On Sep 7, 2:57 pm, Marc Ramsey wrote:
http://www.equipped.org/SPOT_ORSummer2007.htm Looks interesting. Let us you when you have one Marc! More info at their web site http://www.findmespot.com The (very simple) Spot User Guide is available at http://www.globalcomsatphone.com/man...user_guide.pdf The "Help" message button could be used to send a message to your crew you need a retrieve. Looks small enough to put in the luggage shelf area on most gliders but to reach the buttons or see the status LEDs probably means the thing is stuck up on the glareshield or maybe strapped to your leg (if it can get a GPS signal in that position). Pity they did not design it to sit on a car dashboard - with buttons/ LEDs on one end, and that bright orange reflecting in the canopy will be annoying. You'll want to be able to see the LED status to be sure the thing has a GPS signal and is transmitting etc. A 12v external power input would have been nice. Remembering to press the tracking button before each flight may be a challenge. I don't see this at all as a replacement for a PLB - especially since it's not transmitting a 121.5/406 Mhz homing signal but the tracking feature is sexy. I wonder how long the tracking data is kept online, they seem to imply a long time. I also wonder how well these will work given problem Globalstar have been having with their satellites and service reliability. Any reports from glider pilots using Globalstar GSP-1700 (or 1600) phones in the western half of the USA? How have you found coverage and signal reliability? Yes I know the Spot service is slightly different, but I was also curious about the sat phones. If they work reliably the newer more compact Globalstar phones and their lower service prices are pretty interesting for remote places like the great basin. Cheers Darryl Ramm |
Hm,
The active tracking option might be what turns this device into something extremely useful in case of an emergency. Once in the habit of enabling the realtime tracker for each flight, then if an accident does occur, searchers will have a place to start looking. Even if the connection to the satellites is marginal, I expect that due to being airborne and the device being autonomous and sending just a data packet instead of voice, it should be able to get through at least a couple times per hour. If it gets through every 10 minutes, then that's even better. Each glider operation with internet access could set up the methods to track all local pilots, and the dream of getting real time competition tracking into the mainstream may have just turned into reality. If I read the review article correctly, the unit will cost $150 with a $150 per year subscription ($100 basic + $50 for real time). This is starting to look like a near perfect passive tracking and emergency "locating" solution. An ELT or PLB is still a must, but the realtime tracking will at least provide a starting point for the search. -Tom |
Hi,
That is a very cool device. I look forward to tracking cross-country soaring flights using them. Paul Remde "5Z" wrote in message oups.com... Hm, The active tracking option might be what turns this device into something extremely useful in case of an emergency. Once in the habit of enabling the realtime tracker for each flight, then if an accident does occur, searchers will have a place to start looking. Even if the connection to the satellites is marginal, I expect that due to being airborne and the device being autonomous and sending just a data packet instead of voice, it should be able to get through at least a couple times per hour. If it gets through every 10 minutes, then that's even better. Each glider operation with internet access could set up the methods to track all local pilots, and the dream of getting real time competition tracking into the mainstream may have just turned into reality. If I read the review article correctly, the unit will cost $150 with a $150 per year subscription ($100 basic + $50 for real time). This is starting to look like a near perfect passive tracking and emergency "locating" solution. An ELT or PLB is still a must, but the realtime tracking will at least provide a starting point for the search. -Tom |
http://www.equipped.org/SPOT_ORSummer2007.htm Some brief testing with SPOT by Doug Ritter at http://www.equipped.org/blog/?p=73 Keeps looking interesting. Darryl |
On Oct 3, 3:03 am, "
wrote: Keeps looking interesting. And since they say it will run on alkaline batteries, then I assume it will run on rechargeables as well. If I were to put in a fresh pair of charged batteries before each flight and select tracking mode, then if I did have an accident, it should provide a relatively small area in which to look for me. If course an ELT and/or PLB would still be a very good idea. Assuming an XC speed of 90 mph and an update every 10 minutes, the search radius would be about 15 miles. An update every 15 minutes would push that up to 22 miles, but still a lot better than the potential of at least 100 miles on one of my typical flights. Using topography, weather and a declared flight, the search area would go down dramatically. And if each club had someone actively monitoring the day's flying, a pilot in trouble could be identified within an hour or less. Since we are interested in tracking while airborne, we should be seeing near 100% coverage, unless flying deep inside canyons. I have a feeling that I'll be an early adopter! -Tom |
On Oct 3, 11:56 am, 5Z wrote:
On Oct 3, 3:03 am, " wrote: Keeps looking interesting. And since they say it will run on alkaline batteries, then I assume it will run on rechargeables as well. If I were to put in a fresh pair of charged batteries before each flight and select tracking mode, then if I did have an accident, it should provide a relatively small area in which to look for me. If course an ELT and/or PLB would still be a very good idea. Assuming an XC speed of 90 mph and an update every 10 minutes, the search radius would be about 15 miles. An update every 15 minutes would push that up to 22 miles, but still a lot better than the potential of at least 100 miles on one of my typical flights. Using topography, weather and a declared flight, the search area would go down dramatically. And if each club had someone actively monitoring the day's flying, a pilot in trouble could be identified within an hour or less. Since we are interested in tracking while airborne, we should be seeing near 100% coverage, unless flying deep inside canyons. I have a feeling that I'll be an early adopter! -Tom Early adopters, please share your experience with us. This is really sounding interesting, and cheap too. Almost too good to be true. Too bad Fossett didn't use one... Ramy |
Tom
I'm also thinking it would be a fun think for those friendly local races days - a really low cost way for clubs/FBOs to do some interesting flight tracking and as you say, a great safety tool to boot - and kind of obvious when somebody lands out if they can't raise anybody on the radio - a stationary target over the favorite landout strips. Still wish it had external power and a way not to have to press the tracker feature. I think I'll also be buying one. Darryl On Oct 3, 11:56 am, 5Z wrote: On Oct 3, 3:03 am, " wrote: Keeps looking interesting. And since they say it will run on alkaline batteries, then I assume it will run on rechargeables as well. If I were to put in a fresh pair of charged batteries before each flight and select tracking mode, then if I did have an accident, it should provide a relatively small area in which to look for me. If course an ELT and/or PLB would still be a very good idea. Assuming an XC speed of 90 mph and an update every 10 minutes, the search radius would be about 15 miles. An update every 15 minutes would push that up to 22 miles, but still a lot better than the potential of at least 100 miles on one of my typical flights. Using topography, weather and a declared flight, the search area would go down dramatically. And if each club had someone actively monitoring the day's flying, a pilot in trouble could be identified within an hour or less. Since we are interested in tracking while airborne, we should be seeing near 100% coverage, unless flying deep inside canyons. I have a feeling that I'll be an early adopter! -Tom |
| Thread Tools | |
| Display Modes | |
| Lawrence Sperry's Messenger biplane landing in front of the US Capitol Building, Washington DC | Dave Kearton | Aviation Photos | 1 | May 10th 07 08:48 AM |
| spot the topless passenger | Dan Luke | Piloting | 19 | March 21st 07 07:32 PM |
| Warm spot for IFR finish-up | Dave Reinhart | Instrument Flight Rules | 9 | September 17th 05 02:37 PM |
| US: Region 4 South - spot available | Dirk Elber | Soaring | 1 | September 14th 04 10:23 AM |
| Dont shoot the messenger | Jeff | Piloting | 5 | February 11th 04 10:12 AM |
