Pegasus or ....?
Old November 29th 07, 08:39 AM posted to rec.aviation.soaring
Cats
Default Pegasus or ....?
On Nov 29, 3:22 am, "Bill" wrote:
snip
A sleeve can not be added to the elevator
connection due to lack of space, but this connection is exposed enough that
using a safety pin is not a problem.
snip
I've just brought one and the elevator is self-connecting - it's a
101a.
Old November 29th 07, 05:17 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
snip
snip
101a.
If you can find one, go for a Pegase 90 - they are later than the 101
models and have automatic hook-ups for all controls.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old November 29th 07, 06:49 PM posted to rec.aviation.soaring
Cats
On Nov 29, 5:17 pm, Martin Gregorie
snip
snip
101a.
I've got what I've got - I'll get on with flying it! And I'm
suspecting I'll never need another glider, unless I manage to break it.
Old November 29th 07, 03:53 PM posted to rec.aviation.soaring
Tim Mara
my 2 cents:
Pegasus is a very good choice.
Excellent performance for the money.
Pegasus is very typical of gliders of the late 70's mid 80's performance
More deluxe than ASW19/20 with finished interior, lifting instrument panel
like last ASW20 models offered, having owned (2)Pegasus, ASW19 and ASW20,
and ASW20C would say they all handled and performed essentially the same..
obvious differences were flaps on 20's, Quality was similar, some better and
worse on each.
It doesn't have any bad habits.
Well, keeping wings level in the early part of the takeoff run can be a
bit of a challenge, especially in even the lightest crosswind. It also
tends to drop the nose pretty dramatically and abruptly if you let speed
bleed off in a slip. Otherwise I find it to be a very honest and
relatively docile aircraft. Handling is excellent with very sensitive
response in pitch and yaw (roll is a bit less enthusiastic, as is typical
for this type of aircraft). Be prepared for some moderate PIO on the first
takeoff or two. Assembly is very straightforward assuming spring-loaded
sleeves have been retrofitted to aileron and spoiler connections,
otherwise pinning these connections can be awkward. A sleeve can not be
added to the elevator connection due to lack of space, but this connection
is exposed enough that using a safety pin is not a problem.
worst bad habit if you could call it that is manual hook-ups and lack of
access...very difficult to verify safe control connections....assembly is
slow and very unfriendly by comparison to better designs.
Flying was not difficult or unusual....I never noticed any unusual or
exciting take-offs in any of these, though I did with earlier ASW15's with
offset CG hook....now those need attention! I do have a fair amont of glider
experience though and may not recommend these gliders to lower time pilots
since like any more-or-less modern racing gliders do things more quickly and
less noticeable than club type gliders....all of these (ASW19/20/Pegasus)
gliders can catch the sloppy flyer with an unplanned wingover and possibly a
spin, probably moreso with ASW20 with flaps in use
It is built like a tank, simple and parts are available through the
factory
without any issues whatsoever.
If you speak French.
actually I've called Centrair on a couple of occasions and had no difficulty
in speaking with Mary Ann in English (actually her English was probably
better than mine ) They are still or at least were, when I called last
(about a year ago) very supportive of Pegasus owners, even in the USA but
you can expect to wait for special parts, they are IMO a bit slow with
delivering parts.
Send me an email to jacek dot kobiesa
at clearwire dot net to remained me of it and I will send you their
contact. I bought from them hinges, hinge pins, pedals, etc. So, don't
buy from anybody that lack of factory support nonsense.
Support is available. Access to support for non-Francophones can be
challenging. My best advice to a potential Peg owner is to learn enough
French to be polite and have patience.
It's no more difficult speaking English with people at Centrair than it is
with the German companies, being polite with anyone gets you further than
being rude or demanding.
