On Oct 17, 8:43?pm, Randy wrote:
I am looking for suggestions on what type of video equipment to use to record some soaring flights. I would also like to know to safely mount the cameras, (both inside and outside the cockpit). Thanks for your time! Randy best format - Mini DV. I've zip tied a lipstick camera to my sunglasses with good results. Also find a clamp type mount to mount lipstick camera to tubing behind pilot for over shoulder shots, down the wing shots. Duct tape lipstick camera to exterior of glider - check for proximity of tattle tales first. Video security web sites have a variety of lipstick cams to choose from. Most do need 12v power, either from glider or separate pack. Use Mini DV camcorder as VCR and away you go. I tuck my camcorder under my right elbow. The more camera angles the better. So do the same flight over and over with camera in different place each time. Makes it look like you have a camera crew. Don't forget air to air shots and ground to air shots too.... Oh, don't screw up while cameras are running! Joe Bozo |
On Oct 19, 6:36 pm, Airjunkie wrote:
On Oct 17, 8:43?pm, Randy wrote: I am looking for suggestions on what type of video equipment to use to record some soaring flights. I would also like to know to safely mount the cameras, (both inside and outside the cockpit). Thanks for your time! Randy best format - Mini DV. I've zip tied a lipstick camera to my sunglasses with good results. Also find a clamp type mount to mount lipstick camera to tubing behind pilot for over shoulder shots, down the wing shots. Duct tape lipstick camera to exterior of glider - check for proximity of tattle tales first. Video security web sites have a variety of lipstick cams to choose from. Most do need 12v power, either from glider or separate pack. Use Mini DV camcorder as VCR and away you go. I tuck my camcorder under my right elbow. The more camera angles the better. So do the same flight over and over with camera in different place each time. Makes it look like you have a camera crew. Don't forget air to air shots and ground to air shots too.... Oh, don't screw up while cameras are running! Joe Bozo there's a ton of mini-dvs out there ... any recommendations ... do all mini-dvs allow you to hook up a lipstick cam? thanks, KK |
On Oct 19, 5:48 pm, "Ken Kochanski (KK)"
wrote: On Oct 19, 6:36 pm, Airjunkie wrote: On Oct 17, 8:43?pm, Randy wrote: I am looking for suggestions on what type of video equipment to use to record some soaring flights. I would also like to know to safely mount the cameras, (both inside and outside the cockpit). Thanks for your time! Randy best format - Mini DV. I've zip tied a lipstick camera to my sunglasses with good results. Also find a clamp type mount to mount lipstick camera to tubing behind pilot for over shoulder shots, down the wing shots. Duct tape lipstick camera to exterior of glider - check for proximity of tattle tales first. Video security web sites have a variety of lipstick cams to choose from. Most do need 12v power, either from glider or separate pack. Use Mini DV camcorder as VCR and away you go. I tuck my camcorder under my right elbow. The more camera angles the better. So do the same flight over and over with camera in different place each time. Makes it look like you have a camera crew. Don't forget air to air shots and ground to air shots too.... Oh, don't screw up while cameras are running! Joe Bozo there's a ton of mini-dvs out there ... any recommendations ... do all mini-dvs allow you to hook up a lipstick cam? thanks, KK No, look for those with AVI input. I have a JVC GR-DF550 I bought specifically for that feature though it's a couple of years old now. Also, for general use 1.33MP CCD. Many out there have 680K CCD. Get highest res lipstick cam also. AVI lipstick cam and mic will require external power and they are recorded in dubbing mode. Frank Whiteley |
On Oct 19, 9:19 pm, Frank Whiteley wrote:
On Oct 19, 5:48 pm, "Ken Kochanski (KK)" wrote: On Oct 19, 6:36 pm, Airjunkie wrote: On Oct 17, 8:43?pm, Randy wrote: I am looking for suggestions on what type of video equipment to use to record some soaring flights. I would also like to know to safely mount the cameras, (both inside and outside the cockpit). Thanks for your time! Randy best format - Mini DV. I've zip tied a lipstick camera to my sunglasses with good results. Also find a clamp type mount to mount lipstick camera to tubing behind pilot for over shoulder shots, down the wing shots. Duct tape lipstick camera to exterior of glider - check for proximity of tattle tales first. Video security web sites have a variety of lipstick cams to choose from. Most do need 12v power, either from glider or separate pack. Use Mini DV camcorder as VCR and away you go. I tuck my camcorder under my right elbow. The more camera angles the better. So do the same flight over and over with camera in different place each time. Makes it look like you have a camera crew. Don't forget air to air shots and ground to air shots too.... Oh, don't screw up while cameras are running! Joe Bozo there's a ton of mini-dvs out there ... any recommendations ... do all mini-dvs allow you to hook up a lipstick cam? thanks, KK No, look for those with AVI input. I have a JVC GR-DF550 I bought specifically for that feature though it's a couple of years old now. Also, for general use 1.33MP CCD. Many out there have 680K CCD. Get highest res lipstick cam also. AVI lipstick cam and mic will require external power and they are recorded in dubbing mode. Frank Whiteley Thanks, Frank ... I also found a site that seems to identify all camcorder models that have AV Inputs ... I guess all of these will support an external lipstick cam ... don't know enough about the hardware to understand if there are any other factors that would result in problems. http://www.vio-pov.com/support/index...acture r=Sony |
Consider using a HiDef camera like the Canon HV20. Uses standard DV
tapes but is a full HD format camera. Around $900 or less. I've been experimenting with an HV20 in the cockpit for capturing footage for advanced XC training purposes. A very short clip (no narration, just raw footage) is at: http://vimeo.com/343957 Now this has been massaged by Vimeo (a partner posted this there as a test), so the clarity is not all you can get from HD, but when you see the crispness and detail from raw HD footage, it's fantastic. Especially when you think that our sport often relies on small visual details (sky or ground), then HD is the way to go. Warning: the files are enormous (13 Gigabytes per hour of footage), and there is no reliable PC based system for ingesting and editing. Buy a dual processor Mac with max memory and disk and you'll be set. Also consider a half Terabyte external drive too. I don't know about lipstick cameras that can output an HD usable image, if anyone knows about that, I'd like to hear about it. I saw the table from a previous post that showed the HV20 supported, but that could be at a lower resolution. Hmmmm Kemp |
making money | william[_2_] | Home Built | 2 | July 19th 07 11:53 PM |
On making it difficult for everyone else | Frank Whiteley | Soaring | 35 | May 8th 07 05:52 PM |
So, can we quit making believe the man can't fly? | Marc Ramsey | Soaring | 10 | March 10th 05 06:06 PM |
VIDEO: Frecce Tricolore collides over Ramstein - a new head on video | Montblack | Piloting | 1 | February 12th 05 04:03 AM |
Making your own canopy | c hinds | Home Built | 6 | November 22nd 04 09:10 AM |
