Mxsmanic wrote in
news ![]() Gatt writes: I recommend building an airplane sometime. The ultimate way to prove your theory is to be like the Wright Brothers; build it and fly it. Folks on this forum have logged hundreds of thousands if not millions of collective hours and all of them have put their asses on the line based on the aerodynamic principles in books ... But they have not built airplanes, as you suggest (with a few rare exceptions, and even then they did not design them). I have. About once a month somebody comes in here and wants to talk about how aerospace science is all wrong but the thing is, none of 'em ever seems to have flown an airplane. Flying an airplane wouldn't help, although designing one (successfully) would. You haven't done either, fjukkktard Bertie |
On Oct 4, 10:27 am, Le Chaud Lapin wrote:
The cigarettes would be lit so that stream of smoke floats upward. Can cigarettes be lit so that the smoke flows downward? If flat pressure sensors were mounted below the wing, close to the trailing edge, they would show a momentary increase in pressure. We've been told for years by people who do wind-tunnel experiments that the pressure on the bottom is not increased. Again, it's not intuitive. We're feeling drag, not an increase in pressure. If we hold a funnel (a version of a converging duct) with the big end to the wind, we'll find accelerating airflow in it, decreasing pressure, decreasing temperature, and drag that makes us think that the pressure in it is increasing. The air below is moving downward, something that could be measured by an airspeed indicator, but that doesn't mean pressure is increased. It means that the air has dynamic pressure now because it's moving, and if it's moving its static pressure has decreased. Better get building this thing. Get back to us as to the pressure readings under the wing. Dan Dan |
FAA advisory voids IFR certification for GPS's!!! | Prime | Owning | 12 | May 29th 07 01:43 AM |
Brass or copper sheet? | Scott | Home Built | 11 | October 15th 06 02:20 AM |
4130 sheet | log | Home Built | 4 | September 1st 04 01:42 AM |
Day 2 New Castle Score Sheet | Guy Byars | Soaring | 3 | September 25th 03 02:39 AM |
S-H Spars: Anyone check for voids laterally? | Mark Grubb | Soaring | 1 | September 20th 03 04:27 AM |
