![]() "Peter R." wrote in message ... On 12/5/2007 10:40:30 AM, "Gig 601XL Builder" wrote: Also, while you link does say, "The best temperature for brewing coffee is between 195 F and 205 F." it doesn't say it should be served at that temperature. So you brew a pot of coffee at that temperature, then what? Wait 20 minutes for it to cool down? Of course not. You draw off a cup right away. Also your prime rib example is not a valid comparison. Beef has to sit 5 to 10 minutes before you cut into it or you risk losing all the juice and making it too dry. Okay, you two -- take this to rec.fan.cooking :~) |
"Peter R." wrote:
On 12/5/2007 10:40:30 AM, "Gig 601XL Builder" wrote: Also, while you link does say, "The best temperature for brewing coffee is between 195 F and 205 F." it doesn't say it should be served at that temperature. So you brew a pot of coffee at that temperature, then what? Wait 20 minutes for it to cool down? Of course not. You draw off a cup right away. So heat a cup of water to 195 F and drink it. Then report back the results. |
Jim Logajan wrote:
"Peter R." wrote: On 12/5/2007 10:40:30 AM, "Gig 601XL Builder" wrote: Also, while you link does say, "The best temperature for brewing coffee is between 195 F and 205 F." it doesn't say it should be served at that temperature. So you brew a pot of coffee at that temperature, then what? Wait 20 minutes for it to cool down? Of course not. You draw off a cup right away. So heat a cup of water to 195 F and drink it. Then report back the results. DISCLAIMER: KIDS DON'T TRY THIS AT HOME. This experiment should only be performed by masochists and those with reckless disregard for their own safety. Also make sure your health insurance is paid up to date. |
On 12/5/2007 4:42:31 PM, Jim Logajan wrote:
So heat a cup of water to 195 F and drink it. Then report back the results. Bland to the taste, could use flavor. -- Peter |
![]() "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote Also, while you link does say, "The best temperature for brewing coffee is between 195 F and 205 F." it doesn't say it should be served at that temperature. If I cook a prime rib at 375 F I don't plan to serve it at that temperature. Exactly. NOBODY can drink coffee at 180 degrees. Few could drink it at 140. -- Jim in NC |
"Morgans" wrote in
: "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote Also, while you link does say, "The best temperature for brewing coffee is between 195 F and 205 F." it doesn't say it should be served at that temperature. If I cook a prime rib at 375 F I don't plan to serve it at that temperature. Exactly. NOBODY can drink coffee at 180 degrees. You haven't met mrs. Bunyip. I'm not kidding.. Straight out of the pot, no colling. She must have had her tongue cauterised by hot drinks until it was leather when she was a child. Bertie |
Morgans wrote:
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote Also, while you link does say, "The best temperature for brewing coffee is between 195 F and 205 F." it doesn't say it should be served at that temperature. If I cook a prime rib at 375 F I don't plan to serve it at that temperature. Exactly. NOBODY can drink coffee at 180 degrees. Few could drink it at 140. Right. Most McDonalds are in towns or cities. I don't drive and drink coffee when in high traffic and congested areas. Even where I live, in a fairly rural area, most McDonalds are located such that I must drive 5-10 minutes before I'm in an area safe enough to drive my coffee while driving. By then the coffee is easily sipped and soon after can be gulped, and this is without adding cream or sugar which cool the coffee. If I was served coffee at 120 degrees, it would be barely above body temperature 10 minutes later and that would not make me a happy camper. Matt |
![]() "Matt Whiting" wrote If I was served coffee at 120 degrees, it would be barely above body temperature 10 minutes later and that would not make me a happy camper. They make little pull offs at every Mc D's so you could open your coffee lid, and get it into your cup holder. Then you could start drinking it in most any traffic. If that does not do it, then you should get one of those little heating elements that plug into your cigarette lighter to heat up your cup of coffee. Don't expect the rest of the world to give up their safety and needs to fit your requirements. -- Jim in NC |
Matt Whiting wrote:
Morgans wrote: "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote Also, while you link does say, "The best temperature for brewing coffee is between 195 F and 205 F." it doesn't say it should be served at that temperature. If I cook a prime rib at 375 F I don't plan to serve it at that temperature. Exactly. NOBODY can drink coffee at 180 degrees. Few could drink it at 140. Right. Most McDonalds are in towns or cities. I don't drive and drink coffee when in high traffic and congested areas. Even where I live, in a fairly rural area, most McDonalds are located such that I must drive 5-10 minutes before I'm in an area safe enough to drive my coffee while driving. By then the coffee is easily sipped and soon after can be gulped, and this is without adding cream or sugar which cool the coffee. If I was served coffee at 120 degrees, it would be barely above body temperature 10 minutes later and that would not make me a happy camper. Matt Unfortunately most people aren't as responsible as you are Matt. McD's research showed most people started drinking right away. |
Criticizing the system based on the McDonald's case is a fallacy. The
reason it got so much attention is because it was an abberant result, at least as far as the jury verdict. The judge reduced the damages substantialy, which shows one of the safeguards that the system has. They are not perfect, but they usually work. There will always be a bad result every once in awhile; e.g., O.J.'s criminal trial and any number of others. Can you name any human system that doesn't screw up once in awhile? You need to realize that there are literally tens of thousand verdicts or court decisions each year. In almost every case at least half the participants feel that the outcome was wrong. The fact that there seems to be some disagreement among the members of this newsgroup shows that the answer is not always clear, even here. Anyone care to guess which entities file the most lawsuits? (I don't mean "lawyers", either. Ha, ha.) As an aside, i once heard it said that the justice system is simply a means to an end. i.e., to resolve a dispute. Nothing more, nothing less. I often tell people that in law school, the one word I never heard discussed by any professor, in any class or in any lawbook was the word "fair." This shocks many people, but after all, what is "fair"? The legal system has no answer to that question any more than does any religion or anything else. |
British Aircraft to be used for Skydiving in Iran! | [email protected] | Aerobatics | 0 | September 7th 07 06:40 PM |
British Aircraft to be used for Skydiving in Iran! | [email protected] | Simulators | 0 | September 7th 07 06:39 PM |
Lycoming Sued | jls | Home Built | 0 | February 13th 04 02:01 PM |
Glider/Skydiving Crash | dm | Soaring | 0 | September 27th 03 05:13 PM |
WOW - Shots fired at skydiving plane in NY... | Buff5200 | Piloting | 15 | July 14th 03 06:37 PM |
