On 2007-11-13 19:25:30 -0800, buttman said:
On Nov 13, 5:53 pm, "Steven P. McNicoll" wrote: Something like ten years ago, maybe more, there was a case that involved a skydiving club. One of the members was also a private pilot and volunteered to fly the jump plane. He thought it a great way to build free time towards his commercial. Since he was using the time towards another rating it was deemed to be compensation since he'd otherwise have to pay for it and the flights were a commercial operation. http://www.ntsb.gov/alj/O_n_O/docs/AVIATION/4583.pdf this case? If so, in that case, the pilot was in the wrong because he was flying passengers who had paid to be there. He was, but (just to be clear about this) it is not because he was violating the rules for common carriage. See part 119.1: §Â*119.1Â*Â*Â*Applicability. ... (e) Except for operations when common carriage is not involved conducted with airplanes having a passenger-seat configuration of 20 seats or more, excluding any required crewmember seat, or a payload capacity of 6,000 pounds or more, this part does not apply to— ... (6) Nonstop flights conducted within a 25-statute-mile radius of the airport of takeoff carrying persons or objects for the purpose of conducting intentional parachute operations. So, it is not a question of whether he was carrying passengers as a common carrier. It is a question of whether he was piloting an aircraft and carrying passengers for compensation in violation of the privileges and limitations of a private pilot certificate. The FAA said being allowed to fly an aircraft for free was a form of compensation. The problem I really have with this ruling (and the reason I brought this subject up in the first place) was the Administrator's insistence that a private pilot sharing expenses with his passengers must have a 'common purpose' with them for the flight. This is clearly wrong. You almost get the impression that if the pilot had jumped out of the plane along with the skydivers that the FAA would have been okay with that, because then he would have shared enough 'common purpose' with the skydivers to meet the 'shared expenses' rule (provided he had paid his share of the expenses). Because he did not jump out of the plane, there was no 'common purpose' with the skydivers. This is bogus, as the FARs make no mention at all of the need for a 'common purpose' when sharing expenses. See part 61.113 -- no mention of 'common purpose' at all: §Â*61.113Â*Â*Â*Private pilot privileges and limitations: Pilot in command. (a) Except as provided in paragraphs (b) through (g) of this section, no person who holds a private pilot certificate may act as pilot in command of an aircraft that is carrying passengers or property for compensation or hire; nor may that person, for compensation or hire, act as pilot in command of an aircraft. (b) A private pilot may, for compensation or hire, act as pilot in command of an aircraft in connection with any business or employment if: (1) The flight is only incidental to that business or employment; and (2) The aircraft does not carry passengers or property for compensation or hire. (c) A private pilot may not pay less than the pro rata share of the operating expenses of a flight with passengers, provided the expenses involve only fuel, oil, airport expenditures, or rental fees. I think it is clear that this was an obvious example of someone attempting to circumvent the FARs governing commercial flight. Unfortunately, this forced the FAA to adopt a position that adversely affects private pilots engaged in ordinary activity. All it takes is one guy to try to find a loophole, and the FAA will have to plug up the loophole with a plug that blocks hundreds or even thousands of pilots who are engaging in an activity that was formerly considered legitimate. The 'common purpose' test is clearly out of bounds and should only be used in cases of questions of common carriage. In this case, the skydiving operation was clearly 'holding out' without having to resort to any sort of 'common purpose' test. They were advertising in the Yellow Pages, after all, which is how the pilot found them. But, even though they were 'holding out,' they were still within the exception of part 119.1(e)(3), so the issue of 'common purpose' should never have come up at all. -- Waddling Eagle World Famous Flight Instructor |
Problems in a commercial flight | megaMAX | Piloting | 92 | March 23rd 07 09:45 AM |
Question on ferry flight for inspection | M | Owning | 11 | July 14th 05 08:20 PM |
Looping during a commercial flight | LordAvalon | Aerobatics | 10 | October 23rd 04 04:05 PM |
Nixon on Commercial Flight | Flyin'[email protected] | Piloting | 1 | June 16th 04 05:51 PM |
Dash 80 Ferry Flight | MLenoch | Military Aviation | 1 | October 30th 03 11:55 PM |
