Does VFR Operation Require A High Level Of Language Proficiency?
Old October 9th 07, 08:00 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default Does VFR Operation Require A High Level Of Language Proficiency?
Larry Dighera wrote in
news
On Tue, 09 Oct 2007 18:10:09 -0000, "Robert M. Gary"
wrote in
.com:
On Oct 9, 4:41 am, Larry Dighera wrote:
Does VFR Operation Require A High Level Of Language Proficiency? It
looks like some in Europe would think it might:
IAOPA WINS LANGUAGE REPRIEVE
(http://www.avweb.com/eletter/archive...ll.html#196325)
The International Aircraft Owners and Pilots Association has
successfully lobbied the International Civil Aviation Organization
(ICAO) to delay by three years implementation of onerous language
proficiency rules it says would severely limit VFR flight in much
of Europe. Under the ICAO proposal, all pilots would require to
demonstrate a high level of proficiency in either English or the
language of the country in which they are flying. In an interview
with AVweb at AOPA Expo in Hartford, IAOPA General Secretary John
Sheehan said the rule makes sense for IFR operations but not for
recreational flyers. "For VFR people it doesn't make any sense,"
Sheehan said. "I don't think [VFR] requires a high level of
[language] proficiency."
Given the US's provision for NORDO VFR operations, that has probably
been in the regulations since their inception, one can only conclude
that VFR operation doesn't even require any communication at all.
Most pilots would consider NORDO to be an emergency operation.
ATC controller, Mr. McNicoll does it all the time, as does Mr. Ford. I
doubt they would concur.
All public use airports need communication.
At controlled fields, light signals are quite effective for
communications, and they require no language ability.
Flying into an airport (even a very small one) without talking could
certainly be considered careless or reckless.
For some folks, flight of any kind might qualify as careless and
reckless, but the fact is, that the CFRs permit aircraft without
electrical systems (and hence radios) to operate at public use
airports, and it routinely occurs.
I haven't the time right now to research the NTSB database, but it
would be enlightening to know how the percentage of NORADO flights
that result in being the cause of or contribute to incidents and
accidents.
Don't get me wrong. If I were flying an aircraft certified without an
electrical system, you can bet I'd have a handheld radio. But that's
just me. I'm a cautious sort; I'd have a backup handheld too.
If you're that reliant on ATC do you carry matches so you can set your
seats on fire for smoke signals?
Bertie
Old October 12th 07, 10:35 PM posted to rec.aviation.piloting
Robert M. Gary
On Oct 9, 12:00 pm, Bertie the Bunyip wrote:
Larry Dighera wrote innews
wrote in
.com:
accidents.
That's got to be the most sophomoric logic fallacy I've ever heard.
-Robert
Old October 13th 07, 07:07 AM posted to rec.aviation.piloting
"Robert M. Gary" wrote in
ups.com:
Larry Dighera wrote
innews
wrote in
.com:
It looks like some in Europe would think it might:
(http://www.avweb.com/eletter/archive...974-full.html#
1963
25)
Organization
much of Europe. Under the ICAO proposal, all pilots would
require to demonstrate a high level of proficiency in either
English or the language of the country in which they are
flying. In an interview with AVweb at AOPA Expo in Hartford,
IAOPA General Secretary John Sheehan said the rule makes
sense for IFR operations but not for recreational flyers.
"For VFR people it doesn't make any sense," Sheehan said. "I
don't think [VFR] requires a high level of [language]
proficiency."
probably been in the regulations since their inception, one can
only conclude that VFR operation doesn't even require any
Ford. I doubt they would concur.
could certainly be considered careless or reckless.
accidents.
an electrical system, you can bet I'd have a handheld radio. But
that's just me. I'm a cautious sort; I'd have a backup handheld
too.
your seats on fire for smoke signals?
Um, yeah, that was obviously an attempt at logic.
IIRC my philosophy correctly, the Shophists were big on just that sort
of reasoning.
Bertie
Old October 9th 07, 10:04 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
I know of many pilots of both antique aircraft and gliders that would
likely disagree.
All
public use airports need communication. Flying into an airport (even a
very small one) without talking could certainly be considered careless
or reckless.
Considered careless or reckless by whom? Obviously the FAA doesn't think
so.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200710/1
Old October 12th 07, 10:33 PM posted to rec.aviation.piloting
Robert M. Gary
likely disagree.
I fly antique aircraft but am not so cheap as to not be able to afford
a couple hundred dollars for a portable radio. This isn't the 1920's
you know.
Old October 12th 07, 11:16 PM posted to rec.aviation.piloting
you know.
I'm not sure which one's you're flying, but the unshielded ignition systems
in many of the ones I've flown made my handheld radio just about useless. It
has nothing to do with being cheap.
Message posted via http://www.aviationkb.com
Old October 9th 07, 10:34 PM posted to rec.aviation.piloting
Mxsmanic
Robert M. Gary writes:
But some wouldn't, and it's perfectly legal.
All public use airports need communication. Flying into an airport (even a
or reckless.
It's legal and safe if done correctly (at small airports). It may not be as
flexible or prudent as having a radio, but it's allowed and it isn't careless
or reckless.
Old October 9th 07, 10:39 PM posted to rec.aviation.piloting
Mxsmanic wrote in
(even a very small one) without talking could certainly be considered
be as flexible or prudent as having a radio, but it's allowed and it
isn't careless or reckless.
How would you know?
You don't fly.
Never will.
bertie
Robert M. Gary
or reckless.
I think there is an upgrade available from Microsoft where you can
have full ATC.
-Robert
Old October 14th 07, 07:58 AM posted to rec.aviation.piloting
oups.com:
not be as flexible or prudent as having a radio, but it's allowed and
it isn't careless or reckless.
have full ATC.
God forbid you should sim without guidance from someone on the ground to
keep you out of trouble, eh?
Bertie
USN R4Ds aboard USS Phillipine Sea for Operation High Jump 1947 Dave Kearton Aviation Photos 0 May 16th 07 08:32 AM
question about instrument proficiency check Sylvain Instrument Flight Rules 14 October 20th 05 09:11 AM
Perfect Proficiency Flight Jay Honeck Piloting 39 August 30th 05 06:06 PM
What level of commercial operation can an owner operator goto under FAR91? Peter Bondar Owning 3 October 17th 04 02:40 AM
Changes in Instrument Proficiency Check Requirements Richard Kaplan Instrument Flight Rules 71 June 10th 04 08:02 PM
