On Wed, 10 Oct 2007 15:49:48 -0700, Fred the Red Shirt
wrote: On Oct 9, 11:53 pm, Steve Hix wrote: In article .com, Fred the Red Shirt wrote: ... Obviously you have not seen how a telescope mirror ages over the years. Guess again. Well then you should have observed that the transparency increases between cleanings. It's easy to recoat the mirror, so it's not so much of a problem, certainly less of one than dealing with silver corrosion. While it is not a technologically daunting task, it is not cheap for IF you have the equipment (vacuum chamber, heater for vaporizing Aluminum) it's relatively simple. One of our Astronomy club members does up to 10 or 12" for the locals. IIRC his favorite source of Aluminum is peeling the foil off gum wrappers although regular Aluminum foil works. It just takes more power. It doesn't take a super high vacuum either. Just one high enough to develop a plasma although that's not part of the process. On local used the chemical process for coating which worked pretty well, but the coating isn't nearly as even as vacuum deposition. larger mirrors especially when you consider shipping. I have a 17.5" mirror that will need realuminizing when I finally get around to putting it into a scope. It has been cleaned exactly once, but the coating is nearly gone entirely after 30 years in storage. Offhand, do you know anyone who recoats mirrors that size? Not that size, but there are a number of labs that do the work and I think I saw a couple of links listed. Roger (K8RI). |
Richard Riley wrote:
On Thu, 04 Oct 2007 04:52:18 GMT, Darrel Toepfer wrote: Ron Wanttaja wrote in m: On Wed, 03 Oct 2007 16:35:43 -0700, Richard Riley wrote: "Research is continuing to look at fatigue, as well as analysis of damage caused by corrosion, hail storms and other weather phenomena, including trucks that collide with aircraft while they’re on the ground." That's really bad weather. When they say, "It's raining cats and dogs," one generally ISN'T thinking CATerpillars and DOGdges. :-) Can "transparent aluminum" be far behind? You're behind the times. Transparent aluminum is commercially available, I have a sample on my desk. It's expensive - $10/sq. in - but more bulletproof than armored glass and half the weight. Google aluminum oxynitride or ALON. Star Trek 4 came out in 1986. The first patent for aluminum oxynitride as transparent aluminum - from Raytheon, patent 4720362 - was filed in 1985 and granted in 1988. Damit Scotty! You know the Prime Directive specifically prohibits passing advanced technology to primitive cultures!! |
Star Trek 4 came out in 1986. The first patent for aluminum oxynitride as transparent aluminum - from Raytheon, patent 4720362 - was filed in 1985 and granted in 1988. D@rn, but was it formulated on an old Mac with a wired mouse? |
aluminum rib, aluminum spar, holes drilled but screws broken off | jls | Home Built | 13 | January 3rd 07 08:06 AM |
Lighter than air... | Richard Lamb | Home Built | 12 | February 27th 06 11:16 PM |
composite using aluminum windowscreen layer | Allan Morrison | Home Built | 4 | January 27th 05 01:19 PM |
Composite & Carbon Fiber | NW_PILOT | Home Built | 11 | September 21st 04 06:21 PM |
If I make it stronger | Jdandy | Home Built | 9 | August 30th 04 08:22 PM |
