Mxsmanic wrote in
: the warlock society writes: ok ill bite; why are you 'not sure you would have' marked the spot with your GPS? Do I need to make a tinfoil hat before hearing your answer? Apart from the potential futility of doing so, there's also the danger that you'd get zapped with the laser again. Fjukkwit. Like you'd know what it's like. Bertie |
Judah wrote:
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in : Judah wrote: I just hope that the noise grumblers don't get the same idea... I disagree. Hoping of course they don' hurt anyone it would be nice to put a few of them in jail. What do you think are the chances of finding the guy, let alone prosecuting him? I'd say pretty slim at best. And Marco marked the area with a GPS. I'm not sure I would have. Laser Beamed at Plane Leads to N.J. Man's Arrest http://www.washingtonpost.com/wp-dyn...-2005Jan4.html Idaho: 2 Arrested for Pointing Laser http://www.greenlaser.cn/idaho-2-arr...ointing-laser/ and a bunch more. Catching them is hard, prosecution easy. -- Jim Pennino Remove .spam.sux to reply. |
Judah writes:
What altitude where you at? I would bet that a kid with a handheld laser pointer might be very difficult to catch and prosecute, and I bet even a handheld laser pointer will create a flash in your eye at 2000 feet, even if the beam has diffused enough that the "operator" won't be able to tell for sure where it's hitting your plane... If you're lucky, you will only see the diffused portion of the light, and not the beam itself, which may damage your vision. It sounds like the OP saw only the periphery, not the beam itself (which, as you indicate, would be extremely difficult to aim with precision from the ground, unless the culprit also had some sort of telescopic sight and a way to hold the laser steady). The beam of a good quality laser (highly collimated, that is) will hardly spread out at all over a distance of a few thousand feet and thus may still be only a millimetre or two in diameter. |
Mxsmanic wrote in
: Judah writes: What altitude where you at? I would bet that a kid with a handheld laser pointer might be very difficult to catch and prosecute, and I bet even a handheld laser pointer will create a flash in your eye at 2000 feet, even if the beam has diffused enough that the "operator" won't be able to tell for sure where it's hitting your plane... If you're lucky, you will only see the diffused portion of the light, and not the beam itself, which may damage your vision. It sounds like the OP saw only the periphery, not the beam itself (which, as you indicate, would be extremely difficult to aim with precision from the ground, unless the culprit also had some sort of telescopic sight and a way to hold the laser steady). The beam of a good quality laser (highly collimated, that is) will hardly spread out at all over a distance of a few thousand feet and thus may still be only a millimetre or two in diameter. So, you going to put a laser pointer on the edge of your monitor now? Bertie |
On Nov 13, 3:42 pm, Mxsmanic wrote:
The beam of a good quality laser (highly collimated, that is) will hardly spread out at all over a distance of a few thousand feet and thus may still be only a millimetre or two in diameter. Complete ********. Just buy a laser pointer and measure the spot size after 50'. It's already cm wide. The cavity of laser diode is just too short to produce such high degree of collimation... Cheers |
![]() "WingFlaps" wrote in message oups.com... On Nov 13, 3:42 pm, Mxsmanic wrote: The beam of a good quality laser (highly collimated, that is) will hardly spread out at all over a distance of a few thousand feet and thus may still be only a millimetre or two in diameter. Complete ********. Just buy a laser pointer and measure the spot size after 50'. It's already cm wide. The cavity of laser diode is just too short to produce such high degree of collimation... Garden-variety laser pointers aren't the same as the newer high-powered green lasers, though, are they? (For example: http://www.greenlaserbeam.com/ ) -c not a physicist. |
Gatt writes:
Garden-variety laser pointers aren't the same as the newer high-powered green lasers, though, are they? (For example: http://www.greenlaserbeam.com/ ) No, they are not. They are still not the most collimated beams around, but they are collimated enough to cover just about the area of a person's face at a few thousand feet. The total energy delivered to the eye in this case would be in the range of microwatts at several thousand feet, and it would be virtually impossible to accurately aim a handheld pointer at this range. So it would be more of a nuisance to vision than a damage hazard. Unfortunately, there are still more powerful lasers available. Most people dramatically underestimate the hazards of laser light. I'd be nervous about those green pointers just out of concern for my own vision. All you have to do is accidentally aim it at a reflective surface, and next thing you know you have a retinal burn. |
Mxsmanic wrote in
: Gatt writes: Garden-variety laser pointers aren't the same as the newer high-powered green lasers, though, are they? (For example: http://www.greenlaserbeam.com/ ) No, they are not. They are still not the most collimated beams around, but they are collimated enough to cover just about the area of a person's face at a few thousand feet. The total energy delivered to the eye in this case would be in the range of microwatts at several thousand feet, and it would be virtually impossible to accurately aim a handheld pointer at this range. So it would be more of a nuisance to vision than a damage hazard. Unfortunately, there are still more powerful lasers available. Most people dramatically underestimate the hazards of laser light. I'd be nervous about those green pointers just out of concern for my own vision. All you have to do is accidentally aim it at a reflective surface, and next thing you know you have a retinal burn You;re an idiot and as usual, are missing the point altogether. Bertie |
WingFlaps writes:
Complete ********. Just buy a laser pointer and measure the spot size after 50'. It's already cm wide. Laser pointers are hardly the state of the art. |
Mxsmanic wrote in
: WingFlaps writes: Complete ********. Just buy a laser pointer and measure the spot size after 50'. It's already cm wide. Laser pointers are hardly the state of the art. Fjukkwit, nobody said they were. Bertie |
An Interesting Event | RL Anderson | Piloting | 2 | March 2nd 07 04:07 PM |
REQUEST: 14V illumination for RT459A transponder? | [email protected] | Home Built | 3 | October 20th 06 06:14 PM |
Request: RT459 14V illumination jumper settings | mikem | Owning | 0 | October 17th 06 04:37 PM |
Anybody know about an event at AWO? | Rich S. | Home Built | 4 | October 11th 05 01:02 AM |
Flight Number 5 - Illumination! | Shiver Me Timbers | Rotorcraft | 2 | August 25th 04 11:08 PM |