I am 6' 3" (1.9 meters) and 230 pounds (103.3 kilos). Aside from being a
bit tight in the shoulders, my Peg fits me just fine with a backpack
parachute. I do find the rudder pedals to be very narrow and have to fly
wearing specialized driving shoes with narrow soles to fit my feet into
the pedals. I also find that my knees fall exactly under the relatively
sharp bottom edge of the instrument panel (I added some split rubber hose
as "edge dressing" to provide a bit of cushioning).
Rudder pedals are narrow and uncomfortable, there is little room for big
feet in any of these and there was an ad to change out the rudder pedals in
the pegasus (a not so pleasant operation to accomplish) and the new pedals
were even narrower than the originals for whatever reason...
The only item that I had an issue with is very weak
wheel brake. I rebuild it in my glider with new shoes, springs, cable,
and it was still marginal.
I find the brake, operated by a motorcycle-like lever on the stick,
acceptable when stopping from a slow roll, otherwise it's virtually
useless.
actually I never had an issue with the wheel brakes on any of these, the
brakes were not overPowering, but if serviced and adjusted did an OK job of
stoping the glider....but unmaintained you'll be very unhappy with the
stopping power, they all use a reasonibly sized 5" wheel, much better than
many gliders of the era still using very small light 4" wheels.
But don't take my word for it: go and fly
one, and then fly the LS-4, ASW-19, and whatever else you can and make
your own decision. I just sold mine and I put on it last 2 seasons
almost 200 hours.
In my humble opinion, the Pegasus is a great aircraft and a good choice
for moderately experienced pilots as a first high-performance or
competition sailplane.
I concour mostly....for the $ it's in the ball park, I'd say the LS gliders
handle better and are more docile for relative equal perfomance and similar
costs, quality is typical and no one should expect any of these mentioned
gliders to be in perfect condition, all will have some issues with finish
unless thay have been refinished, find one that has had the best care, the
BEST TRAILER since this will have a great deal to do with enjoyment since
assembly is going to be an issue, and check and DOUBLE check the control
connections!
tim
Please visit the Wings & Wheels website at www.wingsandwheels.com
Bill
"TX"
Posted via NewsDemon.com - Premium Uncensored Newsgroup Service
-------http://www.NewsDemon.com------
Unlimited Access, Anonymous Accounts, Uncensored Broadband Access
Old November 29th 07, 04:34 PM posted to rec.aviation.soaring
Dan G
How does the Standard Cirrus compare to the Pegase and 19 in terms of
performance and handling?
Dan
Old November 29th 07, 05:16 PM posted to rec.aviation.soaring
Michel Talon
Dan
You can find a list of L/D for some gliders he
http://www.soe.ucsc.edu/~mjboyd/cfi/...lidersCompared
They give the Pegase at 41.
The Open Cirrus at 44, but it is a 18m ship. The 15m one is given here
at 38.5 in its best variant
http://fr.wikipedia.org/wiki/Cirrus_(planeur)
By comparison, there is a LS4 polar he
http://www.stolaf.edu/people/hansonr...lars/ls-4a.jpg
which gives L/D at 40. I think it is roughly equivalent to the Pegase.
An other comparison is the ASW19, information can be found he
http://www.sailplanedirectory.com/schleich.htm
and ASW19 is given with L/D at 38, that is basically like the standard
Cirrus, and the ASW20 at 43.
By the way, you can find the other manufacturers at the same place.
Michel TALON
Old November 29th 07, 05:29 PM posted to rec.aviation.soaring
Tim Mara
not even in the same category.... keeping in mind you are speaking of quite
an evolutionally jump, much was learned in construction technique, better
airfoils and to a lesser degree performance.
