Regarding being high on final, there is a place for both the full
spoiler/increased approach airspeed and the slipping technique. Just as important as being proficient doing them is knowing how to choose the most appropriate for the conditions. For example if the wind is strong, the full spoiler/increased speed is generally safe because losing the energy at the bottom of the maneuver should be no problem. If the wind is zero or very light and/or there is a long line of gliders waiting to launch (we land and depart at 4220 MSL on the same runway at Tehachapi) and therefore the landing runway is shorter than normal, a slip might be most appropriate since you get a high sink rate without adding excessive energy to get rid of at the bottom. As for doing a 360 in the pattern, you may need a plan B when the guys behind you take the runway away from you. Paul ZZ Dan G wrote: On Oct 22, 5:58 pm, Eric Greenwell wrote: I find it a very useful technique if I am high enough on final to use it. Generally, I use it shortly after turning final as I realize I am too high, even with full spoiler. That's when I have 500' agl or so, which is plenty. Going from 50 knots to 70 knots (watch the flap setting speed) doubles the rate of energy loss. When I slow down to 50 knots again (still at full spoiler), my new "aim point" is much closer, and I can reduce the spoilers to (ideally) about half. All this is way outside my experience, and I'm not going to attempt it myself (though I might nobble an instructor experienced at it). However I still have a question: do you dive and then return to normal approach speed before rounding out, or round out at the much faster speed? If the latter, does not the extra float in ground effect negate the losses from extra drag in the dive, especially with a slippery glass ship versus a draggy wood and fabric glider (such as one a pilot might train in)? Dan |
MA-8 with parachute extended S63-00693.jpg | [email protected] | Aviation Photos | 0 | April 10th 07 02:52 PM |
spoilers vs. ailerons | [email protected] | Piloting | 36 | August 8th 05 11:24 AM |
Frozen spoilers | stephanevdv | Soaring | 0 | November 4th 04 05:24 PM |
Extended GPX Schema | Paul Tomblin | Products | 0 | September 25th 04 02:44 AM |
L-13 Spoilers | Scott | Soaring | 2 | August 27th 03 06:08 AM |
