On Oct 22, 7:57 am, wrote:
On Oct 21, 11:13 am, Tim Taylor wrote: [snip] If you are THAT much too high, wouldn't it also be prudent to consider a large 360? It may not be pretty, but let's face it, if you have turned final and just THEN realized you're way too high, you've already lost all your style points. Was this a serious comment? How many more people have to die to prove you should not be suggesting turning away from the runway? A pilot was killed in the Sierras in the last few years doing exactly this and we had at least another major accident this year in the Sierras this year with the same thing. It is on of the precursors to stall-spin accidents, nasty scenarios like if unexpected lift cause the glider to be high, the turn takes the glider out of lift, now you are going down fast and pointing the wrong way. And low and the ground is coming up at you, maybe I'll pull back more, push that foot to make the nose go round, ugh, oh f!@#... Use S-turns, parasitic drag approaches, slips etc. but don't turn away from the runway. --- As for the high speed/paracitic drag approach Cindy Brinkner talked about this at an SSA convention a few years ago. Maybe she has slides available etc. I was suprised by the whispering amongst some people in the audience about "ohh this is bad". I see it as a very useful tool to have in your toolkit. I think Cindy's points were don't try it by yourself - go take a ride with an knowledgeable instructor and that in the hands of less experienced piltos in the right gliders this may be a safer techqunique than slipping - I've seen pilots who have *no* clue how to really slip to loose height, far too timid, nose just a little off center - I have no idea if they were taught better and have just forgotten or what. Like Marc says the Duo tends to hold energy and makes this somewhat less useful (but it still works, you do come down faster), but slips work great in a Duo as compensation for not overly effective spoilers. I was all set to demonstrate a parasitic drag approach in a Duo today but the instructor doing the check ride thought a rope break would be better :-( Things are not black and white, I'd hope good pilots want to try out different techniques, see what works best in different gliders and situations and have the benefit of different tools at their disposal. Darryl |
I have used the high speed parasitic drag approach, and others.
First point is - no-one here has mentioned that the appropriate action depends on the wind speed and direction. In all cases drag increases at the square of velocity. If you have a really low drag glider that is optimised for high speed you might not get that high a return. In a low performance ship the results are dramatic. Consider being way too high on final approach in a low wing loading wood and fabric trainer. If you are in still air, or have a tail wind then diving will work best. Maximum drag, get close to the ground, bleed speed off. If you have a strong headwind you can slow down and increase your angle of decent, not rate. This is the inverse calculation of working our McCready speed for best XC distance. Here you want to reduce the distance by flying too slowly. One hint - you will be descending through wind gradient so leave a height + speed reserve to compensate close to the ground. Another technique is - if you see you are too high turning onto final, why continue the turn. Extend the base leg a bit, make a steep 90 degree turn back and line up. It is a sort of S turn, but more effective in that you start from 90 degrees to the landing point. I know at least one pilot who has serious injuries from making an S turn and losing it. So any of the approaches carries risk. We generally teach side slipping as the preferred method, and with 6000 feet of runway - land long rather than spin in trying to nail the threshold. Landing in a field is a different matter. I must agree the 360 is a bad idea. Not saying you should never do it - I did it once to avoid conflicting traffic - but it is not advisable/comfortable to lose sight of the runway low down. Use the appropriate one for the circumstances. wrote: On Oct 22, 7:57 am, wrote: On Oct 21, 11:13 am, Tim Taylor wrote: [snip] If you are THAT much too high, wouldn't it also be prudent to consider a large 360? It may not be pretty, but let's face it, if you have turned final and just THEN realized you're way too high, you've already lost all your style points. Was this a serious comment? How many more people have to die to prove you should not be suggesting turning away from the runway? A pilot was killed in the Sierras in the last few years doing exactly this and we had at least another major accident this year in the Sierras this year with the same thing. It is on of the precursors to stall-spin accidents, nasty scenarios like if unexpected lift cause the glider to be high, the turn takes the glider out of lift, now you are going down fast and pointing the wrong way. And low and the ground is coming up at you, maybe I'll pull back more, push that foot to make the nose go round, ugh, oh f!@#... Use S-turns, parasitic drag approaches, slips etc. but don't turn away from the runway. --- As for the high speed/paracitic drag approach Cindy Brinkner talked about this at an SSA convention a few years ago. Maybe she has slides available etc. I was suprised by the whispering amongst some people in the audience about "ohh this is bad". I see it as a very useful tool to have in your toolkit. I think Cindy's points were don't try it by yourself - go take a ride with an knowledgeable instructor and that in the hands of less experienced piltos in the right gliders this may be a safer techqunique than slipping - I've seen pilots who have *no* clue how to really slip to loose height, far too timid, nose just a little off center - I have no idea if they were taught better and have just forgotten or what. Like Marc says the Duo tends to hold energy and makes this somewhat less useful (but it still works, you do come down faster), but slips work great in a Duo as compensation for not overly effective spoilers. I was all set to demonstrate a parasitic drag approach in a Duo today but the instructor doing the check ride thought a rope break would be better :-( Things are not black and white, I'd hope good pilots want to try out different techniques, see what works best in different gliders and situations and have the benefit of different tools at their disposal. Darryl |
Others have suggested
increasing speed to increase drag. I am not a big fan of this technique because I feel it minimizes options for the pilot and is susceptible to pilot error that can end up in over shooting the LZ. I didn't think so either until Marty Eiler at Cal City demonstrated it for me as part of a BFR. Practiced, and properly done, it can produce an unbelievably steep angle from decision point to stopping point. Yes you have to point the nose at the ground and look temporarily like you'll undershoot. Definitely not for beginners, but not a maneuver to be dismissed either. A suggestion: I bought a copy of the condor flight simulator a while ago, in part to explore on the ground how things like this work out. It does let you practice and explore limits of glider abilities. You can find out, for example, exactly how much altitude a 360 will take in various configurations, or how much altitude you really need for a 180 back to the airport. John Cochrane |
