Interesting runway environment... no trees.. but when the cross winds get
nasty here we get mechanical turbulence on final from the multi story hotel about 1/2 mile to the offset to final.. clear that and the burble goes away and just deal with the decreasing performance crosswind as you get closer to the ground. BUT !! The runway is slightly elevated above the drainage ditch between the two runways.. more of an easy swale than a ditch.. and the low level breeze can create "ridge lift" in glider pilot language.. as it comes up the swale to the runway.. low level lift right over the runway.. and you find yourself with the power back.. wing low crosswind approach and "soaring in ridge lift and climbing".. with the tire looking at the terra firma only mere inches below. The "code to be cracked"? NEVER EVER stop flying the airplane.. tail wheel or nose tragger.. until it is in the chocks and chained. I experienced the same "tree line cross wind shear" when I first learned taildraggin in a J3 more than 25yrs ago on a grassy runway just off the beach in New Hampshire. BT "Kyle Boatright" wrote in message news ![]() I'm always puzzled by the impact obstacles (trees, buildings, etc) have on a crosswind. On the day ten years ago when I earned my tailwheel endorsement, there was a 15 knot direct crosswind above the treeline. But, the field was buried in a small gap between 75' trees and the crosswind effectively disappeared once the airplane descended below the trees. Even better, there was no turbulence. I'm still surprised at how easy it was to land in those conditions. As opposed to yesterday, when I was landing at a nearby field in a 10 knot, 60 degree crosswind. There was a row of 50' trees a hundred and fifty feet upwind of the runway, and those trees (presumably) created a nasty burble at groundlevel. Because of my widely varied experience with obstacles interacting with crosswinds, I struggle to pick the *best* runway or landing spot. Is it better to bet on an obstacle reducing the crosswind, or is that obstacle likely to cause a burble that will result in a rotten (or exciting) landing? I'm still trying to crack the code on this one... Thoughts? KB |
| Thread Tools | |
| Display Modes | |
| Navy's 'Ring Of Steel Bomb' Flattens Obstacles | [email protected] | Naval Aviation | 0 | August 28th 07 04:27 AM |
| %%%%HOW TO BE FUNNY!%%%% | Expert Humor | Soaring | 0 | March 31st 06 05:13 PM |
| %%%%HOW TO BE FUNNY!%%%% | Expert Humor | Owning | 0 | March 31st 06 05:12 PM |
| Garmin GPS196 Update v.4 - obstacles? | [email protected] | Piloting | 13 | March 16th 05 07:05 PM |
| Funny B-2 Pic | Leadfoot | Military Aviation | 1 | October 26th 03 09:35 PM |
