in 08? God help us all.
Old September 28th 07, 01:23 PM posted to rec.aviation.piloting
FredGarvinMaleProstitute wrote in
Mxsmanic wrote:
JA_MORAN writes:
contractors(Telco).
Actually, it's you who are clueless about tech matters, but don't let me
stop you making an asshole out of yourself!
Not that anything could stop ya.
Bertie
SSA Convention - Memphis [email protected] Soaring 29 February 16th 07 10:14 PM
NC/SC/VA Pilots to Memphis? [email protected] Soaring 1 January 25th 07 02:51 PM
Memphis Belle Update jsmith Piloting 1 September 2nd 05 10:22 PM
Flying to Memphis Greg Esres Piloting 6 October 15th 03 12:26 AM
Memphis in September Jim Fisher General Aviation 0 July 2nd 03 02:59 PM