On Oct 22, 11:30 am, BB wrote:
Others have suggested increasing speed to increase drag. I am not a big fan of this technique because I feel it minimizes options for the pilot and is susceptible to pilot error that can end up in over shooting the LZ. I didn't think so either until Marty Eiler at Cal City demonstrated it for me as part of a BFR. Practiced, and properly done, it can produce an unbelievably steep angle from decision point to stopping point. Yes you have to point the nose at the ground and look temporarily like you'll undershoot. Definitely not for beginners, but not a maneuver to be dismissed either. A suggestion: I bought a copy of the condor flight simulator a while ago, in part to explore on the ground how things like this work out. It does let you practice and explore limits of glider abilities. You can find out, for example, exactly how much altitude a 360 will take in various configurations, or how much altitude you really need for a 180 back to the airport. John Cochrane Doing these tests in the actual glider (at high altitude) with a data logger will produce reliable numbers. The simulator might or might not reproduce the performance accurately enough. Todd Smith 3S |
BB wrote:
Others have suggested increasing speed to increase drag. I am not a big fan of this technique because I feel it minimizes options for the pilot and is susceptible to pilot error that can end up in over shooting the LZ. I didn't think so either until Marty Eiler at Cal City demonstrated it for me as part of a BFR. Practiced, and properly done, it can produce an unbelievably steep angle from decision point to stopping point. Yes you have to point the nose at the ground and look temporarily like you'll undershoot. Definitely not for beginners, but not a maneuver to be dismissed either. I find it a very useful technique if I am high enough on final to use it. Generally, I use it shortly after turning final as I realize I am too high, even with full spoiler. That's when I have 500' agl or so, which is plenty. Going from 50 knots to 70 knots (watch the flap setting speed) doubles the rate of energy loss. When I slow down to 50 knots again (still at full spoiler), my new "aim point" is much closer, and I can reduce the spoilers to (ideally) about half. If I'm "low", say less than 200', when I decide I'm too high, slipping is my choice. I've never used S turns: if I'm high enough to make turns on final, it's easier and safer to dive off the speed. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Oct 22, 5:58 pm, Eric Greenwell wrote:
I find it a very useful technique if I am high enough on final to use it. Generally, I use it shortly after turning final as I realize I am too high, even with full spoiler. That's when I have 500' agl or so, which is plenty. Going from 50 knots to 70 knots (watch the flap setting speed) doubles the rate of energy loss. When I slow down to 50 knots again (still at full spoiler), my new "aim point" is much closer, and I can reduce the spoilers to (ideally) about half. All this is way outside my experience, and I'm not going to attempt it myself (though I might nobble an instructor experienced at it). However I still have a question: do you dive and then return to normal approach speed before rounding out, or round out at the much faster speed? If the latter, does not the extra float in ground effect negate the losses from extra drag in the dive, especially with a slippery glass ship versus a draggy wood and fabric glider (such as one a pilot might train in)? Dan |
On Mon, 22 Oct 2007 19:17:18 -0000, Dan G wrote:
However I still have a question: do you dive and then return to normal approach speed before rounding out, or round out at the much faster speed? If the latter, does not the extra float in ground effect negate the losses from extra drag in the dive, especially with a slippery glass ship versus a draggy wood and fabric glider (such as one a pilot might train in)? You found the problem! ![]() The key is to be back at normal approach speed while still outside the ground effect. This means you need to decide about using this maneuvre while still fairly high. Bye Andreas |
Dan G wrote:
SNIP However I still have a question: do you dive and then return to normal approach speed before rounding out, or round out at the much faster speed? If the latter, does not the extra float in ground effect negate the losses from extra drag in the dive, especially with a slippery glass ship versus a draggy wood and fabric glider (such as one a pilot might train in)? SNIP I had this demonstrated to me by a very experienced instructor in a K13. He had me fly a deliberately high and close in circuit until it was clear that we'd be a long way up the field, even with full airbrake. Then he took over and performed the 'energy dumping' manoeuvre, which involved opening full brake and pointing the nose at the ground. It all happened rather fast and was not unalarming, so my recollections are not exact. However, I'm fairly sure the speed never exceeded 80kts. Certainly the ground approached very rapidly. One moment we were in a gross overshoot situation and the next moment I was concerned that we might impact the ground before reaching the boundary wall. We came out of the dive, popped over wall and settled on to the ground for one of the shortest landings I've seen. I remember being surprised at how quickly we lost the excess speed. Pulling out of a near-vertical dive (at least that's what it felt like) with full airbrakes seems to scrub a lot of energy very quickly. I asked the instructor whether this would work in something more slippery. He answered that it would, but of course it wouldn't be so effective as in the K13. He even told that he had successfully demonstrated it in a Duo, though I don't have any quantitative or qualitative information to say how effective it was. I was also taught this technique on a basic instructors course (in a G103). But I'm always left thinking that it requires a high level of skill to judge the roundout correctly. Leaving it just a second too late would result in a rather rapid meeting with the ground. I think I'd rather take my chances with a side slip. Alastair |
MA-8 with parachute extended S63-00693.jpg | [email protected] | Aviation Photos | 0 | April 10th 07 02:52 PM |
spoilers vs. ailerons | [email protected] | Piloting | 36 | August 8th 05 11:24 AM |
Frozen spoilers | stephanevdv | Soaring | 0 | November 4th 04 05:24 PM |
Extended GPX Schema | Paul Tomblin | Products | 0 | September 25th 04 02:44 AM |
L-13 Spoilers | Scott | Soaring | 2 | August 27th 03 06:08 AM |