Std Cirrus is in the generation of ASW15, LS1, Libelle and a few others
in this group I would personally rate the LS1 and best handling, easiest to
fly (I'm speaking of LS1f only)
Libelle (my personal favorite) was best design, innovation, easiest to
assemble and just all around great design for the time....production numbers
seem to prove this also. Std Cirrus, ASW15 and earlier LS1 fall below the
head of the class in all of these areas.
my last 2 cents
tim
"Dan G" wrote in message
Dan
Old November 29th 07, 05:10 PM posted to rec.aviation.soaring
jcarlyle
I think the ASW-19 is suitable to low time pilots, as I started flying
my 19 at about 90 hours and 220 flights total experience (95% of that
in 2-33s, 1-26s, L-13s and L-23s). The biggest transition problem for
me was the CG hook and the need for careful approach speed control.
With regard to manual control hook-ups, I don't find them to be a
problem. It takes 20 seconds to connect the L'Hotelliers, and less
than a minute to pin them. You can easily see things if you put your
eye to the inspection hatch, and it's easy to manually verify through
pushing the button while pulling and twisting to verify that they're
properly engaged. True, manuals aren't the no-brainer that automatic
hook-ups are. However, I've seen automatic hook-ups fail to engage and
cause 5 minutes or so of frustration during wing assembly on LS and SH
ships. Naturally, you MUST do a PCC with either type of hook-up!
I can't speak from personal experience regarding the Pegasus, but the
previous owner of my ship bought one. For what it's worth, he said the
Pegasus flew like a truck in comparison to the ASW-19.
-John
Old November 29th 07, 05:41 PM posted to rec.aviation.soaring
Tim Mara
properly engaged.
must be you're not yet over 50 and into the bifocal user's group....with
Popeye forearms going into tiny hatch opening connections are essentially in
brail, with bright sun looking onto a white fuselage with a black hole to
inspect the connections even making the connetion, say nothing of safety
pins in almost guesswork... I know few who can say that they never missed a
connection at least once....double and triple check them!
must have been a really nice ASW19 and a really bad Pegasus! They are
essentially the same with modified non-flapped 20 wings on the
Pegasus.....The Pegasus probably then I guess flys more like a 20 than it
does a 19.
tim
-John
Old November 26th 07, 09:48 PM posted to rec.aviation.soaring
connekt
For the best of my knowledge the Pegasus is a France-produced version
of the ASW 19, with some marginal modifications. Good ship and very
stable, but I think you won't see much difference compared to the ASW
15. The real step-up on my opinion would be the ASW 20 (the L version
even better), which can really give you some satisfactions. On the
flip side, it requires attention in certain conditions, nothing
impossible but it's definitely less forgiving than the ASW 15, 19 or
the various Discus or LS4. But still the ASW 20 seems to be the best
bang for the buck.
On Nov 23, 8:43 am, Mike125 wrote:
I'm looking to move up a level from my ASW 15. Ideally, I'd like an LS
4 but they are few and far between. A couple of Pegasuses (Pegasi?)
are listed on W&W and seem to be reasonably priced for what you get. I
am in the US and am aware of the 3000 hr issue but don't fly enough
for that to be a factor with the ones I've seen. After looking through
the RAS archives it seems that parts and support were/are an issue.
The most recent of these posts are from 2003. Can I assume that
support hasn't gotten any better? What are you Pegasus drivers
experiencing these days?
As an aside, my ASW 15 had an Experimental certificate when I bought
it. The original owner had a water ballast system installed and the
certificate changed from Standard to Experimental. The system had been
mostly removed when I bought it. I finished the process and had the
certificate changed back to Standard. My questions are 1) how
difficult is it to make the change from Standard to Experimental? and
2) wouldn't this make repairs a little less difficult?
Anyone have a nice LS 4 they are willing to part with?
Mike
Pegasus fo sale ? Jean Soaring 1 February 21st 07 03:44 AM
Pegasus time limit [email protected] Soaring 38 February 14th 07 08:35 AM
Pegasus instrument panel [email protected] Soaring 0 November 1st 06 11:42 PM
FS: Pegasus [email protected] Soaring 1 October 4th 05 10:05 PM
Pegasus AD [email protected] Soaring 9 August 29th 05 12:03 AM
